1100M Knowledge Base
Upgrading your 770M+ or 1100M+ mill to a BT30 spindle is a great upgrade to add more tool holding strength. Additionally, for the 1100M+, this upgrade increases your top spindle speed up to 10,000 rpm.
Note: The M+ update is a requirement before completing the BT30 upgrade. However, these updates can be completed at the same time. For more information, see 1100M+ Servo Upgrade .
  • 3 in. (7.6 cm) wooden block, 2
  • 6 in. gear puller
  • Flat-blade screwdriver
  • Metric hex wrench set
  • Open-ended wrenches:
    • 13 mm
    • 19 mm
    • 25 mm
  • Phillips screwdriver
  • Safety eye wear
  • Simple Green (or similar mild degreaser)
  • Torque wrench
  • WD-40 (or similar water displacement oil)
