770M Knowledge Base
Manual Oiler
If you have an automatic oiler, view those instructions here.
Install the Oiler
  1. Find the hardware installed on the left side of the machine stand, as shown in the following image.
Figure 1: Oiler installation location on the left side of the machine stand.
  1. Using the hardware from Step 1, attach the oiler to the machine stand with a 5 mm hex wrench.
Figure 2: Automatic oiler installation on the machine stand.
Make Manual Oiler Connections
  1. Remove and discard the orange plastic shipping plug from the oiler.
  2. Connect the existing oil line on the mill to the oil line on the oiler.
  3. Secure the oil line in the mounting clips on the machine stand.
  4. Fill the oiler's reservoir with machine oil to about 80% full.
Set Up the Manual Oiler
  1. Pull and release the plunger on the oiler until oil is pushed through the distribution system. After that, pull the plunger at the following times:
    1. Every time you power on the mill
    2. Every four hours of operation
  2. You must verify the installation before you install any additional components. If you are not installing any additional components, you still must verify the core installation before you use the machine for the first time. Go to Verify the Core Installation.
This is a section of the 770M operator's manual. To view the whole manual, go to Tormach document UM10540.
