[{"id":"ci_59168c8c3ace97e8b1421644ea62aa8e8cf1b8e5186f4799ea9170da189cae7a","title":"About Your Machine","path":"/770mx/about-your-machine","children":[{"id":"ci_2bd67185071e5d6aaa8ef2e538031e52afa15e0b8143942cee811d1e48c8f537","title":"Safety","path":"/770mx/safety","children":[]},{"id":"ci_ac225f36fde1414b3bade83b2648499e339e83f7396a03661a38d8fcb1d81f8b","title":"Machine Specifications","path":"/770mx/machine-specifications","children":[{"id":"ci_4cc5859865a1099fd29bc4b79faa56709ce5eb1f8d58b09174c9e3488a31c637","title":"T-Slot Spacing on Tormach Mills","path":"/770mx/t-slot-spacing-on-tormach-mills","children":[]},{"id":"ci_2e39a41b722c393f4dbdd80f6a8454e4726bd93d9a987936052781f8c558e8fb","title":"Machine Kinematics (Max Feed, Travel Limits, Accelerations)","path":"/770mx/machine-kinematics-max-feed-travel-limits-accelera","children":[]},{"id":"ci_4fcefd519a27b3e5103c9a8231939c44f95e1c13d3a085907336febc708e7b63","title":"770M/MX Torque Curves (MX - MF/MH Serials)","path":"/770mx/770m-mx-torque-curves","children":[]}]},{"id":"ci_175b0e9e2a9493d82ffb3497d1973da86df6243ca06d90fc5e017c1133f274e6","title":"Site Requirements","path":"/770mx/site-requirements","children":[]}]},{"id":"ci_2291932d209647d1e96748e4be6f8b4b27613dbf133de5bf985a421120820460","title":"Installation","path":"/770mx/installation","children":[{"id":"ci_d0ba45d3ba045df618f9670a82f6a603e1f0657bb7641636afcf03e8689e3ec2","title":"Before You Begin","path":"/770mx/before-you-begin","children":[]},{"id":"ci_e631bf02dd1202c6565b9da5a9256c26045be6d40a99f4f89b82744f88f6aff9","title":"Assemble the Machine Stand","path":"/770mx/assemble-the-machine-stand","children":[]},{"id":"ci_7214bf2979b8525dc142a72534e359ba886ef5802647d89d3a28227ec111b78a","title":"Unpack and Mount the Machine","path":"/770mx/unpack-and-mount-the-machine","children":[]},{"id":"ci_3dc0949b52a8b7d9f5e6cb597cb16c9cf7c21ee7edb079068d93332ffba99fca","title":"PathPilot Controller","path":"/770mx/pathpilot-controller","children":[]},{"id":"ci_665d1092174a65f9b78908431727d71c34bdd2dbf247f69284ac31de45c3f734","title":"Manual Oiler","path":"/770mx/manual-oiler","children":[]},{"id":"ci_2f6b6732e5e348c9ea6e42f9a98ea59528ed8756f50abd82354e7ff6df1fee1a","title":"Filter-Regulator-Lubricator (FRL)","path":"/770mx/filter-regulator-lubricator-frl","children":[]},{"id":"ci_150ba061e7de6cee0f734ac9f89fc782a0d18212fe7a8b8de43fef683f767a23","title":"Set Up the PathPilot Controller","path":"/770mx/set-up-the-pathpilot-controller","children":[]},{"id":"ci_e11e90a5b36e8fcc060a5af0381895d938353d1307dfabd5c0e2bca6606b33ab","title":"Verify the Installation","path":"/770mx/verify-the-installation","children":[]},{"id":"ci_a7f9a5f3c4a89d379a32c4cb0d17723094bd6b7cc4516269130f580347a2e33c","title":"Leveling and Squaring Your Mill","path":"/770mx/leveling-and-squaring-your-mill","children":[]},{"id":"ci_64687051ab1623f4e1b97365707815f21903511e983931d40074db17be8d03b9","title":"Chip Pans","path":"/770mx/chip-pans","children":[]},{"id":"ci_12daf2847f18562ed65824ea20f7dcd1e8f0d16894d972c6ec0bd663095b7390","title":"Enclosure","path":"/770mx/enclosure","children":[]},{"id":"ci_c33036c2767bc1296ce9f2ab87396828203c268079d174f94cbb4afe99a139eb","title":"Accessory Installation","path":"/770mx/accessory-installation","children":[{"id":"ci_00ddd611594065d8aded32e12e22d1f4a65e0a9bb6f25ca78595964077e648b3","title":"ATC","path":"/770mx/atc","children":[{"id":"ci_72aa3c346c8f24c115fb6ab05b7c24d19a750a860c91227acabe981a5b63169c","title":"ATC Installation Manual - 770MX","path":"/770mx/atc-installation-manual","children":[]},{"id":"ci_79880294a51480bbfcafa65f014f97634754ecb62aa50c3a645a9575ff5f0b36","title":"Tool Change Scenarios","path":"/770mx/tool-change-scenarios","children":[]},{"id":"ci_b5550e937c25e6d9b1746bfbafe40526bff61acb7fa0f4ee89302257da297015","title":"V2.X ATC Board Kit for M/MX ATC's","path":"/770mx/v2-x-atc-board-kit-for-m-mx-atcs","children":[]}]},{"id":"ci_48119bd34772ffb59c513c2d724c7fe7f7257afd1cfc1577af5a3fdda821e6de","title":"microARC 4","path":"/770mx/microarc-4","children":[{"id":"ci_dbdaba5ebf27dd112e29a429723ffa76e88b16cc4c8f29a820cd009171fa2445","title":"microARC 4 Installation Manual","path":"/770mx/microarc-4-installation-manual","children":[]},{"id":"ci_cbe2598c12c8510e15a6ba8a9b2f99024b9e3181b735153ecc1116323f331a5e","title":"Simultaneous 4 Axis Machining in Fusion 360 with the Tormach microARC 4!","path":"/770mx/simultaneous-4-axis-machining-in-fusion-360-with-t","children":[]},{"id":"ci_e11a60b465a19b4e6df30a5cbd4c79b9665c23421c9cf377b42f098f4ff2ec05","title":"Machining a Turbine Disk on Tormach 1100MX + 4th Axis microARC","path":"/770mx/machining-a-turbine-disk-on-tormach-1100mx-4th-axi","children":[]},{"id":"ci_ab7b981b757bf9d4b5fee641e3c7567ef1cc806c8412a4cccf3c3a27d79c0ade","title":"4th Axis CNC Milling Non-Cylindrical Parts Using Rotary Toolpath in Fusion 360","path":"/770mx/4th-axis-cnc-milling-non-cylindrical-parts-using-r","children":[]}]},{"id":"ci_9ab3bfcf218b599e8dce096aeadb90c10f351b0a215dac766c8d948d1aebc038","title":"6 and 8 in. 4th Axis","path":"/770mx/6-and-8-in-4th-axis","children":[{"id":"ci_dbd0098f35b16e50dd27e7af31f43d8e03178a17966dc7248b4b18c324816245","title":"4th Axis Installation Manual","path":"/770mx/4th-axis-installation-manual","children":[]},{"id":"ci_8bf486a7a6ae17cdcd1072cc7b2aae9245ca8f3ef6ccb701a34fa27443ebea37","title":"How to Setup a 4th Axis: 4-Jaw Chuck","path":"/770mx/how-to-setup-a-4th-axis-4-jaw-chuck","children":[]},{"id":"ci_53269e00db3c3a241f9848e534b272d2c035a70f471b1f333a80eaf359e79c26","title":"How to Setup a 4th Axis","path":"/770mx/how-to-setup-a-4th-axis","children":[]}]},{"id":"ci_f6e4fdef2b62130627e9ddf1022743ba8a96a49d27518418aee72c8ce5284ee1","title":"RapidTurn","path":"/770mx/rapidturn","children":[{"id":"ci_88a634477135018786253fc22c2a39e74b8a8dce54d52891a25d8158c5f6fa99","title":"RapidTurn Installation","path":"/770mx/rapidturn-installation","children":[]},{"id":"ci_2896aef5d0486ce18bbd244090cea56a20a655ea066f03390c7bb720fb614ed0","title":"CNC Machining a Chess Rook With A Tormach RapidTurn","path":"/770mx/cnc-machining-a-chess-rook-with-a-tormach-rapidtur","children":[]}]},{"id":"ci_c69ba43d2d1f099156ded71f5c84dd0e6f9b36021aa7bf1dfc01412c91dee1b6","title":"Operator Console","path":"/770mx/operator-console","children":[{"id":"ci_e837f958012a62dd34b169565c92a0f64926883ff1192fe885a40f0675b75c98","title":"Operator Console Installation Video - 770MX","path":"/770mx/operator-console-installation-video-770mx","children":[]},{"id":"ci_c12e5da61df368f62d1519399d8de241da15c10f1c314cd85cf686134317451a","title":"Operator Console Installation Manual - 770MX","path":"/770mx/operator-console-installation-manual-770mx","children":[]}]},{"id":"ci_6ea5490004b879992d2a9d24a993e52474b6ed9f85fb421be04eb802850206f1","title":"SmartCool","path":"/770mx/smartcool","children":[{"id":"ci_bfd329c8331345fa443353c84f5a4226517d2b4a89d0af8528cb2b0f39570e63","title":"SmartCool Installation Manual","path":"/770mx/smartcool-installation-manual","children":[]}]},{"id":"ci_4eec2d3ee985c7e8717011367236d12bc6e1ce874b94d5555eb4624150f9499b","title":"Fogbuster","path":"/770mx/fogbuster","children":[]},{"id":"ci_c0d252e8702d07adb35028269a69d1d09e2fb03c46af393aa0092d4478bcaec6","title":"USB I/O","path":"/770mx/usb-i-o","children":[]},{"id":"ci_04883c77e60256d54e0dd7e34f6363ae4079a2467384fa9facbb0b33ff8b2b6f","title":"Flood Coolant","path":"/770mx/flood-coolant","children":[{"id":"ci_da44d4bc66ff124c5ae7288b4bd389a61bb27cb17a832a47256d66924312105d","title":"Flood Coolant Kit","path":"/770mx/flood-coolant-kit","children":[]}]},{"id":"ci_65585174a75a84a78ac96ed316a5c19d6d5bf9a721f67a93720169f45ba779dc","title":"Door Lock Switch Kit - 770M/MX","path":"/770mx/door-lock-switch-kit","children":[]},{"id":"ci_5e1837088fa21a61c06941ade50f4b5e5f7266651b0c68d43678f25216d7305a","title":"Automatic Oiler","path":"/770mx/automatic-oiler","children":[]},{"id":"ci_6fbff4edf1bd54a3777bf443a53f5a640c0429fef79ae86c6b081904118c2fbc","title":"Touch Screen","path":"/770mx/touch-screen","children":[{"id":"ci_df3e42ecaa9dd1a3b0942fde1d838cc64c98ef3f6b834f9a2e032f4fd2cf7556","title":"Touch Screen Installation Video","path":"/770mx/touch-screen-installation-video","children":[]},{"id":"ci_ef8d8017c8217272f97325964dadf8d815bd5b86f94c7512d6c113de065234d0","title":"Touch Screen Kit Installation Manual","path":"/770mx/touch-screen-kit-installation-manual","children":[]}]},{"id":"ci_d0509ede93ebe967675255b87e04ddaa8923608160746b8e64392c2fe2b79d9e","title":"Vise","path":"/770mx/vise","children":[{"id":"ci_25405ffab40dbaa44e98321c89d30c927e8e444772835a43c635a5c841fd2440","title":"Basic Steps to Square a Vise","path":"/770mx/basic-steps-to-square-a-vise","children":[]}]},{"id":"ci_adce6e9df0ffb252dfc495d502630e7e653fdf630ebf6852c48728023d1d01f3","title":"ETS - Electronic Tool Setter","path":"/770mx/ets-electronic-tool-setter","children":[]},{"id":"ci_0504539cf4ff8e6a01decc01db39d023aa4bddbe9ffff7d0e2bf4e5af877d815","title":"Power Drawbar Foot Pedal","path":"/770mx/power-drawbar-foot-pedal","children":[]},{"id":"ci_63ac9c58a7b09632211272f3b436c9bc077ce8ecc0b0b9a42a2b9f377dbb1bdd","title":"Lube Cube Coolant Kit","path":"/770mx/lube-cube-coolant-kit","children":[]}]}]},{"id":"ci_bc2f49088343ffd290f18f8d3f0eb96ca275c76ffc60fd23ba12b8ecd66079c2","title":"Maintenance","path":"/770mx/maintenance","children":[{"id":"ci_0fb009ead304c0a59791ddf37cf7605a022dc1c0410e9758a43f99dcbfbf02eb","title":"Machine Maintenance","path":"/770mx/machine-maintenance","children":[{"id":"ci_a5bdd94a121729c038ab8701dae6d0c3f70b23d67c963f23a4329d5850ac346b","title":"770MX Maintenance","path":"/770mx/770mx-maintenance","children":[]},{"id":"ci_8eb9c16d7caada7baa58216ab42659333783f2dbe8e6b76c9676860e1832324d","title":"Machine Paint Color Codes","path":"/770mx/machine-paint-color-codes","children":[]}]},{"id":"ci_09f0a3812338c6e41d9351e362b5a2d86ea3aa1807897f6c93cf5d544a6a2643","title":"Accessory Maintenance","path":"/770mx/accessory-maintenance","children":[{"id":"ci_50f7a3a4dbbc92c0dc3b66b435b80391aed7a384742e074ca2ec9849b2d01e90","title":"ATC Maintenance","path":"/770mx/atc-maintenance","children":[{"id":"ci_7eb1a7627b7be41ed625d5c0c0935c0faf60e4b695a71fb6383c2fa2f0724669","title":"General Tips and Maintenance for the Automatic Tool Changer (ATC)","path":"/770mx/general-tips-and-maintenance-for-the-automatic-too","children":[]}]},{"id":"ci_32ee740588643cbde2c066faa18a85dbd8af4022133763ddeff3cbdc8360c9a4","title":"6 and 8 in. 4th Axis Maintenance","path":"/770mx/6-and-8-in-4th-axis-maintenance","children":[{"id":"ci_b744b5423f3c2d7413100c97221b5300fc20dd2e8071338a114e9b59fe7edb68","title":"Rotary Table Milling Machine Maintenance","path":"/770mx/rotary-table-milling-machine-maintenance","children":[]}]},{"id":"ci_d9b28f8b3261245ed7f9b43b80940df4d591c874b4be3665d579255c967b5d7d","title":"microARC 4 Maintenance","path":"/770mx/microarc-4-maintenance","children":[{"id":"ci_240f970fff9c602f66f214d3da670e12e63df8de06beddf6100a19515c467022","title":"microARC Maintenance","path":"/770mx/microarc-maintenance","children":[]}]},{"id":"ci_c7e277ab99c102c03038f819526bc076671a586aee0fdddafec6b55bfd50c948","title":"Flood Coolant Maintenance","path":"/770mx/flood-coolant-maintenance","children":[{"id":"ci_576e7a7053006d7f0038c5520b50d84d7421530d747da72e823fb83a61166b44","title":"Tormach Oil Skimmer - Easy Coolant Tank Maintenance","path":"/770mx/tormach-oil-skimmer-easy-coolant-tank-maintenance","children":[]},{"id":"ci_a5c7b23b925a01f0cbe13a41e08b31d058e7e2fdead47dc6385e50bb72e8b0d8","title":"Replacement Mesh for Chip Basket Screen","path":"/770mx/replacement-mesh-for-chip-basket-screen","children":[]}]}]}]},{"id":"ci_213b2b0396fb2a6d440254bd6c34278d73b5aad1f7629672e849f9332964b452","title":"Operation and Programming","path":"/770mx/operation-and-programming","children":[{"id":"ci_00b945bb118ccccf70f65cb6fb6942c2f009094cf16838f6860de3b3ca3fd3c0","title":"Machine Operation","path":"/770mx/machine-operation","children":[{"id":"ci_f07e8f3d9a0216be02b7711211cc03cd917390c05fbc5d240a8e259750780302","title":"System Basics - 770MX","path":"/770mx/system-basics-770mx","children":[]},{"id":"ci_ef610bb6ecd80ef077360a0d1896a476d5d8ddf60870387b584f0b6ba48531af","title":"PathPilot Interface Overview - 770MX","path":"/770mx/pathpilot-interface-overview-770mx","children":[]},{"id":"ci_4e18a025cdd556fbe5ca071711490a300e8bc9ce75f09a405b8711e2704e7654","title":"PathPilot Tools and Features - 770MX","path":"/770mx/pathpilot-tools-and-features-770mx","children":[]},{"id":"ci_2e57e14cbf7520afd62eb32aa96490ddd9e688d759a150397a72c30b58ed4083","title":"Basic Operations - 770MX","path":"/770mx/basic-operations-770mx","children":[]},{"id":"ci_508fee5eda3e8ff6d8a9dc623dbdf7b9340a2cf11f595ba536742c7f6d0ed134","title":"Setting Start Line in the Middle of Program","path":"/770mx/setting-start-line-in-the-middle-of-program","children":[]},{"id":"ci_ee15dc7314a0ac1851a14a3a06d5c763baac5c60584671bf4a020bee8c5a55bc","title":"Windows 10 Network Setup and G-Code Share","path":"/770mx/windows-10-network-setup-and-g-code-share","children":[]},{"id":"ci_68709667ae3e6def9c9a19bbf67afdf3c05265be92144bd47752aba33cf39b80","title":"PathPilot Settings Backup","path":"/770mx/pathpilot-settings-backup","children":[]},{"id":"ci_1d4cdcd044ccbe5033344dc4d683add79e2a79350f7232e74e873a19cf0feae3","title":"PathPilot Spindle Warm Up Program","path":"/770mx/pathpilot-spindle-warm-up-program","children":[]},{"id":"ci_320fb5a05f6c4cd2801a16eda38b2b1781b39aa75cee41ef7912099ddb90a0f7","title":"Setting Up WiFi and Software Updates","path":"/770mx/setting-up-wifi-and-software-updates","children":[]},{"id":"ci_77e179399e4a89214e4179d34c4d0037422e21f2b5a9d9b2932b7e814c6cc218","title":"On-the-Fly Math for Feed Rates","path":"/770mx/on-the-fly-math-for-feed-rates","children":[]},{"id":"ci_57c9daa6d241cfa2f1fc7efa4c82a794beb19148fca4f308f90f47e82a718de3","title":"Finding G-Code from the MDI Line","path":"/770mx/finding-g-code-from-the-mdi-line","children":[]},{"id":"ci_bed31344a30ccf37befa970a8cbf8a49e848225c24bcd45cbe5d820e68242043","title":"Creeping Up on a Part","path":"/770mx/creeping-up-on-a-part","children":[]},{"id":"ci_15ec99775035d33782eb949ee5c58d64215c9719a27e30616e0a964de27ac915","title":"Cutting Your First Part on a Tormach Mill","path":"/770mx/cutting-your-first-part-on-a-tormach-mill","children":[]},{"id":"ci_c27b49802bbe879b891e7ea398184d4eaefa07b6f6959b4a82fd554b152c4a42","title":"Your First Day with Tormach's PathPilot","path":"/770mx/your-first-day-with-tormach-s-pathpilot","children":[]},{"id":"ci_bfa1e0fc9a41bcb401a7f16ea5d71d2d39be83e067e7e7820a16c6b63a9f7bd0","title":"Generating a Log Data File in PathPilot","path":"/770mx/generating-a-log-data-file-in-pathpilot","children":[]},{"id":"ci_bd30320caff435d9059250324c9fc34877dbb85bc37456d26ed4fb3379d0fd74","title":"How to Cut Holes with CNC","path":"/770mx/how-to-cut-holes-with-cnc","children":[]},{"id":"ci_079cb77f164ea5c333820d0acb4e1f1fb5376fb8e2eb30b5090dc71ee8e418af","title":"Changing Machine Configuration","path":"/770mx/changing-machine-configuration","children":[]},{"id":"ci_570fba332b68adc0ea260f67dce9918e0428dccf7199860b94f117d5b15f79d8","title":"Setting G30","path":"/770mx/setting-g30","children":[]},{"id":"ci_9e408e8e7ed2ab8ff80c6cd1418ba375618851c2a5d813a5a5e0116ccfdc2b5a","title":"Tormach Probing Routines","path":"/770mx/probing-routines-in-pathpilot","children":[]},{"id":"ci_54b5ef5959c5ccf45c6735da64b720fe74e3c3145208d161f23f8a427d8eea92","title":"Setting Up Work and Tool Offsets On Tormach Mills","path":"/770mx/setting-up-work-and-tool-offsets-on-tormach-mills","children":[]},{"id":"ci_8e683d6b23737cf78e7429d8f94636d6102daefc8365cfa1a4878519d3d28499","title":"Tweaking Your Work Offsets","path":"/770mx/tweaking-your-work-offsets","children":[]},{"id":"ci_5c88ab3525784c41295958cd96699ac44bbb1dcc9fbcb0dbf1f4be804cd57507","title":"Probe & ETS Setup","path":"/770mx/probe-ets-setup","children":[]}]},{"id":"ci_566b5751f03edc84fe8cc27b9a6e13900e511da5fe94259e281809f29070c060","title":"PathPilot Programming","path":"/770mx/pathpilot-programming","children":[{"id":"ci_2723f7dce25745496f4c688cd9b887976db198ebe8eb5c0f62fbaa078738839a","title":"Programming - 770MX","path":"/770mx/programming-770mx","children":[]},{"id":"ci_4585e6d87eb22235130f268802816a01441b598de14ed40ec7f9af1491fbde1d","title":"G28 Command","path":"/770mx/g28-command","children":[]},{"id":"ci_bdb2e52e8c7fa23eaca949860cff4068ce44275077d2b92a5439c01573ff1113","title":"Work Coordinate Rotation with G10 L2 in PathPilot","path":"/770mx/work-coordinate-rotation-with-g10-l2-in-pathpilot","children":[]},{"id":"ci_8c16ec542c12f9589cac4b1041ba5435307ef83f004ec3ff458f067e4674cef5","title":"CAM Driven Probing","path":"/770mx/cam-driven-probing","children":[]},{"id":"ci_3235a0654658134a60e68c7de8a92fd13799aa0fb5e04144e4efdb7668c7710c","title":"G64/M59 Guide","path":"/770mx/g64-m59-guide","children":[]},{"id":"ci_479dd802925a915bd4cd88dd63805a668069e16608738a57846beb46cc0e07ac","title":"Macro Programming","path":"/770mx/macro-programming","children":[]},{"id":"ci_ef954a5a989d9d6bbeab1ac61714dfa0c5a73a304ad74dc5c9a3df9232506d5e","title":"PathPilot Post Processor Guidelines","path":"/770mx/pathpilot-post-processor-guidelines","children":[]},{"id":"ci_834581f1ba3af82463ac90b69acf0448e3fa767614d45ca24aa66cbc1f9f4ddf","title":"Conversational Drill and Tap","path":"/770mx/conversational-drill-and-tap","children":[]},{"id":"ci_aa2e3f0fb31fa630dce28b03417db78a38e0f4e01abf5762cbd0f2383cfe8c79","title":"Conversational Programming in Tormach's PathPilot","path":"/770mx/conversational-programming-in-tormach-s-pathpilot","children":[]}]}]},{"id":"ci_3e74673e1ba702ff57554f6ce18876eabb28322f003db7ed2cea1122ca62d4e3","title":"Troubleshooting","path":"/770mx/troubleshooting","children":[{"id":"ci_78326d362d1d5b4d926f46cc9244fb800238bed1bb77eade2f3579e4a2bc598a","title":"Spindle Troubleshooting","path":"/770mx/spindle-troubleshooting","children":[{"id":"ci_dcd2bd11d5de48998a8c48f271ef8b57e2f0092b289a82d998c105060da4fbaf","title":"Spindle Tram Adjustment","path":"/770mx/spindle-tram-adjustment","children":[]},{"id":"ci_01423d9524043c209ebd0d15cd0f69496ce538eb2f9f929acb9fbe3284e4194f","title":"Changing Spindle Belt Range","path":"/770mx/changing-spindle-belt-range","children":[]},{"id":"ci_34de1b3308254a3ffb98ebb283143555402e2895c72cb56b405e88a9c00cc84b","title":"Spindle Won't Turn","path":"/770mx/770mx-spindle-won-t-turn","children":[]},{"id":"ci_ff576e539d2557e854b6e324f8a9210b9f64b24839e79503bb03332f90774e6f","title":"Spindle Orient or at Speed Fails","path":"/770mx/spindle-orient-or-at-speed-fails","children":[]},{"id":"ci_f7278ed878e427ecaa66bd08a63cab5a258f27521cc445fe729bb29e99e92144","title":"Chatter","path":"/770mx/chatter","children":[]}]},{"id":"ci_127f71dd60562e262ad28cbf15d4c49e33d634f164078f31f00050e7b20f8819","title":"ATC Troubleshooting","path":"/770mx/atc-troubleshooting","children":[{"id":"ci_8bc69bf46c912e512b5486b088153abd1dacd9b61d7d293bd6814a9abf89c60c","title":"Device Homing Error","path":"/770mx/device-homing-error","children":[]},{"id":"ci_fb63868ed0398a30abe87434e43809a5c0ce1a3b601f9e617264f50513dd5265","title":"Tray-In Sensor Fault","path":"/770mx/tray-in-sensor-fault","children":[]},{"id":"ci_4e17d1087fe390d0adbe963e2e6b96e2d986a38ec2fdd6ae6549e102ba159794","title":"Low Air Pressure or Malfunctioning Air Pressure Switch","path":"/770mx/low-air-pressure-or-malfunctioning-air-pressure-sw","children":[]},{"id":"ci_c3ab7032009823a1d89d39a86acd8f9c2e9d1bfe2436fb33a9634eaec024e71c","title":"BT30 Drawbar Adjustments for Better Tooling Removal","path":"/770mx/bt30-drawbar-adjustments-for-better-tooling-remova","children":[]},{"id":"ci_96d7ebc98f02bad727f4a77be86f54b41768ed55a36727acd21ca3a2b11a6f56","title":"Manual Tool Change with Dead ATC Board - 770MX","path":"/770mx/manual-tool-change-with-dead-atc-board","children":[]},{"id":"ci_119e49287443d9717720f84db6144e2d949efc07aebe7135fe6be56a541c5351","title":"Pneumatic Seal Replacement for Leaking Drawbars","path":"/770mx/pneumatic-seal-replacement-for-leaking-drawbars","children":[]},{"id":"ci_7fd8ee6d83805dc6ed320733c39ce1af6537e13a71f171a7f204197cc519a084","title":"Check Fuses and Cabling Error","path":"/770mx/check-fuses-and-cabling-error","children":[]},{"id":"ci_fe34140d0e60b185db596f6dbd654ba7f16766b43f2c48ef352d55c1b243ea97","title":"Getting Out of an ATC Jam","path":"/770mx/getting-out-of-an-atc-jam","children":[]},{"id":"ci_2f70e2054184904878861b7989cfb56d8ef76759b5dbcc29c44ec7914c6a4e57","title":"Tool Ejection Before Tray Pickup","path":"/770mx/tool-ejection-before-tray-pickup","children":[]}]},{"id":"ci_65b3c67d9914da1958ec4072adf1d3a376dcd656bd0d77c5fa1956fe79bab153","title":"Controller and Console Troubleshooting","path":"/770mx/controller-and-console-troubleshooting","children":[{"id":"ci_8d2c8727a13fb174c9aa0bcedbe95065f260f5c31ebaa724ae965bfe5bd49b6d","title":"Controller Won't Power On - 770MX","path":"/770mx/controller-wont-power-on","children":[]},{"id":"ci_aeed20e8d856203d284fe0327f276d32cc45a4290b5995f5be8dab5f3cddac74","title":"Controller Monitor (Standard and Touch Screen) Doesn't Work","path":"/770mx/controller-monitor-standard-and-touch-screen-doesn","children":[]},{"id":"ci_1366e93d730719e2922a03fcee139dc6e6345216d8ca0ff17b344c7bcbc17c33","title":"Operator Console Troubleshooting","path":"/770mx/operator-console-wont-power-up","children":[]},{"id":"ci_f83b3c145c21b744b5083463fb85f565add3b7b56155d0c4a2e5020b7855b2fa","title":"Machine Interface Error Troubleshooting - 770MX","path":"/770mx/machine-interface-error-troubleshooting-770mx","children":[]},{"id":"ci_440f5035d0ba5d18ce270bfcc63f763c6f59377f705680a7e3715fe01184d9d8","title":"Restore PathPilot to Factory Settings","path":"/770mx/restore-pathpilot-to-factory-settings","children":[]},{"id":"ci_78960dcab963c9a8e847ae8ea468444ad4c0f2bcb28783ac6985156a7a339070","title":"PathPilot Controller CMOS Battery Replacement","path":"/770mx/pathpilot-controller-cmos-battery-replacement","children":[]}]},{"id":"ci_36bbe27c22fb1fa639fee14f43b156d1a0e6126e1aaf3c6e796e375f819087ab","title":"Motion System Troubleshooting","path":"/770mx/motion-system-troubleshooting","children":[{"id":"ci_f983710707c37ec7a73c8078fd5d0d67a1bc842dd62dcbfa28ae26ccc274f531","title":"Mill Gib/AC Bearing Adjustment and Backlash Compensation - 770MX","path":"/770mx/mill-gib-ac-bearing-adjustment-and-backlash-compen","children":[]},{"id":"ci_2b95ca5a63de61fe1e9e5c9cd6d1f64a4788bc1aa53f0dbca702abb8dd2060ae","title":"Ballscrew Replacement","path":"/770mx/ballscrew-replacement","children":[]},{"id":"ci_ffcac221ccad885b9f0976b3e4876568e089c3ba5fb314b4ccc31fa1f8b1bf50","title":"Lost Motion Testing - 770MX","path":"/770mx/lost-motion-testing","children":[]},{"id":"ci_8f6d6dcfe710d872990c59a2352cd6889a885822a9217bb858d7b7276807daae","title":"All Axes Won't Move When Commanded - 770MX","path":"/770mx/all-axes-won-t-move-when-commanded","children":[]},{"id":"ci_17f7aa6319e7dd300aaee2fc8b1c62600346edaa17fcbba023f20a04be608772","title":"One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - 770MX","path":"/770mx/one-axis-won-t-move-or-only-moves-in-one-direction","children":[]},{"id":"ci_ced0dda517f47138c2fbb68b4dfe764b04507691172f38844713d8a4c23abf67","title":"Axis Movement is Noisy - 770MX","path":"/770mx/axis-movement-is-noisy","children":[]}]},{"id":"ci_a9553b6f7c3e1f621e2064a6e14491b8770a82af130ff62693448d2de7ef675c","title":"General Electrical Troubleshooting","path":"/770mx/general-electrical-troubleshooting","children":[{"id":"ci_d85fa8b25611e43826104f3b9892153094b89116c82f1c97af69f188397a7c9c","title":"Checking a Fuse on a Tormach Machine","path":"/770mx/checking-a-fuse-on-a-tormach-machine","children":[]},{"id":"ci_6ed8950c261543a9f1e5e4a58cb201144af4b891f797f770bd17bf26edcbf093","title":"Machine Won't Power On - 770MX","path":"/770mx/machine-won-t-power-on","children":[]},{"id":"ci_e9c4070ada2828c3629a36053c430cfb7f4030f49a22958ce57990863eb3f5b1","title":"DIN Port Jumper Test","path":"/770mx/din-port-jumper-test","children":[]}]},{"id":"ci_b6703903d649ca4356de37e1e490b32751ac048a2dd45d22a16a16222ba9a2b5","title":"Accessory Troubleshooting","path":"/770mx/accessory-troubleshooting","children":[{"id":"ci_46dac605296d3266db4a6cd252128fe23e968c2657cc7fc4073188e18650d8af","title":"Automatic Oiler Troubleshooting","path":"/770mx/automatic-oiler-troubleshooting","children":[{"id":"ci_666c025a2c6ee409d8e48220d28e21923bb218372dcfba12d84952f65789ad42","title":"Unlock and Reprogram Auto Oiler","path":"/770mx/auto-oiler-interval-counting-down-in-seconds-not-m","children":[]}]},{"id":"ci_718a72c5a064b272decdd599ecbef0d4ee9014dcaa96e27ded85d18e41303c66","title":"RapidTurn Troubleshooting","path":"/770mx/rapidturn-troubleshooting","children":[{"id":"ci_fa6f7ec1d6b9b43722e77aa40320206f9d21bf13687a2f857920697f650aadc8","title":"RapidTurn Motor Spinning the Wrong Direction","path":"/770mx/rapidturn-motor-spinning-the-wrong-direction","children":[]},{"id":"ci_bad3ec53688239d20d5939c260cbf53f70d80d5a062825553df0434108113981","title":"RapidTurn Speed Sensor Adjustment","path":"/770mx/rapidturn-speed-sensor-adjustment","children":[]}]},{"id":"ci_65fcf9c304e6843dab60cecc55f874ec26a4429913c67aecc239caa10a76b888","title":"Flood Coolant Troubleshooting","path":"/770mx/flood-coolant-troubleshooting","children":[{"id":"ci_8ab1ffb1dff816cd1e793196b6686d079c40440fc1351d8474942b67aba7627e","title":"Coolant Pump Won't Run","path":"/770mx/coolant-pump-won-t-run","children":[]}]},{"id":"ci_b1bcba45ed65973e3b1a0eb655dd2dc4d30f87fe88b488bac6345c0b3cff2c0c","title":"4th Axis Troubleshooting","path":"/770mx/4th-axis-troubleshooting","children":[{"id":"ci_1f7d83587037793f680517e3718b47c5320ae600e2f7f01a6288f6bbbd5b220e","title":"microARC 4 Repair","path":"/770mx/microarc-4-repair","children":[]},{"id":"ci_8c0b72ecc9d726f1655405f52bd8686653d9427ee51741f3f0c13d50c53c1098","title":"4th Axis Backlash Adjustment","path":"/770mx/4th-axis-backlash-adjustment","children":[]},{"id":"ci_ea59f14f654c92aebc8e0b6d51685c77fb5184aeceb09b255dda454c7491ba88","title":"4th Axis Pin Check","path":"/770mx/4th-axis-pin-check","children":[]}]}]}]},{"id":"ci_d9a724c470d4ba513f52cb1e8da305bc6c12741ae4e73379c6fbd89051758612","title":"Diagrams and Parts List","path":"/770mx/diagrams-and-parts-list","children":[{"id":"ci_4ddfdb86589ae3196714840e1ef8570143038d37023a46e2f6f83ca4958c977b","title":"Base Machine - 770MX","path":"/770mx/base-machine-770mx","children":[]},{"id":"ci_0156b9013072dec5fa776c323d791d2c96bcacda3650dd8db5b1ea51a0cc6106","title":"Spindle Cartridge - 770MX","path":"/770mx/spindle-cartridge-770mx","children":[]},{"id":"ci_416979a54745c0728ab18a00d395e27d63ac2534bda0c959dfc925560a9c75f1","title":"Spindle Head - 770MX","path":"/770mx/spindle-head-770mx","children":[]},{"id":"ci_34b3041528ee4a7e979a726b518a24c0f2451b2c14f623446eb343fc7004e04b","title":"BT30 Power Drawbar Cylinder - 770MX","path":"/770mx/bt30-power-drawbar-cylinder-770mx","children":[]},{"id":"ci_6f3c5b3ce746b47a1dd98f7da1d2fce4ea14ed82e3263f0c9d3d7a73793dde51","title":"Power Drawbar Push Button - 770MX","path":"/770mx/power-drawbar-push-button-770mx","children":[]},{"id":"ci_da787b26b960a8530c552821b9701883410c5c5896031216a4f37fe569eb714f","title":"Spindle Motor Cover - 770MX","path":"/770mx/spindle-motor-cover-770mx","children":[]},{"id":"ci_df5c617978d4328f011fd82e34e87a3b8bf3d962d0db83af04ad492c378bbf6f","title":"X-Axis Assembly - 770MX","path":"/770mx/x-axis-assembly-770mx","children":[]},{"id":"ci_d92a742ca48f1979d3ed7943f8100b61a52b176951dec95b84e5f017bcd5354d","title":"Y-Axis Assembly - 770MX","path":"/770mx/y-axis-assembly-770mx","children":[]},{"id":"ci_e8b4e24b3697ca4f5ba80b96c7195798dff6b82243cddbdec183d79c90e21616","title":"Y-Axis Saddle - 770MX","path":"/770mx/y-axis-saddle-770mx","children":[]},{"id":"ci_62f7f828c34b3482bf383c8c2363b18a7b89172d3a002372fd4a2903393c11da","title":"X-Y Axis Assembly - 770MX","path":"/770mx/x-y-axis-assembly-770mx","children":[]},{"id":"ci_50beff45cec8521da11577138a1257c4e8d458e6b92a2fb10d8e92d855432006","title":"Lubrication/Oil System - 770MX","path":"/770mx/lubrication-oil-system-770mx","children":[]}]},{"id":"ci_5bd83790dab7f5093a4a5795409d7183c66891401767d038017e0adc09176e07","title":"Pneumatic and Electrical Schematics","path":"/770mx/pneumatic-and-electrical-schematics","children":[{"id":"ci_d2c46acc6fdc62c75ab471aa029594056cfdda5b43fbb148bc421cfd27c84d39","title":"Power Drawbar Pneumatics - 770MX","path":"/770mx/power-drawbar-pneumatics-770mx","children":[]},{"id":"ci_d444f921c731cf5a88eb28d6016d46eb7423a21dc53cc0aa4a41baa0c745abf1","title":"Automatic Tool Change (ATC) Pneumatics - 770MX","path":"/770mx/automatic-tool-change-atc-pneumatics-770mx","children":[]},{"id":"ci_04a16068fdbe7aad9eba5561f4881cfb831238f407d0a56ba9638aa3c278448e","title":"115 VAC Power - 770MX","path":"/770mx/115-vac-power-770mx","children":[]},{"id":"ci_a6c9d378e9a02abe0a894ed99a59ad5d18f054333eb1b7ed1b3afb88516efa03","title":"24 VDC Controls - 770MX","path":"/770mx/24-vdc-controls-770mx","children":[]},{"id":"ci_ff2ef5458cec29849dc42efc948b33ca071fea87992bac546a5c31a0d17fd575","title":"Axis Drive Bus - 770MX","path":"/770mx/axis-drive-bus-770mx","children":[]},{"id":"ci_0b4ce810545ef2477d523d5f599bcd22228834ece4ae34b5d9f5b75b1e8c0fd5","title":"Spindle Drive - 770MX","path":"/770mx/spindle-drive-770mx","children":[]},{"id":"ci_52321c31f57341dc0cf09d58c68a6206b9100dd99694a935cd2dbee34c9d97fc","title":"Machine Control Board - 770MX","path":"/770mx/machine-control-board-770mx","children":[]},{"id":"ci_92135652e8e4abb3c58ac6df65975baedfe981eb9a4537faee2f9e0dc8d2f7ef","title":"Limit/Door Switches - 770MX","path":"/770mx/limit-door-switches-770mx","children":[]},{"id":"ci_344c65bbcd06c9163ef7701e67a9b3bde225613c03be9064c90bd71227c138e1","title":"Accessory and Auxiliary Power - 770MX","path":"/770mx/accessory-and-auxiliary-power-770mx","children":[]},{"id":"ci_3438b8517009681389b8f007170e6faa34c212b1c28c4b09467987f05179e04f","title":"Grounds - 770MX","path":"/770mx/grounds-770mx","children":[]},{"id":"ci_6820dc01f8779d15aa414e2cad89f72883b9a531169aa003fa1d933c8e215e10","title":"Electrical Panel Layout and Fuse Table - 770MX","path":"/770mx/electrical-panel-layout-and-fuse-table-770mx","children":[]},{"id":"ci_da84778380b8feadfe8ed211efbe79f4fdf2acf4d8d47bab4315e33980cff0c3","title":"Operator Box Layout - 770MX","path":"/770mx/operator-box-layout-770mx","children":[]},{"id":"ci_10d5c0cc93258aef736e6062e424e4c305424980b4c5ddf4e7c94d050048c182","title":"Wiring Table - 770MX","path":"/770mx/wiring-table-770mx","children":[]},{"id":"ci_02ca4aa9efe1837c476086620c61bb8b614472c622d8eabcb6f00bb08fc03a99","title":"Operator Console Schematic - 770MX","path":"/770mx/operator-console-schematic-770mx","children":[]}]}]
