[{"id":"ci_02fd735b8b2f8a3ef194fdc25c18471dfebea62b5dbd0817fdc837606a8b58c7","title":"About Your Machine","path":"/pcnc-440/about-your-machine","children":[{"id":"ci_eaa88c85296f2d0a5a6f5f68491015dfbd0900800b428c9be6a19415bff92d1d","title":"Safety","path":"/pcnc-440/safety","children":[]},{"id":"ci_f9e287683d16d1569545b546b992d396d3c5f1d87376179b054cff3f6801ae4d","title":"Machine Specifications","path":"/pcnc-440/machine-specifications","children":[{"id":"ci_fcc17b28e83b48798f309cd4d00a17b2d3f7ec6caf24d1da2576992f723bcf62","title":"T-Slot Spacing on Tormach Mills","path":"/pcnc-440/t-slot-spacing-on-tormach-mills","children":[]},{"id":"ci_be4f608d8922e6afabb669efd3abff68c878a79ba47ea6ec340c31e85d7fdc03","title":"PCNC 440 Torque Curves","path":"/pcnc-440/pcnc-440-torque-curves","children":[]},{"id":"ci_23427f2675a74241b574921fb446e2aba4a1addb265fc74ea8c881885949565b","title":"Machine Kinematics (Max Feed, Travel Limits, Accelerations)","path":"/pcnc-440/machine-kinematics-max-feed-travel-limits-accelera","children":[]}]},{"id":"ci_3ce1f4e6856121f8e7bf560c3743ee2653b1ee2c68f08b94da5666eabdee5e19","title":"Site Requirements","path":"/pcnc-440/site-requirements","children":[]}]},{"id":"ci_64a8d9d8e89af2e090891923ac924c011d4c313454144f7cae66d10f9e2f824b","title":"Installation","path":"/pcnc-440/installation","children":[{"id":"ci_2911b8c4c2cd733ab77c2bd69282175752c907d443eaf92a7c48f5e7f85ead44","title":"Before You Begin","path":"/pcnc-440/before-you-begin","children":[]},{"id":"ci_9bf4068b1192b007fb4cc098bacb11db910e53cfce4a16f333402d3da7cef323","title":"Unpack the Machine Crate and Mount the Machine","path":"/pcnc-440/unpack-the-machine-crate-and-mount-the-machine","children":[]},{"id":"ci_d47418488a9ce4536b605135d2b3e65085e21817df81b0e2e2896970db29f6bf","title":"Install the Monitor and the PathPilot Controller","path":"/pcnc-440/install-the-monitor-and-the-pathpilot-controller","children":[]},{"id":"ci_9058841e49d35fc4ea9969774027a447165a0a7d334e9c87de2556ca8b4548c7","title":"Set Up the PathPilot Controller","path":"/pcnc-440/set-up-the-pathpilot-controller","children":[]},{"id":"ci_12fb9b6aac4be199edf90fddc7165f82043a89ac1e919fa0cca7a700a3571713","title":"Verify the Installation","path":"/pcnc-440/verify-the-installation","children":[]},{"id":"ci_e0f9f35cf60ab4f57aa59895730517e19c432bb70d62d0f4f67984b8f2e2638a","title":"Leveling and Squaring Your Mill","path":"/pcnc-440/leveling-and-squaring-your-mill","children":[]},{"id":"ci_b18786d4534bdfd01271d8bd9cfdd5ed6a6867c27b360caffa348e76937e5afa","title":"Accessory Installation","path":"/pcnc-440/accessory-installation","children":[{"id":"ci_7b9da6ed1179a7b58ac66172d9d36e0dc0fdbf2159fc59a43be108622f64d866","title":"Machine Stand - PCNC 440","path":"/pcnc-440/machine-stand-pcnc-440","children":[]},{"id":"ci_98820543879eb56b72d701841c84b7cda05cb9aff34bc22fe8637937885903a9","title":"Enclosure - PCNC 440","path":"/pcnc-440/enclosure-pcnc-440","children":[]},{"id":"ci_5b6f5707ff1c21a8ba2ae62bb2b9752b119f2c41e4a5e9fab649a739a5978d04","title":"PCNC 440 Power Drawbar","path":"/pcnc-440/pcnc-440-power-drawbar","children":[{"id":"ci_2cfcea4844fce7a67aced1dd908b926764c71d2499ef08d7ca23b9dba5808863","title":"Power Drawbar Installation Manual - PCNC 440","path":"/pcnc-440/power-drawbar-installation-manual-pcnc-440","children":[]}]},{"id":"ci_8d1ffbfa150aa440715889dc71a60839d2e041ae70f019abd875242f989aca53","title":"Flood Coolant Kit - PCNC 440","path":"/pcnc-440/flood-coolant-kit-pcnc-440","children":[]},{"id":"ci_b42ac1560383a74d976b7e2a59d9e831c8e9a39dda49feceea6f5515d8f8fab9","title":"Door Switch Kit - PCNC 440","path":"/pcnc-440/door-switch-kit-pcnc-440","children":[]},{"id":"ci_1575c0fe71e2e739f1a582abf7e73382c7679506f58ba2a1f213d43fc314551e","title":"ATC","path":"/pcnc-440/atc","children":[{"id":"ci_e4d1ad66efc417f7e83424d5fe40970445a5abff63630d2fa426b490b08357da","title":"ATC Installation Manual - PCNC 440","path":"/pcnc-440/atc-installation-manual-pcnc-440","children":[]},{"id":"ci_e56cbca58d55d4525f2be0139bacf6d1f4d3b542c11e43619a8384ed6dac862e","title":"Tool Change Scenarios","path":"/pcnc-440/tool-change-scenarios","children":[]},{"id":"ci_3272923111da45052c0a32c8a7b9ba02c6016f2609fce8445e5b02e01d9d28c4","title":"ATC Installation Video","path":"/pcnc-440/atc-installation-video","children":[]},{"id":"ci_06c2b46c42effbabf908e8faa933387c00cbb32d08edf4161413b1d706253985","title":"V2.X ATC Control Board Kit for PCNC 440 Mills","path":"/pcnc-440/v2-x-atc-control-board-kit-for-pcnc-440-mills","children":[]}]},{"id":"ci_d8369760ea0481a63a14561cc149e56e73c689bd3a75984491c5c73d0861bc39","title":"microARC 4","path":"/pcnc-440/microarc-4","children":[{"id":"ci_6ae61321749a4721ee863177808227c3b1940cf82d7f20b421fa524f09abd256","title":"microARC 4 Installation Video","path":"/pcnc-440/microarc-4-installation-video","children":[]},{"id":"ci_827de2ac89735d12ada3946604ae5e59abcf1ac68944285449927643bd5c403e","title":"microARC Installation Manaual","path":"/pcnc-440/microarc-installation-manaual","children":[]},{"id":"ci_f9f0b6ec78c8b7862fc0e93691bceadea35bb316e94407038cc7bb318cbfdcc4","title":"Simultaneous 4 Axis Machining in Fusion 360 with the Tormach microARC 4!","path":"/pcnc-440/simultaneous-4-axis-machining-in-fusion-360-with-t","children":[]},{"id":"ci_b928138befa9df01da42720524737f4d9b690c88bd59e73e5f5401ce63856478","title":"Machining a Turbine Disk on Tormach 1100MX + 4th Axis microARC","path":"/pcnc-440/machining-a-turbine-disk-on-tormach-1100mx-4th-axi","children":[]}]},{"id":"ci_05b6081a6d60a2a2610df291807ccb518a3e7c6118712d5f1f184c6e6d2e81ff","title":"SmartCool","path":"/pcnc-440/smartcool","children":[{"id":"ci_1d42adb5bea6ce01006ed778ff010ddb798ecb31f3f22c591253f73093099c17","title":"SmartCool Installation Manual","path":"/pcnc-440/smartcool-installation-manual","children":[]}]},{"id":"ci_c9b9c73ba3d09cc980be1daf04413de2da0f29e3b452dca65e047304798ba525","title":"FogBuster","path":"/pcnc-440/fogbuster","children":[]},{"id":"ci_5aeb1220c3e4ba8e4db41a14fa2d0093b9ffe2890a5129039c50a9b3d50d1bd8","title":"USB I/O","path":"/pcnc-440/usb-i-o","children":[]},{"id":"ci_a39a697a167e261014f60f728f080412cf499b22a6ee2dda902fe1cace67798e","title":"Touch Screen","path":"/pcnc-440/touch-screen","children":[{"id":"ci_47660f0b7b18d33241320d72a3d0a6d5f10c7668f5be09e0c9de065cd51bc2b8","title":"Touch Screen Installation Manual","path":"/pcnc-440/touch-screen-installation-manual","children":[]},{"id":"ci_f1f60609c9a972770fda2da80177decada33b61f545d199f21aeb8e577a7e197","title":"Touch Screen Installation Video","path":"/pcnc-440/touch-screen-installation-video","children":[]}]},{"id":"ci_5116f1397e26cce54ab7276f3640c63f1fd35b2d05c3afd6982d411826e32533","title":"Vise","path":"/pcnc-440/vise","children":[{"id":"ci_bcc8dc69b3939062287834557e9a0a23811e845009852c2c3bdf5351368d2bd8","title":"Basic Steps to Square a Vise","path":"/pcnc-440/basic-steps-to-square-a-vise","children":[]}]},{"id":"ci_6a03333fb8c9ee0a53f3846a91aa5e156021197e0b8d3346518a7fc33778154f","title":"Power Drawbar Foot Pedal","path":"/pcnc-440/power-drawbar-foot-pedal","children":[]},{"id":"ci_68e0bd2098adc1dde9d693f309700e94dc6de15a919e75751d624a7e09aa088e","title":"Lube Cube Coolant Kit","path":"/pcnc-440/lube-cube-coolant-kit","children":[]}]}]},{"id":"ci_d4d2f58959b94213d595f867a0cc016c2fa53941d1921bdadb60d44d9605974f","title":"Maintenance","path":"/pcnc-440/maintenance","children":[{"id":"ci_d26c6bce59e1880611f83f30d9ffe5df081a2de6c6eb8664e866d0cff4eff008","title":"Machine Maintenance","path":"/pcnc-440/machine-maintenance","children":[{"id":"ci_20497c2590d770de1bb52fbc081a0e5c52b60dec22df5c14fc514c6f6ae12342","title":"PCNC 440 Maintenance","path":"/pcnc-440/pcnc-440-maintenance","children":[]},{"id":"ci_7ee4958c3453b94c8c2e014a085831b47183ab89ce7cf98053c9de86a11f343e","title":"Machine Paint Color Codes","path":"/pcnc-440/machine-paint-color-codes","children":[]},{"id":"ci_71f41dfb905d4563512fbb15da2e72f6be17ac2075559876ccb31b923bf77563","title":"PCNC Oil Line Flush","path":"/pcnc-440/pcnc-oil-line-flush","children":[]}]},{"id":"ci_782c65de8d792b59d7588600b6c1a69606173432890c3a5fa2dbb22cacce5af3","title":"Accessory Maintenance","path":"/pcnc-440/accessory-maintenance","children":[{"id":"ci_5088b956edadf5ab1036d6cd5057d15b66e26cbb6a787038c1596071bf97f503","title":"ATC Maintenance","path":"/pcnc-440/atc-maintenance","children":[{"id":"ci_77edfa1c35a75901f9e8fb1fa028cd0e80116f2774e0f874a46cbc40d922dc12","title":"General Tips and Maintenance for the Automatic Tool Changer (ATC)","path":"/pcnc-440/general-tips-and-maintenance-for-the-automatic-too","children":[]}]},{"id":"ci_36556c15848408fa598ac5178b23042c34f75c6127b8dace50ed9e62a2c12fdd","title":"Flood Coolant Maintenance","path":"/pcnc-440/flood-coolant-maintenance","children":[{"id":"ci_e28de5156610906db4af70bd826fa0515623d5ab959993abfa53ec5f1e645f03","title":"Tormach Oil Skimmer - Easy Coolant Tank Maintenance","path":"/pcnc-440/tormach-oil-skimmer-easy-coolant-tank-maintenance","children":[]}]},{"id":"ci_f4c685fe2094df26a071d2b9b141c05522b76a4609cbca7c6d81458cc97cd0c2","title":"Power Drawbar Maintenance","path":"/pcnc-440/power-drawbar-maintenance","children":[{"id":"ci_227d006979bd1914eeef71077f3885a49eb3de5d78de2325fd5038b241627e0d","title":"Power Drawbar Maintenance - PCNC 440","path":"/pcnc-440/power-drawbar-maintenance-pcnc-440","children":[]}]},{"id":"ci_18104c195b39adbeaf74775874c53dc9cbdfd940893933f178dc6d4435ad483f","title":"microARC 4 Maintenance","path":"/pcnc-440/microarc-4-maintenance-tips","children":[]}]}]},{"id":"ci_eae3239b719d914f428d7c25fb0635ee58989ab2f58c9dc712407db2c4cb9596","title":"Operation and Programming","path":"/pcnc-440/operation-and-programming","children":[{"id":"ci_341c48b0bdc276a6682825c36aa6d65e8f1565f83084893eee612741234437db","title":"Machine Operation","path":"/pcnc-440/machine-operation","children":[{"id":"ci_42435186d7c717ffbf2d6e7b4be216c80229233adbfd1e4e841b9d0ba2e0fb29","title":"System Basics - PCNC 440","path":"/pcnc-440/system-basics-pcnc-440","children":[]},{"id":"ci_902338b8701ea45ece8141bdddfdb4642b2c4791478748fbcfffca3989885f59","title":"PathPilot Interface Overview - PCNC 440","path":"/pcnc-440/pathpilot-interface-overview-pcnc-440","children":[]},{"id":"ci_457a73a96f0ec0cdf12b6a98f669aeb6b4b9cebd30b7c78ac7d1e5b889c1d832","title":"PathPilot Tools and Features - PCNC 440","path":"/pcnc-440/pathpilot-tools-and-features-pcnc-440","children":[]},{"id":"ci_d964c408e6f18a583006c8556175787119c854f221d8998ee6a003b6a414bb40","title":"Basic Operations - PCNC 440","path":"/pcnc-440/basic-operations-pcnc-440","children":[]},{"id":"ci_bac4798e851da584905971d10698e5d3a1ed1058a040d1386edf58a23300b2ea","title":"Setting G30","path":"/pcnc-440/setting-g30","children":[]},{"id":"ci_c9827f7ad20a86cccb8c7cd94ed58b21e955560c5945eeab1c641b5ed6999fe4","title":"Tormach Probing Routines","path":"/pcnc-440/probing-routines-in-pathpilot","children":[]},{"id":"ci_3f6f60fa7e134ce58aa024d92d5d36468eaf428f7c28f8f3144b8a7b69162f16","title":"Setting Up Work and Tool Offsets On Tormach Mills","path":"/pcnc-440/setting-up-work-and-tool-offsets-on-tormach-mills","children":[]},{"id":"ci_410edb2742807c80a8bd8ce8e88ac7ca73f544d3757623c68e73ad1be94e3e7a","title":"Tweaking Your Work Offsets","path":"/pcnc-440/tweaking-your-work-offsets","children":[]},{"id":"ci_882c979fcb3d1b303b106bae7eeba2ce838bd035816e2915445500734d86f852","title":"Changing Machine Configuration","path":"/pcnc-440/changing-machine-configuration","children":[]},{"id":"ci_b7e00f74c5ee0b5817f1c099c9b5cb63f43fa333c7bd99383b2d2ab5c466f4f2","title":"Setting Start Line in the Middle of Program","path":"/pcnc-440/setting-start-line-in-the-middle-of-program","children":[]},{"id":"ci_43bff94147fb8eb618392180e8e1357bb5c89ea759f6d0b4b52b638ffea198e3","title":"Windows 10 Network Setup and G-Code Share","path":"/pcnc-440/windows-10-network-setup-and-g-code-share","children":[]},{"id":"ci_49ee7e46601ccb317d6c5519c686a73bbe357f7576d12b1505975e1fe8ab6b91","title":"PathPilot Settings Backup","path":"/pcnc-440/pathpilot-settings-backup","children":[]},{"id":"ci_4a46bcf6fd11ab137575416dfd5455a33f2db874224037f377f7476adf4985e2","title":"PathPilot Spindle Warm Up Program","path":"/pcnc-440/pathpilot-spindle-warm-up-program","children":[]},{"id":"ci_a3c6c85f164f4c3b2382bef65303bc68bd113aff9276e5d5d937c213b82efdf2","title":"Setting Up WiFi and Software Updates","path":"/pcnc-440/setting-up-wifi-and-software-updates","children":[]},{"id":"ci_7a5847d07e7cb9ed897bffa0dc2ed9981b9ef8ac9ce57b0a2d97d56c74e96e61","title":"On-the-Fly Math for Feed Rates","path":"/pcnc-440/on-the-fly-math-for-feed-rates","children":[]},{"id":"ci_45e99e083e80bf6c0d14f0f470d476b62e3cbb6bbe5ea0ee6ac6ad00b3ac7b3f","title":"Finding G-Code from the MDI Line","path":"/pcnc-440/finding-g-code-from-the-mdi-line","children":[]},{"id":"ci_b96f4569be8e96b7859831f1994e74c3adae0ee67580b16cd2a908072ed94487","title":"Creeping Up on a Part","path":"/pcnc-440/creeping-up-on-a-part","children":[]},{"id":"ci_27f52633f3511ba33bdc5bc07fcd853137fe697b91ffae949a76c0a9996ac471","title":"Cutting Your First Part on a Tormach Mill","path":"/pcnc-440/cutting-your-first-part-on-a-tormach-mill","children":[]},{"id":"ci_ab5ca0a363cf4c04a46d19098be010fb99587c755fb4cab2702c6517ad25312c","title":"Your First Day with Tormach's PathPilot","path":"/pcnc-440/your-first-day-with-tormach-s-pathpilot","children":[]},{"id":"ci_b86ffd6e006a0b8ccb13cf9b9b3108cded4f0d308a430644dbd4477ad7f71fbc","title":"Generating a Log Data File in PathPilot","path":"/pcnc-440/generating-a-log-data-file-in-pathpilot","children":[]},{"id":"ci_2b22d1e0becdd3edcc841452fb5341a8929519691b0f8b6c53d2f88e667a8ad1","title":"How to Cut Holes with CNC","path":"/pcnc-440/how-to-cut-holes-with-cnc","children":[]},{"id":"ci_69647ae499bb51acf30e14fb724de309b59f837791928254786702ac1971fd31","title":"Engraving Comparison on Three Tormach CNC Mills: PCNC 440, 1100MX, and 1500MX","path":"/pcnc-440/engraving-comparison-on-three-tormach-cnc-mills-pc","children":[]},{"id":"ci_6b27eaf4246ff22957d687ae43cc057e15371bcbd925e0b9a77cad0c32aca065","title":"Probe & ETS Setup","path":"/pcnc-440/probe-ets-setup","children":[]},{"id":"ci_790a4913949c08ca311395db34cff39e76b54297a7c4d625cc5acce3da60e3a9","title":"Tormach 440 Cutting 4140","path":"/pcnc-440/tormach-440-cutting-4140","children":[]}]},{"id":"ci_b1ba35a1d9d15b673db60de53116b11acad776b2f1eb83130fb9d1bc131d11ae","title":"PathPilot Programming","path":"/pcnc-440/pathpilot-programming","children":[{"id":"ci_9a2e115a2d2363c4ad661a13a458f2c11810a4645e3d2cc1733f5887e67534a9","title":"Programming - PCNC 440","path":"/pcnc-440/programming-pcnc-440","children":[]},{"id":"ci_f23ff6c8a1067d9b5a3b696b982dd64dc7b2e544b779901ddcbf65da29ac691c","title":"G28 Command","path":"/pcnc-440/g28-command","children":[]},{"id":"ci_a937b26ccb519257499d63bbd7dafc81a6bc18744cd31a6900fdb6b4498455d9","title":"Work Coordinate Rotation with G10 L2 in PathPilot","path":"/pcnc-440/work-coordinate-rotation-with-g10-l2-in-pathpilot","children":[]},{"id":"ci_eb0a80a1a5b0479452aee170e564c2687c2de67ccb29e303fb42fe220d938216","title":"CAM Driven Probing","path":"/pcnc-440/cam-driven-probing","children":[]},{"id":"ci_3fb2de0b2bab21c2c3abbe18ef3401e82b9988235a13a7ac707986cc1e68cfc6","title":"G64/M59 Guide","path":"/pcnc-440/g64-m59-guide","children":[]},{"id":"ci_9355e3129b6fa6356537d8d16741698a739de076fc6ef85aa11dad0528de7de7","title":"Macro Programming","path":"/pcnc-440/macro-programming","children":[]},{"id":"ci_35983043456e0be0dd64b38a3769f99eab28e9478686b994e15be91b98ed8d10","title":"Conversational Drill and Tap","path":"/pcnc-440/conversational-drill-and-tap","children":[]},{"id":"ci_827a31216a83911f16b79bed6ac78146a7f071832e10d79becd5695eaaaf3be7","title":"PathPilot Post Processor Guidelines","path":"/pcnc-440/pathpilot-post-processor-guidelines","children":[]},{"id":"ci_a70af0d0a4942ebb89594c73d581d1b859959f10b3b4406e6a6d363324c88f74","title":"Conversational Programming in Tormach's PathPilot","path":"/pcnc-440/conversational-programming-in-tormach-s-pathpilot","children":[]},{"id":"ci_039721dafc9b29d5fcbabcf8ab3da28fde47e57f6f337e52b0664e5f969a68e1","title":"Tool Breakage Detection","path":"/pcnc-440/tool-breakage-detection","children":[]}]}]},{"id":"ci_b69c0407e880e9d1f30bad589b200030a904fd7c0650969d06b6a47796289357","title":"Troubleshooting","path":"/pcnc-440/troubleshooting","children":[{"id":"ci_962bb9e69f820b294acd9b49b5ec7074c837c04f5e12b9ac6cfa8f702fab4c9b","title":"Spindle Troubleshooting","path":"/pcnc-440/spindle-troubleshooting","children":[{"id":"ci_c881bb34be91ebe75d4238f1e072300c6e399ae7c7ad888690156873004b37e3","title":"Spindle Tram Adjustment - PCNC 440","path":"/pcnc-440/spindle-tram-adjustment-pcnc-440","children":[]},{"id":"ci_c7dbdafc5caef7e269b7ceaa244a4a9c2aff93ef3ae21f40ddaf095ad094cfb2","title":"Spindle Won't Turn - PCNC 440","path":"/pcnc-440/spindle-won-t-turn-pcnc-440","children":[]},{"id":"ci_eab226060c6592eb285ea6c406b957abd9943218f1226201dc36c346294c7d6a","title":"BLDC Check (Battery Test) - PCNC 440","path":"/pcnc-440/bldc-check-battery-test-pcnc-440","children":[]},{"id":"ci_c228a35441131834961491c6dc72789a2b60655c11e864f7d46efab2baf48d41","title":"Changing Spindle Belt Range","path":"/pcnc-440/changing-spindle-belt-range","children":[]},{"id":"ci_71cbeabad3f0359eb679cf9eb509b9710014e1bca7226e417d685bccbe267ca3","title":"Preventing Collet Slip","path":"/pcnc-440/preventing-collet-slip","children":[]},{"id":"ci_7f8b6e1366b2610074bf9a51a2576506e4076f2de5da0c45e4c809dcfb7bc9d2","title":"Chatter","path":"/pcnc-440/chatter","children":[]}]},{"id":"ci_40ac1fe4ae08b7fbb9d1461c17678b313372013146a005dddcdbcf63eed49988","title":"ATC Troubleshooting","path":"/pcnc-440/atc-troubleshooting","children":[{"id":"ci_3d967501dc8d81c7b1c35306365f1a30477b3a1378449f2a289e624969503a46","title":"Tray-In Sensor Fault PCNC 440 M-Style ATC","path":"/pcnc-440/tray-in-sensor-fault-pcnc-440-m-style-atc","children":[]},{"id":"ci_9b0eff65fb18ea80a6607bfe19c5cd48543b090e312c836788a1cc7da102e24c","title":"Pneumatic Seal Replacement for Leaking Drawbars","path":"/pcnc-440/pneumatic-seal-replacement-for-leaking-drawbars","children":[]},{"id":"ci_91d8a5d7bfb798706cc4f778d575623fca72d649ff60f9959b950011066fc26a","title":"Check Fuses and Cabling Error - PCNC 440","path":"/pcnc-440/check-fuses-and-cabling-error-pcnc-440","children":[]},{"id":"ci_e15267b8a1c12ad59fe338505f5065169e64c081860b9f57f6478f8037e33891","title":"Legacy ATC Alignment and Troubleshooting - PCNC 440","path":"/pcnc-440/legacy-atc-alignment-and-troubleshooting-pcnc-440","children":[]},{"id":"ci_f2736c42a03e7d76d300a375f2c9d65418cae89e8f74f5c6ba089b130028947d","title":"Low Air Pressure or Malfunctioning Air Pressure Switch - PCNC 440","path":"/pcnc-440/air-pressure-switch-isn-t-working-pcnc-440","children":[]},{"id":"ci_0be7ae33cb50c4ebac46485e09988806e3ff8194ce21b8d03ad6448789f86191","title":"ATC No VFD Running Signal From VFD (BLDC) - PCNC 440","path":"/pcnc-440/atc-no-vfd-running-signal-from-vfd-bldc-pcnc-440","children":[]},{"id":"ci_cd4ea3e57c38ad64842ba7ad1c85cf0fcf77e514f1dcc634266e00e1ade8320e","title":"Getting Out of an ATC Jam","path":"/pcnc-440/getting-out-of-an-atc-jam","children":[]}]},{"id":"ci_45d254abc6bc552a2f2adae38c15bb98951b650ac923ec45499e0e7d00b0cc07","title":"Controller Troubleshooting","path":"/pcnc-440/controller-troubleshooting","children":[{"id":"ci_2e14c84cbc21885ec53b199b1f1111bfa8cf14be3a54a7d847d362e1b4987062","title":"Controller Won't Power On - PCNC 440","path":"/pcnc-440/controller-won-t-power-on","children":[]},{"id":"ci_3d3e19ab833fe83fd8be71b612211ab0ed2caed84c619836c9fb13ecd115347b","title":"Controller is Beeping on Boot Up - Tower Controller","path":"/pcnc-440/controller-is-beeping-on-boot-up","children":[]},{"id":"ci_5ad4abaadf7b30b9dbb56ce0e558830c87eae7fe12aec72aca4231026e753f82","title":"Controller Monitor (Standard and Touch Screen) Doesn't Work","path":"/pcnc-440/controller-monitor-standard-and-touch-screen-doesn","children":[]},{"id":"ci_30037a227f32a659326be421f82a54c321ef358873388c56c30e3d9ed4709c98","title":"Restore PathPilot to Factory Settings","path":"/pcnc-440/restore-pathpilot-to-factory-settings","children":[]},{"id":"ci_035c05fa4bab3f02098e3be5eb5f72b9f7c70cacf7d7a539aefeded10653f58b","title":"DB25 Cable J4 and J10(440) Pinout","path":"/pcnc-440/db25-cable-j4-and-j10-440-pinout","children":[]},{"id":"ci_208433e082788091b880a094b5c48de9ff2a26e39dabcc41ce990a06774bcd3a","title":"PathPilot Controller CMOS Battery Replacement","path":"/pcnc-440/pathpilot-controller-cmos-battery-replacement","children":[]},{"id":"ci_9c2436b449d74497a77242ee614b8711e15f355cbe5d31f8b2ea1abf73f2b2aa","title":"Networking Machine to Windows Troubleshooting","path":"/pcnc-440/networking-machine-to-windows-troubleshooting","children":[]}]},{"id":"ci_068e441e7e28827f785e402f86c7fc4b966f3d4493cccd556b29c6c589b460e4","title":"Motion System Troubleshooting","path":"/pcnc-440/motion-system-troubleshooting","children":[{"id":"ci_004af89c2360b7e6c9905949a33333beb154926dd91aa13d74a3722fdeaefa06","title":"All Axes Won't Move When Commanded - PCNC 440","path":"/pcnc-440/all-axes-won-t-move-when-commanded","children":[]},{"id":"ci_dcac92b6fccba07c954c401b7cd43b4a5542167d49e8dee3c27fb622f097a5e0","title":"One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move","path":"/pcnc-440/one-axis-won-t-move-or-only-moves-in-one-direction","children":[]},{"id":"ci_cc18916f850f5bd1f40c1c8cdcf3dbe075cfe0edad4b093a342a167bc351d345","title":"Can't Reference All Axes - PCNC 440","path":"/pcnc-440/can-t-reference-all-axes-pcnc-440","children":[]},{"id":"ci_830b7da95a5631dcf1508f0e4955dc4ff8631517e6042ec3cabbbee5f1cf6269","title":"PCNC 440 Y-Axis Ball Screw Replacement","path":"/pcnc-440/pcnc-440-y-axis-ball-screw-replacement","children":[]},{"id":"ci_fa0b2fc18d4cd41bc0e764f62c6cc484c3095208b3487cfa880aa43aa5f30d7a","title":"PCNC 440 X-Axis Ball Screw Replacement","path":"/pcnc-440/pcnc-440-x-axis-ball-screw-replacement","children":[]},{"id":"ci_ec54b89d66432667fda57d958fc557cecd89c058f1935d7d55a888eedae572c3","title":"Lost Motion Testing and Gib/ACB Adjustment - PCNC 440","path":"/pcnc-440/lost-motion-testing-and-gib-acb-adjustment-pcnc-44","children":[]}]},{"id":"ci_ebef6dae84876681d793ff2823dfc2691cdf208602f1d65529b909dbe9ceb335","title":"General Electrical Troubleshooting","path":"/pcnc-440/general-electrical-troubleshooting","children":[{"id":"ci_dbc51f9e847e0f0b91d4bfe2fb61ee1d332d6454b47a17101f757b016da6cc95","title":"Checking a Fuse on a Tormach Machine","path":"/pcnc-440/checking-a-fuse-on-a-tormach-machine","children":[]},{"id":"ci_71b25b36afe9598f5887e650642dfce1db51a93b9362c530aeca73d387297a25","title":"PCNC 440 Estop Troubleshooting","path":"/pcnc-440/pcnc-440-estop-troubleshooting","children":[]},{"id":"ci_a0ec124b61d99ecf334a19a11ed4184c12431fd01b0a02f79118dd11d1dc6829","title":"DIN Port Jumper Test","path":"/pcnc-440/din-port-jumper-test","children":[]}]},{"id":"ci_30f1d1bb042fef2fb061131a0850242072cbef05dd1c64ff6479b65f50588c1f","title":"Accessory Troubleshooting","path":"/pcnc-440/accessory-troubleshooting","children":[{"id":"ci_d251757da2b7477c30e4f893894a2b85f37ea1a644fe88969a84c0fa5f2ba249","title":"microARC 4 Troubleshooting","path":"/pcnc-440/microarc-4-troubleshooting","children":[{"id":"ci_7cf70cb6326feb0f32b7f0201545e1800a79426a143634e2ff4aa588c313bd4b","title":"microARC 4 Repair","path":"/pcnc-440/microarc-4-repair","children":[]}]},{"id":"ci_3282bf0da522171add2b6661068967711b68ed3114393124eef96034f2b91ad4","title":"Flood Coolant Troubleshooting","path":"/pcnc-440/flood-coolant-troubleshooting","children":[{"id":"ci_65b6a1dffde923689c686fe397ba5818059a7b5ba78a1d8b6760b627c2ec4a2c","title":"Coolant Pump Won't Run","path":"/pcnc-440/coolant-pump-won-t-run","children":[]}]}]}]},{"id":"ci_c99bad4eef60b631af2837ddbbd5b22b824ae8085ed621a80ae25d0e0b9d920b","title":"Electrical Schematics and Diagrams","path":"/pcnc-440/electrical-schematics-and-diagrams","children":[{"id":"ci_9ede2d60177f1bd91c4b7c5c8bbb563e7e8d1ef628a6bb09fc7cb2b2321e104d","title":"Spindle Head - PCNC 440","path":"/pcnc-440/spindle-head-pcnc-440","children":[]},{"id":"ci_68232b9e88015fc8e5e72ff05455495c0ce52b0af1f15b2ec46e712d95ee3c78","title":"Z-Axis Column - PCNC 440","path":"/pcnc-440/z-axis-column-pcnc-440","children":[]},{"id":"ci_56f5579ff46444223ffbde5b1eaf05a3863748bcc91fc1a1ccbaaa0397e69973","title":"X-Y Axis - PCNC 440","path":"/pcnc-440/x-y-axis-pcnc-440","children":[]},{"id":"ci_9cc7897a92e96e75df922f1a87a20a8c51644933a25f304c82cf9e4c6a068058","title":"Electrical Cabinet - PCNC 440","path":"/pcnc-440/electrical-cabinet-pcnc-440","children":[]},{"id":"ci_49019c058178112051b69bf2c7248c38ff218b1998f457479e0807c8cfe19f6d","title":"Connections - PCNC 440","path":"/pcnc-440/connections-pcnc-440","children":[]},{"id":"ci_e72b2ecb2c6d2f48044de89cc2ac2a46a1924a6c0ea821be86dfef99b74e2b79","title":"Stepper Connections - PCNC 440","path":"/pcnc-440/stepper-connections-pcnc-440","children":[]},{"id":"ci_9fe6f5d4be5c702982582255be3146e19c9be3bc3c00e2ff8d0060a9a637ba60","title":"Lubrication System - PCNC 440","path":"/pcnc-440/lubrication-system-pcnc-440","children":[]},{"id":"ci_679458dd0c4c225e41f0b7c4d9ca2ee512c29481aeb3da2b2e14de33fdc25ac4","title":"Electrical Schematics - PCNC 440","path":"/pcnc-440/electrical-schematics-pcnc-440","children":[]}]}]
