Performance Expectations
Each machine has a Certificate of Inspection, which details quality assurance measurements performed by members of our quality assurance team prior to shipping.
Cutting Performance
This machine is capable of cutting a wide variety of materials (for information, see Intended Use) at or near their recommended feeds and speeds. Make sure that your workpiece is held as rigidly as possible and use the most rigid tooling available for roughing cuts. Verify that the programmed operations do not exceed the available spindle power.
Spindle Speed Range
Low 300 rpm to 4500 rpm
High 650 rpm to 10,000 rpm
Spindle Power Rating 0.75 hp (0.56 kW)
Maximum Feed Rate
X- and Y-Axis 135 IPM (3.43 m/min)
Z-Axis 110 IPM (2.7 m/min)
Resolution and Accuracy
Accuracy is heavily influenced by the techniques that the machinist uses. A skilled machinist can deliver accuracy that exceeds the specified accuracy from the manufacturer; an inexperienced machinist may have difficulty delivering the specified accuracy. We can't predict operator accuracy, but the specified accuracy is an important reference point.
Resolution 0.0001"
NOTE: The resolution of motion is the minimum discrete positional move.
Positional Accuracy ≤0.0016 in./10 in.
NOTE: The positional accuracy includes additional contributing factors (like compressibility of bearings, ball screw windup, and friction).
Travels | |
X-Axis | 10" (254 mm) |
Y-Axis | 6.25" (159 mm) |
Z-Axis | 10" (254 mm) |
Spindle-to-Table Maximum Clearance | 12" (305 mm) |
Spindle Centerline to Machine Column | 6.5" (165 mm) |
Spindle | |
Spindle Power | 0.75 hp (0.56 kW) |
Spindle Maximum Speed | 10,000 rpm |
Transmission | Poly-V Belt |
Spindle Taper | R8 |
Thread Machining | Thread Mill |
Maximum Feed Rate | |
X- and Y-Axis | 135 IPM (3.43 m/min) |
Z-Axis | 110 IPM (2.7 m/min) |
Axis Motor | Stepper Driven |
Power | |
Primary Power Required | Single-Phase 115 Vac, 50/60 Hz |
Recommended Circuit Amperage | Dedicated 15 A breaker |
Table | |
Table Size | 18" × 6.3" (457 mm × 160 mm) |
T-Slot Size | 3/8" (9.5 mm) (three slots) |
Maximum Weight on Table | 150 lb (68 kg) |
Overall Dimensions | |
Machine Size | 42" × 36" (1.1 m × 0.9 m) |
Overall System Height | 72" (1.8 m) |
Typical System Weight | 600 lb (272 kg) |
This is a section of the PCNC 440 operator's manual. To view the whole manual, go to Tormach document UM10372.
