Skip table of contents
PCNC 770 Series 3 Machine Specifications
Mechanical
Key Dimensions (machine table)
Length
28”
Width
8”
T-Slot Width
5/8”
T-Slot Center-to-Center Distance
2”
Number of Standard T-Slots
Three along X Axis
(Center slot precision ground to 0.625”)
Maximum Weight on Table
400 lbs.
Spindle Nose to Table (~max)
14.8”
Spindle Nose to Table (~min)
1”
Spindle Center to Column Face
8 5/8”
X Axis
14”
Y Axis
7.5”
Z Axis
13.25”
Speed Range
175-10,000 RPM
Maximum Rating
1.0 hp (1.75 hp peak)
Drive System
Belt Driven (two positions)
Low Belt: 175-3250 RPM
High Belt: 525-10,000 RPM
Taper
R8
Feed Rates
Rapids on X
135 IPM
Rapids on Y
135 IPM
Rapids on Z
110 IPM
Max Cutting
135 IPM (X,Y), 110 IPM (Z)
Temperature
Operating Range
45°F-100°F (7°C-38°C)
Electrical
Power Requirements
115 VAC, 50/60 Hz
Recommended Circuit Amperage*
20 AMP
*Dedicated circuit recommended; do not use with a ground-fault interrupter (GFI).
JavaScript errors detected
