1100MX Knowledge Base
Performance Expectations
Each machine ships with a Certificate of Inspection, which details quality assurance measurements performed by members of our quality assurance team prior to shipping.
Cutting Performance
This machine is capable of cutting a wide variety of materials (for information, see Intended Use) at or near their recommended feeds and speeds. Make sure that your workpiece is held as rigidly as possible and use the most rigid tooling available for roughing cuts. Verify that the programmed operations do not exceed the available spindle power.
Spindle Speed Range
  • Low 70 rpm to 2000 rpm
  • High 250 rpm to 10,000 rpm
  • Spindle Power Rating 2 hp (1.5 kW)
  • Maximum Feed Rate
    • X- and Y-Axis 300 IPM (2.7 m/min)
    • Z-Axis 230 IPM (2.2 m/min)
Resolution and Accuracy
Accuracy is heavily influenced by the techniques that the machinist uses. A skilled machinist can deliver accuracy that exceeds the specified accuracy from the manufacturer; an inexperienced machinist may have difficulty delivering the specified accuracy. We can't predict operator accuracy, but the specified accuracy is an important reference point.
  • Resolution 0.0001"
NOTE: The resolution of motion is the minimum discrete positional move.
  • Ball Screw Positional Accuracy ≤ 0.0006 in./ft
  • Positional Accuracy ≤ 0.0013 in./ft
NOTE: The positional accuracy includes additional contributing factors (like compressibility of bearings, ball screw windup, and friction).
X-Axis
18" (457 mm)
Y-Axis
11" (279 mm)
Z-Axis
16.25" (413 mm)
Spindle-to-Table Maximum Clearance
18" (457 mm)
Spindle Centerline to Machine Column
11" (279 mm)
Spindle Power
2 hp (1.5 kW)
Spindle Maximum Speed
10,000 rpm
Transmission
Poly-V Belt
Spindle Taper
BT30
Thread Machining
Tension/Compression, Rigid Tapping, Thread Mill
Maximum Feed Rate
X- and Y-Axis
300 IPM (2.7 m/min)
Z-Axis
230 IPM (2.2 m/min)
Axis Motor
Servo Driven
Primary Power Required
Single-Phase 230 Vac, 50/60 Hz
Recommended Circuit Amperage
Dedicated 20 A breaker
Table
Table Size
34" × 9.5" (864 mm × 241 mm)
T-Slot Size
5/8" (15.9 mm) (three slots)
Maximum Weight on Table
500 lb (181 kg)
Overall Dimensions
Machine Size
69" × 56" (1.8 m × 1.4 m)
Overall System Height
96" (2.4 m)
Typical System Weight
1600 lb (726 kg)
