770MX (ML Serials) Knowledge Base - Coming Soon!
Open a Support Ticket
Forums
Tormach YouTube
Tech Support YouTube
Tormach.com
Main navigation
Close navigation
Main
1500MX Knowledge Base
About Your Machine
Safety
Site Requirements
Unpack the Machine Crate
Self-Assembled Installation - 1500MX
Self-Assembled Installation Manual - 1500MX
Factory-Assembled Machine Setup - 1500MX
Verify the Installation
Hiring a Rigging Company to Deliver Your 1500MX
Accessory Installation
Probe and Tool Setter
Flood Coolant Kit (Self-Installed Machines)
Automatic Chip Tray Washdown Kit
Through-Spindle Coolant (TSC) Kit
Chip Conveyor Kit
Mist Collector Kit
MQL Kit
Automatic Tool Changer (ATC)
microARC 6
Machine Maintenance
Operation and Programming
Machine Operation
System Basics - 1500MX
PathPilot Interface Overview - 1500MX
PathPilot Tools and Features - 1500MX
Basic Operations - 1500MX
Creeping Up on a Part
PathPilot Settings Backup
Tweaking Your Work Offsets
Tormach Probing Routines
Setting G30
How to Cut Holes with CNC
Engraving Comparison on Three Tormach CNC Mills: PCNC 440, 1100MX, and 1500MX
Through Spindle Coolant Overview
Parameter, and Approach for Cutting titanium on the 1500MX
Developing Cut Strategies for 304 Stainless Steel on the Tormach 1500MX CNC Mill
PathPilot Programming
Programming - 1500MX
Macro Programming
Conversational Drill and Tap
G64/M59 Guide
G28 Command
CAM Driven Probing
Servo Drive Subsystem
All Axes Won't Move When Commanded - 1500MX
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - 1500MX
Axis Movement is Noisy - 1500MX
Lost Motion on Axis Travel - 1500MX
Spindle Drive Subsystem
The Spindle Won't Turn - 1500MX
Machining Operations are Loud (Chatter) - 1500MX
Can't Load or Unload a Tool, or the Spindle's Drawbar Drags Against the Power Drawbar Cylinder's Piston - 1500MX
Spindle Rotates on Contact, or Spindle Isn't Rigidly Clamped
Spindle Doesn't Orient Correctly or Consistently - 1500MX
Power Distribution Subsystem
Machine Won't Power On - 1500MX
Operator Console Won't Power On - 1500MX
Servo IO Breakout Board Subsystem
Groups of Inputs and Outputs Aren't Functioning - 1500MX
Accessory Troubleshooting
Low Air Pressure or Malfunctioning Air Pressure Switch - 1500MX
Exploded Views
Machine Diagrams and Parts Lists
Assembly Overview - 1500MX
BT30 Power Drawbar Cylinder - 1500MX
Electrical Cabinet - 1500MX
Enclosure - 1500MX
Flood Coolant System - 1500MX
Flood Coolant Kit Assembly - 1500MX
Coolant Tank Assembly - 1500MX
Flood Coolant Filter Assembly - 1500MX
Y-Axis Washdown Nozzle - 1500MX
Flood Coolant Manifold Manifold Assembly
Washdown Gun Kit
Linear Actuator Assembly - 1500MX
Pneumatics Assembly - 1500MX
Spindle Head - 1500MX
Spindle Head Camera Assembly - 1500MX
Spindle Head Sheet Metal Cover Assembly - 1500MX
X-Axis Assembly - 1500MX
X-Axis Lubrication Assembly - 1500MX
X-Axis Sheet Metal Cover Assembly - 1500MX
Y-Axis Lubrication Assembly - 1500MX
Y-Axis Front Way Cover Assembly - 1500MX
Y-Axis Read Way Cover Assembly - 1500MX
Z-Axis Lubrication Assembly - 1500MX
Z-Axis Way Cover Assembly - 1500MX
Accessory Diagrams and Parts Lists
Automatic Tool Changer Assembly - 1500MX
microARC 6 Assembly - 1500MX
MQL Solenoid Assembly, 24 Vdc - 1500MX
Washdown Kit Assembly - 1500MX
Electrical Schematics
Mill Schematics
230 Vac Power - 1500MX
24 Vdc Controls - 1500MX
Safety Systems - 1500MX
Spindle Drive - 1500MX
A- and B-Axis Drives - 1500MX
EtherCAT IO Board - 1500MX
Grounds - 1500MX
-X1 AC Terminal Strip - 1500MX
Wiring Table - 1500MX
Accessory Schematics
Automatic Tool Changer (ATC) Schematics - 1500MX
Through-Spindle Coolant Electrical Schematics - 1500MX
Chip Conveyor Electrical Schematic - 1500MX
770MX (MF/MH) Knowledge Base
About Your Machine
Safety
770M/MX Torque Curves (MX - MF/MH Serials)
Site Requirements
Assemble the Machine Stand
Unpack and Mount the Machine
PathPilot Controller
Manual Oiler
Chip Pans
Enclosure
ATC
ATC Installation Manual - 770MX
Tool Change Scenarios
microARC 4
6 and 8 in. 4th Axis
4th Axis Installation Manual
How to Setup a 4th Axis
RapidTurn
RapidTurn Installation
Operator Console
Operator Console Installation Video - 770MX
SmartCool
SmartCool Installation Manual
Fogbuster
USB I/O
Flood Coolant
Flood Coolant Kit
Automatic Oiler
Touch Screen
Vise
Basic Steps to Square a Vise
ETS - Electronic Tool Setter
Power Drawbar Foot Pedal
Machine Maintenance
770MX Maintenance
Machine Paint Color Codes
Accessory Maintenance
ATC Maintenance
microARC 4 Maintenance
microARC Maintenance
Flood Coolant Maintenance
Machine Operation
System Basics - 770MX
PathPilot Interface Overview - 770MX
PathPilot Tools and Features - 770MX
Basic Operations - 770MX
Setting G30
Probe & ETS Setup
Programming - 770MX
G28 Command
CAM Driven Probing
G64/M59 Guide
Macro Programming
Spindle Troubleshooting
Spindle Tram Adjustment
Changing Spindle Belt Range
Spindle Won't Turn
Spindle Orient or at Speed Fails
Chatter
ATC Troubleshooting
Device Homing Error
Tray-In Sensor Fault
Manual Tool Change with Dead ATC Board - 770MX
Check Fuses and Cabling Error
Getting Out of an ATC Jam
Controller Won't Power On - 770MX
No Ethernet Link Detected Troubleshooting - 770MX
Motion System Troubleshooting
Mill Gib/AC Bearing Adjustment and Backlash Compensation - 770MX
Ballscrew Replacement
Lost Motion Testing - 770MX
All Axes Won't Move When Commanded - 770MX
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - 770MX
Axis Movement is Noisy - 770MX
Machine Won't Power On - 770MX
microARC 4 Troubleshooting
microARC 4 Repair
4th Axis Backlash Adjustment
RapidTurn Troubleshooting
Flood Coolant Troubleshooting
Coolant Pump Won't Run
Base Machine - 770MX
Spindle Cartridge - 770MX
Spindle Head - 770MX
Power Drawbar Push Button - 770MX
Spindle Motor Cover - 770MX
X-Axis Assembly - 770MX
Y-Axis Assembly - 770MX
Y-Axis Saddle - 770MX
X-Y Axis Assembly - 770MX
Lubrication/Oil System - 770MX
115 VAC Power - 770MX
24 VDC Controls - 770MX
Axis Drive Bus - 770MX
Spindle Drive - 770MX
Machine Control Board - 770MX
Limit/Door Switches - 770MX
Grounds - 770MX
Operator Box Layout - 770MX
Wiring Table - 770MX
1300PL Knowledge Base
About Your Machine
Safety
Site Requirements
Install Plasma Torch and Lead
Fill Water Table
Set Torch Home Position (G30)
Touch Screen
Machine Maintenance
1300PL Machine Maintenance
1300PL Table Slat Replacement
Machine Operation
System Basics - 1300PL
Basic Operations - 1300PL
Setting G30
Programming - 1300PL
Macro Programming
G64/M59 Guide
Controller Troubleshooting
Adjust Belt Tension
Can't Reference All Axes
Ohmic Probe Doesn't Trigger
Torch Pierces Too High
Torch Cuts Too High
Torch Shuts Off During Cut
PCNC 1100 Knowledge Base
About Your Machine
Safety
Site Planning and Prep
Install PathPilot Controller
Essential Controls Overview
Power Off/Power On Procedure
Validate Basic Installation
Controller Customization
Deluxe Stand - PCNC 1100
Power Drawbar - PCNC 1100
ATC
10 Pocket Legacy ATC Installation Manual - PCNC 1100
12 Pocket M-Style ATC Installation Manual - PCNC 1100
Enclosure - PCNC 1100
Enclosure Switch Kit - PCNC 1100
microARC 4
SmartCool
FogBuster
USB I/O
Touch Screen
Vise
Automatic Oiler
RapidTurn
Machine Maintenance
PCNC 1100 Maintenance
Flushing the Lubrication System
ATC Maintenance
Machine Operation
Basic Operation - PCNC 1100
Setting G30
Probe & ETS Setup
Programming - PCNC 1100
G28 Command
CAM Driven Probing
G64/M59 Guide
Macro Programming
Preventing Collet Slip
PCNC 1100 Spindle Rebuild
Chatter
ATC Troubleshooting
ATC Tab Disappears - Legacy ATC (10 Pocket)
Tray In Sensor Isn't Working - Legacy ATC (10 Pocket)
Tray is Moving Too Fast or Too Slow - Legacy ATC (10 Pocket)
Check Fuses and Cables Error
Device Homing Error
Controller Won't Power On - PCNC 1100
All Axes Won't Move When Commanded - PCNC 1100
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - PCNC 1100
Can't Reference All Axes - PCNC 1100
Mill Gib/AC Bearing Adjustment and Backlash Compensation - PCNC 1100
Lost Motion Testing - PCNC 1100
Axis Movement is Noisy - PCNC 1100
PCNC 1100 and 770 Series 1 and Series 2 Dip Switches
Machine Won't Power On - PCNC 1100
microARC 4 Repair
PCNC 440 Knowledge Base
About Your Machine
Safety
PCNC 440 Torque Curves
Site Requirements
Unpack the Machine Crate and Mount the Machine
Install the Monitor and the PathPilot Controller
Machine Stand - PCNC 440
Enclosure - PCNC 440
PCNC 440 Power Drawbar
Power Drawbar Installation Manual - PCNC 440
Flood Coolant Kit - PCNC 440
Door Switch Kit - PCNC 440
ATC
ATC Installation Manual - PCNC 440
microARC 4
microARC 4 Installation Video
microARC Installation Manaual
SmartCool
FogBuster
USB I/O
Touch Screen
Vise
Machine Maintenance
PCNC 440 Maintenance
PCNC Oil Line Flush
ATC Maintenance
Power Drawbar Maintenance - PCNC 440
Machine Operation
System Basics - PCNC 440
PathPilot Interface Overview - PCNC 440
PathPilot Tools and Features - PCNC 440
Basic Operations - PCNC 440
Setting G30
Probe & ETS Setup
Tormach 440 Cutting 4140
Programming - PCNC 440
G28 Command
CAM Driven Probing
G64/M59 Guide
Macro Programming
Spindle Tram Adjustment - PCNC 440
Spindle Won't Turn - PCNC 440
BLDC Check (Battery Test) - PCNC 440
Chatter
ATC Troubleshooting
Tray-In Sensor Fault PCNC 440 M-Style ATC
Check Fuses and Cabling Error - PCNC 440
Legacy ATC Alignment and Troubleshooting - PCNC 440
Low Air Pressure or Malfunctioning Air Pressure Switch - PCNC 440
v2.x ATC Control Board Kit for PCNC 440 Mills
ATC No VFD Running Signal From VFD (BLDC) - PCNC 440
Controller Won't Power On - PCNC 440
All Axes Won't Move When Commanded - PCNC 440
Can't Reference All Axes - PCNC 440
PCNC 440 Y-Axis Ball Screw Replacement
PCNC 440 X-Axis Ball Screw Replacement
Lost Motion Testing and Gib/ACB Adjustment - PCNC 440
PCNC 440 Estop Troubleshooting
microARC 4 Repair
770M Knowledge Base
About Your Machine
Safety
Site Requirements
Before You Begin Installation
Manual Oiler
Chip Pans
Enclosure
ATC
microARC 4
RapidTurn
Operator Console
SmartCool
Backsplash and Splash Guard
Fogbuster
USB I/O
Flood Coolant
Flood Coolant Kit
Automatic Oiler
Touch Screen
Vise
Machine Maintenance
770M Maintenance
ATC Maintenance
Machine Operation
Setting G30
Probe & ETS Setup
Programming - 770M
G28 Command
CAM Driven Probing
G64/M59 Guide
Macro Programming
770M Spindle Won't Turn
Chatter
ATC Troubleshooting
Device Homing Error
Can't Reference All Axes - 770M
microARC 4 Repair
770M+ Servo Upgrade
770M+ Servo Upgrade Installation Video
770M+ Servo Upgrade Installation Manual
770M+ to MX Spindle Upgrade
770M+ BT30 Spindle Upgrade (M+ to MX)
770M+ BT30 Spindle Upgrade (M+ to MX) Installation Manual
Base Machine - 770M
Z-Axis Assembly - 770M
Enclosure - 770M
Lubrication/Oil System Diagram - 770M
Grounds - 770M
Wiring Table - 770M
Operator Console - 770M
15L Knowledge Base
About Your Machine
Safety
Install the Manual Oiler
Tormach 15L Slant-Pro CNC Lathe Lifting Kit
Turret
Gen 1 Turret Installation Manual
Gen 2 Turret
Gen 2 Turret Installation Manual (PN 37335)
How to Install Turret Boring Bar Holders on the Tormach 15L
Auto Collet Closer
Auto Collet Closer Installation Manual
D1-4 Lathe Chuck
D1-4 Chuck/Face Plate Installation Manual
Quick Change Tool Post
Quick Change Tool Post Installation Manual - 15L
Collet Closer Foot Pedal
15L Slant-PRO Lathe Light Kit
Chuck Guard Kit
15L Gen 2 Enclosure
Automatic Oiler
Gang Tooling
5C Collet Insert
Machine Maintenance
15L Maintenance
Adding Oil to a Gen 2 Turret
Machine Operation
Operation - 15L
PathPilot Tools and Features - 15L
PathPilot Interface Overview - 15L
Change Spindle Motor Pulley Position - 15L
Adjusting Lathe Soft Limits
Cutting a Yo-Yo on the Tormach 15L Slant-PRO Lathe
Customizing Lathe Turning Tools
Making a Pen with Lathe Conversational Profiling
Beginner's Guide to Lathe Tooling
Turning Steel on a 15L Slant-PRO Lathe
Cutting an Industrial-Style Air Hose Coupler on a Tormach Slant-Pro
Touching Off Drills on a Tormach Lathe
Cutting Your First Part on a Tormach Lathe
Cutting a Camera Step-Up Ring on a Tormach 15L
Cutting a Custom Steel Bolt on the Tormach 15L
Setting Up Work and Tool Offsets on a Tormach Lathe
Tormach 15L EZ Bar Puller/Automatic Collet Closer
Programming - 15L
Macro Programming
Conversational Programming on the Tormach 15L Slant-PRO Lathe
G64/M59 Guide
Spindle and Drive System Troubleshooting
15L Encoder Replacement
My Spindle Won't Turn - 15L
Spindle Direction is Reverse
15L Gib/AC Bearing Adjustment and Backlash Compensation
All Axes Won't Move When Commanded - 15L
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - 15L
Controller Won't Power On - 15L
DB25 Cable J4 and J10(Pinout) Pinout
Machine Won't Power On - 15L
Turret Troubleshooting
Gen 2 Turret Harness Replacement
Gen 2 Turret Lock Sensor Adjustment
Coolant Pump Won't Run - 15L
Lathe Bed Z-Axis - 15L
Lathe Headstock - 15L
Lathe Cabinet Hardware - 15L
8L Knowledge Base
About Your Machine
Safety
8L Torque Curves
Site Requirements
Before You Begin and Move the Pallet
Lift and Move the Machine
Align Quick Change Tool Post Kit
Install the Machine Stand Coolant Kit
Machine Maintenance
8L Maintenance
Machine Operation
System Basics - 8L
PathPilot Interface Overview - 8L
PathPilot Tools and Features - 8L
Basic Operations - 8L
Install a Chuck onto 8L Lathe
ID Boring and Threading on a Tormach 8L
Setting Up Multiple Offsets on an 8L Lathe
Cutting a Thumbscrew on an 8L Lathe
Setting Up a Boring Bar on an 8L Lathe
Tormach 8L Lathe Setup (Part 1): Setting Up Tool Heights and Lengths
Programming - 8L
Macro Programming
G64/M59 Guide
All Axes Won't Move When Commanded - 8L
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - 8L
No Ethernet Link Detected Troubleshooting - 8L
Controller Won't Power On - 8L
Machine Won't Power On - 8L
PCNC 770 Knowledge Base
About Your Machine
Safety
Machine Stand - PCNC 770
Enclosure - PCNC 770
Power Drawbar - PCNC 770
ATC
Legacy ATC Installation Manual - PCNC 770
M-Style ATC Installation Manual - PCNC 770
microARC 4
SmartCool
FogBuster
USB I/O
Touch Screen
Vise
RapidTurn
Machine Maintenance
PCNC 770 Maintenance
ATC Maintenance
Power Drawbar Maintenance - PCNC 770
Machine Operation
Basic Operation - PCNC 770
PathPilot Interface - PCNC 770
Setting G30
Probe & ETS Setup
Programming - PCNC 770
G28 Command
CAM Driven Probing
G64/M59 Guide
Macro Programming
Chatter
ATC Troubleshooting
Low Air Pressure or Malfunctioning Air Pressure Switch - PCNC 770
Device Homing Error
Controller Won't Power On - PCNC 770
Mill Gib/AC Bearing Adjustment and Backlash Compensation - PCNC 770
Lost Motion Testing - PCNC 770
Axis Movement is Noisy - PCNC 770
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - PCNC 770
All Axes Won't Move When Commanded - PCNC 770
Can't Reference All Axes - PCNC 770
Machine Won't Power On - PCNC 770
microARC 4 Repair
15LX Knowledge Base - Coming Soon!
AF50+ Knowledge Base
About Your Machine
Safety
Site Requirements
Unpack the Crate
Set Up the Machine
Machine Operation
System Basics - AF50+
Basic Operations - AF50+
Automatic and Manual Operation - AF50+
Maintenance and Mechanical Adjustments
Machine Maintenance - AF50+
Mechanical Adjustments - AF50+
Operations Troubleshooting
Blades Break Too Frequently - AF50+
Blades Dull Too Quickly - AF50+
Blades Lose Teeth - AF50+
Cuts Are Crooked - AF50+
Material Doesn't Advance - AF50+
Material Slips in Vise Clamps - AF50+
Noise or Problems Moving Through the Cut - AF50+
Motor and Electrical Troubleshooting
Coolant Pump Doesn't Work - AF50+
Error on the Control Panel - AF50+
Machine Doesn't Start or a Panel Breaker Trips - AF50+
Machine Stalls or It's Underpowered - AF50+
Pneumatic System - AF50+
Electrical Schematic - AF50+
1100M Knowledge Base
About Your Machine
Safety
1100M Torque Curves
Site Requirements
Manual Oiler
Chip Pans
Enclosure
ATC
microARC 4
RapidTurn
Operator Console
SmartCool
Fogbuster
USB I/O
Flood Coolant
Flood Coolant Kit
Automatic Oiler
Touch Screen
Vise
Machine Maintenance
1100M Maintenance
ATC Maintenance
Machine Operation
System Basics - 1100M
Basic Operations - 1100M
Setting G30
Probe & ETS Setup
Programming - 1100M
G28 Command
CAM Driven Probing
G64/M59 Guide
Macro Programming
Chatter
ATC Troubleshooting
Device Homing Error
Lost Motion Testing - 1100M
microARC 4 Repair
1100M+ Servo Upgrade
1100M+ to MX Spindle Upgrade
Base Machine - 1100M
Spindle Motor Cover - 1100M
X-Axis Assembly - 1100M
Y-Axis Assembly - 1100M
Y-Axis Saddle - 1100M
X-Y Axis Assembly - 1100M
Z-Axis Assembly - 1100M
Stand - 1100M
Coolant Tank - 1100M
Enclosure - 1100M
230 VAC Power - 1100M
24 VDC Controls - 1100M
Axis Drive Bus - 1100M
Spindle Drive - 1100M
Machine Control Board - 1100M
Limit/Door Switches - 1100M
Grounds - 1100M
Operator Box Layout - 1100M
Wiring Table - 1100M
Operator Console - 1100M
24R Knowledge Base
About Your Machine
Safety
Machine Kinematics
Spoilboard Bolt Pattern
T-Slot Layout and Dimensions
Site Requirements
Unpack and Level the Machine
ATC
ATC Installation Video - 24R
ATC Installation Manual - 24R
Operator Console
24R Z-Axis Brake Retrofit Kit
24R 24 Vdc Power Supply
Machine Maintenance - 24R
24R Maintenance
Machine Operation
System Basics - 24R
Basic Operations - 24R
Programming - 24R
Machine Won't Power On - 24R
Lost Motion - 24R
Axis Movement is Noisy - 24R
ATC Troubleshooting
My Spindle Won't Turn - 24R
xsTECH Pro Knowledgebase - Coming Soon!
AF50 Knowledge Base
About Your Machine
Safety
Site Requirements
Set Up the Machine
Machine Operation
Noise or Machine Vibration - AF50
Base Casting Exploded View - AF50
Head Casting Exploded View - AF50
Infeed Table Exploded View - AF50
Stand Exploded View - AF50
Bandsaw Pneumatics - AF50
115 Vac Power - AF50
Controls and Sensors - AF50
Terminal Strips - AF50
Electrical Panel Layout - AF50
1100MX Knowledge Base
About Your Machine
Safety
1100MX Torque Curves
Site Requirements
Manual Oiler
Chip Pans
Enclosure
ATC
ATC Installation Manual - 1100MX
microARC 4
RapidTurn
Operator Console
Operator Console Installation Video - 1100MX
Operator Console Installation Manual - 1100MX
SmartCool
Fogbuster
USB I/O
Flood Coolant
Flood Coolant Kit
Automatic Oiler
Touch Screen
Vise
Machine Maintenance
1100MX Maintenance
ATC Maintenance
Machine Operation
System Basics - 1100MX
PathPilot Interface Overview - 1100MX
PathPilot Tools and Features - 1100MX
Basic Operations - 1100MX
Probe & ETS Setup
Setting G30
Programming - 1100MX
Macro Programming
G64/M59 Guide
G28 Command
CAM Driven Probing
Spindle Orient or at Speed Fails - 1100MX
Chatter
ATC Troubleshooting
Device Homing Error
Manual Tool Change with Dead ATC Board - 1100MX
Controller Won't Power On - 1100MX
No Ethernet Link Detected Troubleshooting - 1100MX
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - 1100MX
Mill Gib/AC Bearing Adjustment and Backlash Compensation - 1100MX
All Axes Won't Move When Commanded - 1100MX
Axis Movement is Noisy - 1100MX
Lost Motion Testing - 1100MX
Machine Won't Power On - 1100MX
microARC 4 Repair
Base Machine - 1100MX
Spindle Cartridge - 1100MX
Power Drawbar Push Button - 1100MX
Spindle Motor Cover - 1100MX
X-Axis Assembly - 1100MX
Y-Axis Assembly - 1100MX
Y-Axis Saddle - 1100MX
X-Y Axis Assembly - 1100MX
Z-Axis Assembly - 1100MX
Enclosure - 1100MX
Lubrication/Oil System Diagram - 1100MX
Stand - 1100MX
230 VAC Power - 1100MX
24 VDC Controls - 1100MX
Axis Drive Bus - 1100MX
Spindle Drive - 1100MX
Limit/Door Switches - 1100MX
Grounds - 1100MX
Operator Box Layout - 1100MX
Wiring Table - 1100MX
Operator Console - 110MX
xsTech Knowledge Base
About Your Machine
xsTECH Machine Specifications
T-Slot Spacing of xsTECH
EU Declaration of Conformity (CE Certification)
xsTECH Router Bill of Materials
xsTECH Illustrated Parts Diagram and Key
xsTECH Exploded View
xsTECH Router Wiring Diagram
Getting Started
xsTECH Quick Setup Guide
Setting Up and Getting Started with an xsTECH Router
Holding Material in the xsTECH
Workholding Tips and Tricks
Tool Setter Installation
xsTECH 4th Axis Installation
xsTECH Tooling Overview
Getting Started with the xsTECH: A 9-Part CNC Training Series for Educators and Students
How to Make a Whiskey Smoker Using the Tormach xsTECH CNC Desktop Router
Creating Name Tags on the xsTECH Desktop Router: A CNC Project for Students
Making a Tool Holder on the xsTECH Desktop Router: Parts 1, 2 & 3
Making a Tool Holder on the xsTECH CNC Desktop Router: Parts 4, 5 & 6
X Axis Gantry Alignment
ETS Error When Measuring Tools
xsTECH Axis Motion Control Swap
xsTECH Spindle Speed Control Troubleshooting
xsTECH Spindle Running in Reverse
xsTECH X-Axis Motor Replacement
xsTECH Y-Axis Motor Replacement
FAQ
What is the Tormach xsTECH Router?
Do I need to supply my own compuer to use the xsTECH?
What is PathPilot?
How much does the xsTECH router weigh?
What size cutting tools can I use with the xsTECH Router?
How loud is the xsTECH Router?
How do I install tools on the xsTECH Router?
How do I reference the xsTECH Router?
How do I set X, Y, and Z-axis work offsets on the xsTECH Router?
How do I use the PathPilot Tool Table?
How do I use the electronic tool setter?
How do I update PathPilot?
How do I change BIOS power setting on my PathPilot controller?
How do I calibrate the touchscreen on my PathPilot controller?
How do I find the MAC address for my PathPilot Controller?
How do I replace the fuse on the xsTECH Router?
Where do I find the lot number or serial number of my xsTECH Router?
How do I adjust the tool setter sensor position?
How do I disable the limit switches on my xsTECH Router?
How do I cut plywood on the xsTECH Router?
How do I cut Plastic on the xsTECH Router?
How do I cut Hardwoods on the xsTECH Router?
Forums
Tormach YouTube
Tormach.com
