xsTECH Knowledge Base
xsTECH Router Bill of Materials
Pictured and listed below is everything that comes along with your xsTECH Router.
Your xsTECH CNC Router Package includes:
  • 10.4 in. Touchscreen PathPilot Controller
  • Keyboard, Mouse, and Jog Shuttle input devices
  • WiFi Module
  • Electronic Tool Setter
  • ER11 Collets
  • 16 pcs. Carbide Cutting Tools
    • 1 - Spiral 'O' Flute Up-Cut End Mill: 2 mm x 12 mm x 4 mm x 50 mm
    • 1 - Spiral Down-Cut Plunge End Mill: 4 mm x 12 mm x 4 mm x 50 mm
    • 1 - Spiral Up-Cut Plunge End Mill: 4 mm x 12 mm x 4 mm x 50 mm
    • 1 - Spiral Compression End Mill: 4 mm x 20 mm x 4 mm x 50 mm
    • 1 - Spiral Down-Cut End Mill: 4 mm x 12 mm x 4 mm x 50 mm
    • 1 - Spiral Ball Nose Up-Cut End Mill: 2 mm x 12 mm x 4 mm x 50 mm
    • 1 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 25 mm x 4 mm x 50 mm
    • 1 - Spiral 'O' Flute Down-Cut End Mill: 4 mm x 25 mm x 4 mm x 50 mm
    • 1 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 12 mm x 4 mm x 50 mm
    • 1 - Straight Ball Nose End Mill: 4 mm x 25 mm x 4 mm x 50 mm
    • 1 - Tapered Ball Nose End Mill: 1 mm x 10 mm x 4 mm x 50 mm
    • 1 - Square End Mill: 4 mm x 6 mm x 4 mm x 50 mm
    • 1 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 8 mm x 4 mm x 30 mm
    • 1 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 6 mm x 4 mm x 40 mm
    • 1 - Spiral 'O' Flute Up-Cut End Mill: 2 mm x 6 mm x 4 mm x 40 mm
