PCNC 440 Knowledge Base
Inspect the item(s):
  • Note any damage on the delivery receipt before signing for the shipment. If there is extensive visible damage to the machine, refuse to accept the shipment.
If there are any items that have not yet been delivered, we recommend waiting until you've received all shipments to begin installing the machine. Depending on the product and options ordered, the system may arrive in one or more shipments of:
  • Accessories (if applicable)
  • Machine
NOTE: The machine system and large accessories are sent by freight carrier. Smaller accessories may be sent by parcel service.
Installation Tools and Items
Before uncrating and beginning the initial setup of your machine, collect the following tools and items.
1000-lb capacity engine hoist
NOTE: Make sure that the distance between the engine hoist legs is at least 22 inches.
  • Assistant to help you
  • Metric hex wrench set
  • Pallet jack
  • Pry bar
  • Shears or knife
  • Socket set
  • Step ladder
  • Snips
  • Work gloves
Move the Pallet
Shipments arrive in crates loaded on pallets, which the freight carrier unloads onto the curb or loading dock.
Verify that the ground surface is smooth and clean of debris, and then use a pallet jack to move the pallet(s) to the desired installation location.
