1300PL Knowledge Base
Programming - 1300PL
Programming Overview
Example:
G-Code Formatting Reference
  2. (Optional) Line number
Example
A line may have:
Line Numbers
  1. The letter N
Words
  1. A letter other than N or O
  2. A real value
Letters
Letter
A
A-axis
B
B-axis
C
C-axis
D
F
Feed rate
G
General function
H
Tool length offset index
I
X-axis offset for arcs
J
Y-axis offset for arcs
K
Z-axis offset for arcs
L
M
Miscellaneous function
N
Line number
O
Subroutine label number
P
Q
R
S
Spindle speed
T
Tool selection
U
Synonymous with A
V
Synonymous with B
W
Synonymous with C
X
X-axis
Y
Y-axis
Z
Z-axis
Values
    • An optional plus or minus sign
    • Zero to many digits
    • (Optional) One decimal point
NOTE:  PathPilot only keeps 17 significant figures, which is enough for all known applications.
A non-zero number with no sign as the first character is assumed to be positive.
Order of Execution
Example
Example
  3. Set feed rate (F)
  4. Set spindle speed (S)
  5. Special I/O (M62 to M68)
NOTE: This is not supported.
  1. Change tool (T)
  6. Operator defined commands (M101 to M199)
  7. Dwell (G04)
Modal Groups
Example
Group
Commands
Group Description
Group 1
{G00, G01, G02, G03, G33, G37/G37.1, G38.x, G73, G76, G80, G81, G82, G84, G85, G86, G88, G89}
Motion (one always in effect)
Group 2
Plane selection
Group 3
{G90, G91}
Distance mode
Group 4
{G90.1, G91.1}
Arc distance mode
Group 5
{G93, G94}
Feed rate mode
Group 6
{G20, G21}
Length units
Group 7
{G40, G41, G42, G41.1, G42.1}
Cutter compensation
Group 8
{G43, G43.1, G49}
Tool length offset
Group 10
{G98, G99}
Return mode in canned cycles
Group 12
Group 13
{G61, G61.1, G64}
Path control mode
Group 14
{G96, G97}
Spindle control mode
Group 15
{G07, G08}
Lathe diameter mode
Group
Commands
Group Description
Group 4
{M00, M01, M02, M30, M60}
Program stop and program end
Group 7
{M03, M04, M05}
Spindle control
Group 8
{M07, M08, M09}
Group 9
{M48, M49}
Override control
Non-modal G-codes are:
Comments
Example:
Supported G-Codes Reference
G-Code
G00
Rapid linear motion
G01
Linear motion at feed rate
G02
Clockwise arc at feed rate
G03
G04
Dwell
G10 L1
Set tool table
G10 L2
Set coordinate system
G10 L10
G10 L11
G10 L20
G15
Workpiece probe
G16
Pierce
G17, G18, G19
Plane selection
G20/G21
Length units
G28
Return to predefined position
G28.1
G30
G33
G33.1
Rigid tapping
G37/G37.1
Automatically measure tool lengths with an ETS
G38.x
Straight probe
G40
Cancel cutter compensation
G41/G42
G41.1, G42.1
Dynamic cutter compensation
G43
Apply tool length offset
G47
Engrave sequential serial number
G49
G53
Absolute coordinates
G54-G59.3
G61/G61.1
Set exact path control mode
G64
Set blended path control mode
G73
High-speed peck drill
G76
Multi-pass threading cycle
G80
Cancel canned cycles
G81
Drilling cycle
G82
Simple drilling cycle
G83
Peck drilling cycle
G85
Boring cycle
G86
Boring cycle
G88
Boring cycle
G89
Boring cycle
G90, G90.1
Arc distance mode
G91, G91.1
Incremental distance mode
G92
G92.x
Cancel G92, etc.
G93, G94, G95
Feed rate mode
G96, G97
G98
Programming G-Code
About the Examples Used
Rapid Linear Motion (G00)
  • X~ is the X-axis coordinate
  • Y~ is the Y-axis coordinate
  • Z~ is the Z-axis coordinate
  • A~ is the A-axis coordinate
Conditions
The motion differs if:
It's an error if:
  • All axis words are omitted
  • F~ is the feed rate
Conditions
It's an error if:
  • No F word is specified
Radius Format Arc
  • R~ is the radius of the arc
  • Nearly full circles
  • Semicircles
  • Nearly semicircles
  • Up to 165 degrees
Example
It's an error if:
  • No R word is given
Center Format Arc
It's an error if:
Arc in XY Plane
It's an error if:
  • X and Y are both omitted
  • I and J are both omitted
Arc in XZ Plane
It's an error if:
  • X and Z are both omitted
  • I and K are both omitted
Arc in YZ Plane
It's an error if:
  • Y and Z are both omitted
  • J and K are both omitted
Example
(Sample Program G02EX3:)
(Workpiece Size: X4, Y3, Z1)
N5 G90 G20
N10 M06 T2 G43 H2
N15 M03 S1200
N20 G00 X1 Y1
N25 Z0.1
N30 G01 Z-0.1 F5
N40 G01 X3.5
N55 G00 Z0.1
N60 X2 Y1.5
N65 G01 Z-0.25
N75 G00 Z1
N80 X0 Y0
N85 M05
N90 M30
Dwell (G04)
For a dwell, program: G04 P~
  • P~ is the dwell time (measured in seconds)
Example
It's an error if:
  • The P number is negative
Set Offsets (G10)
Set Tool Table (G10 L1)
  • P~ is the tool number
  • R~ is the radius of tool
It's an error if:
  • Cutter Compensation is on
  • The P number is unspecified
  • The P number is 0
Set Tool Table (G10 L10)
It's an error if:
  • The P number is 0
Set Tool Table (G10 L11)
It's an error if:
  • The P number is 0
It's an error if:
Workpiece Probe (G15)
Probe vertically downwards towards the end of travel until the ohmic cap contacts the work piece.
Once the workpiece has been located, the Z coordinate of the current coordinate system is set to zero.
G15 will trigger on either the ohmic cap making continuity with the workpiece or the physical touch switch in the torch lifter detecting upwards pressure on the torch from the material.
Pierce (G16)
Raise the torch to the pierce height set in the variable #<_PierceHeight>. The torch is turned on and the program pauses for the pierce delay value set by AutoFS or M209.
After the pierce delay, Torch Height Control (THC) is enabled and the program continues.
Length Units (G20 and G21)
If no positions are stored with G28.1 then all axes will go to the machine origin.
It's an error if:
It's an error if:
To set the G37 position:
G37.1 performs as follows:
G37 performs as follows:
Straight Probe (G38.x)
It's an error if:
  • Feed rate is zero
Example code:
o<probe_pocket> sub
#<x_max> = 1
#<x_min> = -1
#<y_max> = 1
#<y_min> = -1
#<feed_rate> = 30 (30 IPM)
F #<feed_rate>
F [#<feed_rate>/30]
F #<feed_rate>
F [#<feed_rate>/30]
G38.5 X #<x_start>
G00 X #<x_start>
F #<feed_rate>
F [#<feed_rate>/30]
G38.5 Y #<y_start>
F #<feed_rate>
F [#<feed_rate>/30]
G38.5 Y #<y_start>
G00 Y #<y_start>
o<probe_pocket> endsub
M02
It's an error if:
It's an error if:
  • D~ is the tip radius multiplied by two
It's an error if:
It's an error if:
  • The H number is negative
  • Y~ is, if present, the starting Y position, or the bottom side of the serial number
Example
It's an error if:
  • The Z number is unspecified
  • The R number is unspecified
Absolute Coordinates (G53)
It's an error if:
Example
For information, see “About Work Offsets”.
It's an error if:
    P is omitted then the speed is maintained however far from the programmed path the tool cuts.
Distance Mode (G90 and G91)
Example
It's an error if:
Example
It's an error if:
    This word is optional.
  • S~ is the surface speed.
Example
To set RPM mode, program: G97
It's an error if:
  • S is not specified with G96
Programming M-Code
Supported M-Codes Reference
M-Code
M00
Program stop
M01
Optional program stop
M02
Program end
M03, M04M03
Rotate spindle clockwise/counterclockwise
M05
Stop spindle rotation
M07, M08
Coolant on
M09
All coolant off
M30
Program end and rewind
M48
M49
M64
Activate output relays
M66
Wait on an input
M98
Call subroutine
M99
Return from subroutine/repeat
M200, M203, M205, M207-M13
Plasma specific M-codes
M301, M302, M303
USB camera control
  • In the same folder as the G-code program
  • In an images folder within the G-code program's folder
  • In an images folder within the home directory
  1. Program an M00 or M01 break, and, using parentheses, type the full file name of the image (including its extension).
Example
Display Information with Text
Example
To use M01 to take pictures:
  2. Run the G-code program.
Spindle Control (M03, M04, and M05)
To start the spindle turning counterclockwise at the currently programmed speed, program: M04
It's okay to use M03 or M04 if the spindle speed is set to 0; if this is done, the spindle won’t start turning. If later the spindle speed is set above 0, the spindle starts turning. It is permitted to use M03 or M04 when the spindle is already turning, or to use M05 when the spindle is already stopped.
Tool Change (M06)
  • If you have an ATC:
  • If you don't have an ATC:
Example
N191 M06 T3 G43 H3
Feed Override Control (M50)
The P1 is optional.
The P1 is optional.
Set Current Tool Number (M61)
  • Q~ is the tool number
It's an error if:
  • Q~ is not 0 or greater
Example
Example
The following is legal:
M64 P0
M64 P2
M64 P3
The following is not legal:
M64 P023
M64 P0 P2 P3
Wait on Input (M66)
M66 P- | E- <L->
  • L- is the wait mode type:
To begin a video recording by an attached camera, program: M301
To take a picture with an attached camera, program: M303
Plasma Specific M-Codes
M-Code
Set by M200
Parameters
M200
AutoFS - Apply the automatically generated feed, speed and cutting values for the material selected in the main PathPilot UI. AutoFS will set feedrate, THC voltage, and pierce delay.
M203
Start Torch
M205
Stop Torch and return to G30 Z Height
M207
Set Pierce Height used when executing a G16 pierce. Set automatically when using M200 AutoFS.
Yes
P (Required): Pierce height in the current unit system (in. or mm.)
M208
Set Cut Height used when executing a G16 pierce. Set automatically when using M200 AutoFS.
Yes
P (Required): Cut height in the current unit system (in. or mm.)
M209
Set Pierce Delay used when executing a G16 pierce.
Yes
P (Required): Pierce delay in seconds
M210
Set THC voltage. Does not enable or disable THC.
Yes
P (Required): Desired THC Voltage
M211
Set plasma source cut current.
If a Hypertherm adapter is not installed on the system, program run will be paused with an M01 break to allow the user to set the specified cut current.
Yes
P (Required): Desired Cut Current in Amps
M212
Set plasma source cut mode.
If a Hypertherm adapter is not installed on the system, program run will be paused with an M01 break to allow the user to set the specified cut mode.
No
P (Required): Cut mode:
Normal = 1
CPA = 2
Gouge = 3
Note: For the Hypertherm Powermax 45 Normal Mode and CPA Mode (Continuous Pilot Arc) are the same.
M213
Set plasma source air pressure.
If a Hypertherm adapter is not installed on the system, program run will be paused with an M01 break to allow the user to set the specified air pressure.
No
P: Desired Cut Pressure in PSI
Note: When the pressure is omitted or set to 0, the pressure control is set to Automatic.
Programming Input Codes
Feed Rate (F)
Spindle Speed (S)
It's an error if:
  • The S number is negative
Change Tool Number (T)
It's an error if:
  • A negative T number is used
Advanced Programming
There are significant differences between controls in the way parameters work. Do not assume that code from another control works in the same way with the operating system. We don't recommend writing parametric G-code — it’s difficult to debug, and difficult for another operator to understand. Modern CAM virtually eliminates the need for it.
Parameters
Parameters Reference
Parameter Syntax
  • Numbered - #4711
  • Named local - #<localvalue>
Parameter Scope
Parameter Mode
Persistence and Volatility
Intended Use
Numbered Parameters Reference
Read-Only Parameters
  • 5400: Current tool number
  • 5410: Current tool diameter
Named Parameters Reference
Examples
Expressions
Binary Operators Reference
  1. **
  2. * / MOD
  3. + -
  4. EQ NE GT GE LT LE
  5. AND OR XOR
Example
which is
0.5
Functions Reference
The available functions are:
  • ABS[arg]: Absolute value
  • ACOS[arg]: Inverse cosine
  • ASIN[arg]: Inverse sine
  • COS[arg]: Cosine
  • LN[arg]: Base-e logarithm
  • SIN[arg]: Sine
  • SQRT[arg]: Square root
  • TAN[arg]: Tangent
Subroutines
Subroutines Reference
  • o123
  • o99999
  • o<my test code>
  • Call: Call the subroutine
  • Return: Return a value
Example of sub, endsub, call:
o100 sub
o100 endsub
M02
For example, this is valid:
o100 sub
o100 endsub
M02
But this is not:
M02
o100 sub
o100 endsub
if/endif
If/endif example:
o100 sub
o110 if [#2 GT 5]
(some code here)
o110 endif
(some more code here)
o100 endsub
if/elseif/else/endif
If/elseif/endif example:
F100
F200
F150
o102 endif
Repeat example:
(Mill 5 diagonal shapes)
G91 (Incremental mode)
o103 repeat [5]
o103 endrepeat
G90 (Absolute mode)
Looping Subroutines Reference
do/while
Do/while loop example:
o100 do
(debug, parameter 1 = #1)
o110 if [#1 EQ 2]
o110 endif
(some code here)
o100 while [#1 LT 3]
M02
while/endwhile
While/endwhile example:
(draw a sawtooth shape)
F25 (set a feed rate)
o101 while [#1 LT 10]
G01 X0
G01 Y[#1/10] X1
o101 endwhile
M02 (end program)
This is a section of the 1300PL operator's manual. To view the whole manual, go to Tormach document UM10720.
