PCNC 440 Knowledge Base
Performance Expectations
Each machine has a Certificate of Inspection, which details quality assurance measurements performed by members of our quality assurance team prior to shipping.
Cutting Performance
This machine is capable of cutting a wide variety of materials (for information, see Intended Use) at or near their recommended feeds and speeds. Make sure that your workpiece is held as rigidly as possible and use the most rigid tooling available for roughing cuts. Verify that the programmed operations do not exceed the available spindle power.
Spindle Speed Range
  • Low 300 rpm to 4500 rpm
  • High 650 rpm to 10,000 rpm
  • Spindle Power Rating 0.75 hp (0.56 kW)
  • Maximum Feed Rate
    • X- and Y-Axis 135 IPM (3.43 m/min)
    • Z-Axis 110 IPM (2.7 m/min)
Resolution and Accuracy
Accuracy is heavily influenced by the techniques that the machinist uses. A skilled machinist can deliver accuracy that exceeds the specified accuracy from the manufacturer; an inexperienced machinist may have difficulty delivering the specified accuracy. We can't predict operator accuracy, but the specified accuracy is an important reference point.
  • Resolution 0.0001"
NOTE: The resolution of motion is the minimum discrete positional move.
  • Positional Accuracy ≤0.0016 in./10 in.
NOTE: The positional accuracy includes additional contributing factors (like compressibility of bearings, ball screw windup, and friction).
X-Axis
10" (254 mm)
Y-Axis
6.25" (159 mm)
Z-Axis
10" (254 mm)
Spindle-to-Table Maximum Clearance
12" (305 mm)
Spindle Centerline to Machine Column
6.5" (165 mm)
Spindle Power
0.75 hp (0.56 kW)
Spindle Maximum Speed
10,000 rpm
Transmission
Poly-V Belt
Spindle Taper
R8
Thread Machining
Thread Mill
Maximum Feed Rate
X- and Y-Axis
Z-Axis
110 IPM (2.7 m/min)
Axis Motor
Stepper Driven
Primary Power Required
Single-Phase 115 Vac, 50/60 Hz
Recommended Circuit Amperage
Dedicated 15 A breaker
Table
Table Size
18" × 6.3" (457 mm × 160 mm)
T-Slot Size
3/8" (9.5 mm) (three slots)
Maximum Weight on Table
150 lb (68 kg)
Overall Dimensions
Machine Size
42" × 36" (1.1 m × 0.9 m)
Overall System Height
72" (1.8 m)
Typical System Weight
600 lb (272 kg)
