PCNC 770 Knowledge Base
Open a Support Ticket
Forums
Tormach YouTube
Tech Support YouTube
Tormach.com
Main navigation
Close navigation
Main
Forums
Tormach YouTube
Tormach.com
Main
About Your Machine
Safety
Site Planning and Prep
Unpack and Mount the Machine
Install PathPilot Controller
Essential Controls Overview
Power Off/Power On Procedure
Controller Customization
Validate Basic Installation
Accessory Installation
Machine Stand - PCNC 770
Enclosure - PCNC 770
Power Drawbar - PCNC 770
ATC
Legacy ATC Installation Manual - PCNC 770
M-Style ATC Installation Manual - PCNC 770
Tool Change Scenarios
V2.X ATC Control Board Kit for M/MX ATC's
ETS - Electronic Tool Setter
microARC 4
SmartCool
SmartCool Installation Manual
FogBuster
USB I/O
Touch Screen
Vise
Basic Steps to Square a Vise
RapidTurn
RapidTurn Installation
Power Drawbar Foot Pedal
6 and 8 in. 4th Axis
How to Setup a 4th Axis
Lube Cube Coolant Kit
PCNC 770/770M Moving Kit
Machine Maintenance
PCNC 770 Maintenance
Machine Paint Color Codes
Flushing the Lubrication System
Accessory Maintenance
microARC 4 Maintenance
microARC Maintenance
Flood Coolant Maintenance
ATC Maintenance
Power Drawbar Maintenance - PCNC 770
Operation and Programming
Machine Operation
Basic Operation - PCNC 770
PathPilot Interface - PCNC 770
Setting G30
Tormach Probing Routines
Tweaking Your Work Offsets
PathPilot Settings Backup
Creeping Up on a Part
How to Cut Holes with CNC
Probe & ETS Setup
PathPilot Programming
Programming - PCNC 770
G28 Command
CAM Driven Probing
G64/M59 Guide
Macro Programming
Conversational Drill and Tap
Spindle Troubleshooting
Preventing Collet Slip
Changing Spindle Belt Range
Spindle Tram Adjustment
Chatter
ATC Troubleshooting
ATC Tab Disappears - Legacy ATC
Tray Won't Reference - Legacy ATC
Tray In Sensor Isn't Working - Legacy ATC
Tray is Moving Too Fast or Too Slow - Legacy ATC
Low Air Pressure or Malfunctioning Air Pressure Switch - PCNC 770
Check Fuses and Cables Error
Device Homing Error
Tray-In Sensor Fault
Getting Out of an ATC Jam
Controller Troubleshooting
Controller Won't Power On - PCNC 770
Motion System Troubleshooting
Mill Gib/AC Bearing Adjustment and Backlash Compensation - PCNC 770
Lost Motion Testing - PCNC 770
Ballscrew Replacement
Axis Movement is Noisy - PCNC 770
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - PCNC 770
All Axes Won't Move When Commanded - PCNC 770
Can't Reference All Axes - PCNC 770
PCNC 1100 and 770 Series 1 and Series 2 Dip Switches
Machine Won't Power On - PCNC 770
DIN Port Jumper Test
Accessory Troubleshooting
RapidTurn Troubleshooting
Flood Coolant Troubleshooting
4th Axis Troubleshooting
microARC 4 Repair
4th Axis Backlash Adjustment
4th Axis Pin Check
Electrical Schematics and Diagrams
Lower Mill Assembly - PCNC 770
Stepper Connections - PCNC 770
Operator Panel - PCNC 770
Ribbon Cable and Miscellaneous - PCNC 770
Lubrication System - PCNC 770
Electrical Schematic - PCNC 770
Home
On this Page
ATC Maintenance
Sections
