1500MX Knowledge Base
Automatic Tool Changer Assembly - 1500MX
Alternative Part Number
ATC Slide Pin 10 mm, 1500MX*
ATC Column Mount Assembly, 1500MX*
ATC Custom Standoff Washer, M12, 1500MX (PN 52288)
Screw, Socket Head Cap, M12 × 1.75 - 30
McMaster-Carr: 91290A618
ATC Slide Assembly, 1500MX*
ATC Motor Box Assembly, 1500MX*
ATC Chip Door Turning Box, Base, Black Delrin, 1500MX (PN 53036)
ATC Chip Door, BT30 16T (PN 51865)
ATC Chip Door Turning Box, Top, Black Delrin, 1500MX (PN 53035)
ATC Cowling, 1500MX (PN 53030)
ATC Blast Assembly, 1500MX*
Locknut, Hex, M5 × 0.8
McMaster-Carr: 94645A102
ATC Gearbox Spacer, 1500MX (PN 51864)
Screw, Hex (Flat), M5 × 0.8 - 20, Black Oxide Steel
McMaster-Carr: 91294A214
ATC Tool Tray Assembly, 1500MX*
ATC Fork for MX Mills (BT30) (PN 38519)
16
17
Custom Stainless Steel Washer, M5 (PN 52482)
Washer, Pressure, 1/4 in.
McMaster-Carr: 92146A029
Screw, Hex Head, M5 × 0.8 - 20, A2 Stainless Steel
McMaster-Carr: 91287A125
ATC Actuator Assembly, 1500MX (PN 51859)
Screw, Socket Head Cap, M14 × 2.0 - 25, Black Oxide
McMaster-Carr: 91290A712
Cabinet Standoffs, M12 × 15 (PN 51974)
ATC Electrical Cabinet Assembly, 1500MX*
Tubing, Polyethylene Air Line, 1/4 in. OD, Black, 40 cm (PN 31457)
Tubing, Polyethylene Air Line, 1/4 in. OD, Red, 125 cm (PN 52323)
Tubing, Polyethylene Air Line, 1/4 in. OD, Black, 135 cm (PN 31457)
Tubing, Polyethylene Air Line, 1/4 in. OD, Black, 125 cm (PN 31457)
IEC 320 C13 to C14 Cable, 250 V, 10 A, 1 M, Black (PN 51969)
Vinyl Decal, microARC 6, Cord Label 38 × 77 mm (PN 52497)
Servo Drive Comm. EtherCAT Cable, 1M (PN 51970)
External STO/24 V Harness (PN 51965)
External Encoder/Motor Power Harness (PN 51967)
Mount Cover Panel, 1500MX (PN 52374)
Mount Gap Plate, 1500MX (PN 52450)
