1500MX Knowledge Base
Programming - 1500MX
About the languages that are understood and interpreted by PathPilot.
Programming Overview
Example:
G-Code Formatting Reference
  2. (Optional) Line number
Example
A line may have:
Line Numbers
  1. The letter N
Words
  1. A letter other than N or O
  2. A real value
Letters
Letter
A
A-axis
B
B-axis
C
C-axis
D
F
Feed rate
G
General function
H
Tool length offset index
I
X-axis offset for arcs
J
Y-axis offset for arcs
K
Z-axis offset for arcs
L
M
Miscellaneous function
N
Line number
O
Subroutine label number
P
Q
R
S
Spindle speed
T
Tool selection
U
Synonymous with A
V
Synonymous with B
W
Synonymous with C
X
X-axis
Y
Y-axis
Z
Z-axis
Values
  1. An optional plus or minus sign
  2. Zero to many digits
  3. (Optional) One decimal point
  4. Zero to many digits
NOTE:  PathPilot only keeps 17 significant figures, which is enough for all known applications.
Order of Execution
Example
Example
  3. Set feed rate (F)
  4. Set spindle speed (S)
  5. Special I/O (M62 to M68)
NOTE: This is not supported.
  1. Change tool (T)
  6. Operator defined commands (M101 to M199)
  7. Dwell (G04)
Modal Groups
Example
Group
Commands
Group Description
Group 1
{G00, G01, G02, G03, G33, G37/G37.1, G38.x, G73, G76, G80, G81, G82, G84, G85, G86, G88, G89}
Motion (one always in effect)
Group 2
Plane selection
Group 3
{G90, G91}
Distance mode
Group 4
{G90.1, G91.1}
Arc distance mode
Group 5
{G93, G94}
Feed rate mode
Group 6
{G20, G21}
Length units
Group 7
{G40, G41, G42, G41.1, G42.1}
Cutter compensation
Group 8
{G43, G43.1, G49}
Tool length offset
Group 10
{G98, G99}
Return mode in canned cycles
Group 12
Group 13
{G61, G61.1, G64}
Path control mode
Group 14
{G96, G97}
Spindle control mode
Group 15
{G07, G08}
Lathe diameter mode
Group
Commands
Group Description
Group 4
{M00, M01, M02, M30, M60}
Program stop and program end
Group 7
{M03, M04, M05}
Spindle control
Group 8
{M07, M08, M09}
Group 9
{M48, M49}
Override control
Non-modal G-codes are:
Group 0 {G04, G10, G28, G30, G53, G92, G92.1, G92.2, G92.3}
Comments
Example:
Supported G-Codes Reference
G-Code
G00
Rapid linear motion
G01
Linear motion at feed rate
G02
Clockwise arc at feed rate
G03
G04
Dwell
G10 L1
Set tool table
G10 L2
Set coordinate system
G10 L10
G10 L11
G10 L20
G17, G18, G19
Plane selection
G20/G21
Length units
G28
Return to predefined position
G28.1
G30
G33
G33.1
Rigid tapping
G37/G37.1
Automatically measure tool lengths with an ETS
G38.x
Straight probe
G40
Cancel cutter compensation
G41/G42
G41.1, G42.1
Dynamic cutter compensation
G43
Apply tool length offset
G47
Engrave sequential serial number
G49
G53
Absolute coordinates
G54-G59.3
G61/G61.1
Set exact path control mode
G64
Set blended path control mode
G73
High-speed peck drill
G76
Multi-pass threading cycle
G80
Cancel canned cycles
G81
Drilling cycle
G82
Simple drilling cycle
G83
Peck drilling cycle
G85
Boring cycle
G86
Boring cycle
G88
Boring cycle
G89
Boring cycle
G90, G90.1
Arc distance mode
G91, G91.1
Incremental distance mode
G92
G92.x
Cancel G92, etc.
G93, G94, G95
Feed rate mode
G96, G97
G98
Programming G-Code
About the Examples Used
Rapid Linear Motion (G00)
  • X~ is the X-axis coordinate
  • Y~ is the Y-axis coordinate
  • Z~ is the Z-axis coordinate
  • A~ is the A-axis coordinate
Conditions
The motion differs if:
It's an error if:
All axis words are omitted
G10, G28, G30 or G92 appear in the same block
  • F~ is the feed rate
Conditions
It's an error if:
  • No F word is specified
Radius Format Arc
  • R~ is the radius of the arc
  • Nearly full circles
  • Semicircles
  • Nearly semicircles
  • Up to 165 degrees
Example
It's an error if:
Both of the axis words for the axes of the selected plane are omitted
  • No R word is given
Center Format Arc
It's an error if:
Arc in XY Plane
It's an error if:
  • X and Y are both omitted
  • I and J are both omitted
Arc in XZ Plane
It's an error if:
  • X and Z are both omitted
  • I and K are both omitted
Arc in YZ Plane
It's an error if:
  • Y and Z are both omitted
  • J and K are both omitted
Example
(Sample Program G02EX3:)
(Workpiece Size: X4, Y3, Z1)
N5 G90 G20
N10 M06 T2 G43 H2
N15 M03 S1200
N20 G00 X1 Y1
N25 Z0.1
N30 G01 Z-0.1 F5
N40 G01 X3.5
N55 G00 Z0.1
N60 X2 Y1.5
N65 G01 Z-0.25
N75 G00 Z1
N80 X0 Y0
N85 M05
N90 M30
Dwell (G04)
For a dwell, program: G04 P~
  • P~ is the dwell time (measured in seconds)
Example
It's an error if:
  • The P number is negative
Set Offsets (G10)
Set Tool Table (G10 L1)
  • P~ is the tool number
  • R~ is the radius of tool
It's an error if:
  • Cutter Compensation is on
  • The P number is unspecified
  • The P number is 0
Set Tool Table (G10 L10)
It's an error if:
  • The P number is 0
Set Tool Table (G10 L11)
It's an error if:
  • The P number is 0
It's an error if:
Length Units (G20 and G21)
If no positions are stored with G28.1 then all axes will go to the machine origin.
It's an error if:
It's an error if:
To set the G37 position:
G37.1 performs as follows:
NOTE: MX BT30 tool holders are designed to seat in the spindle taper, and should never touch the nose of the spindle.
NOTE: On MX mills, use the tip of the BT30 drive dog, not the spindle nose, to reference .
G37 performs as follows:
Straight Probe (G38.x)
It's an error if:
  • Feed rate is zero
Example code:
o<probe_pocket> sub
#<x_max> = 1
#<x_min> = -1
#<y_max> = 1
#<y_min> = -1
#<feed_rate> = 30 (30 IPM)
F #<feed_rate>
F [#<feed_rate>/30]
F #<feed_rate>
F [#<feed_rate>/30]
G38.5 X #<x_start>
G00 X #<x_start>
F #<feed_rate>
F [#<feed_rate>/30]
G38.5 Y #<y_start>
F #<feed_rate>
F [#<feed_rate>/30]
G38.5 Y #<y_start>
G00 Y #<y_start>
o<probe_pocket> endsub
M02
It's an error if:
It's an error if:
  • D~ is the tip radius multiplied by two
It's an error if:
It's an error if:
  • The H number is negative
Y~ is, if present, the starting Y position, or the bottom side of the serial number
Example
It's an error if:
  • The Z number is unspecified
  • The R number is unspecified
Absolute Coordinates (G53)
It's an error if:
Example
For information, see “About Work Offsets”.
It's an error if:
    If P is omitted then the speed is maintained however far from the programmed path the tool cuts.
Distance Mode (G90 and G91)
Example
It's an error if:
  • All axis words are omitted
Example
It's an error if:
    This word is optional.
  • S~ is the surface speed.
Example
To set RPM mode, program: G97
It's an error if:
  • S is not specified with G96
Programming Canned Cycles
Canned Cycles Reference
Supported Canned Cycles
Canned Cycle
G80
Cancel active canned cycle
G81
G82
Simple drilling with dwell cycle
G83
Peck drilling cycle
G73
High speed peck drilling cycle
G84
Tapping cycle
G85
Boring cycle – feedrate out
G86
Boring cycle – stop, rapid out
G88
Boring cycle – stop, manual out
G89
Boring cycle – dwell, feedrate out
Rotational axis (A-axis) words are allowed in canned cycles, but it's better to omit them. If rotational axis words are used, the numbers must be the same as the current position numbers so that the rotational axes do not move.
The R number is always sticky — it keeps its value on subsequent blocks if they're not explicitly programmed to be different.
In incremental distance mode (G91), when the XY-plane is selected, X, Y, and R numbers are treated as increments to the current position and Z as an increment from the Z-axis position before the move involving Z takes place; when the YZ- or XZ-plane is selected, treatment of the axis words is analogous.
It's an error if:
When the XY plane is active, the Z number is sticky and it's an error if:
When the XZ plane is active, the Y number is sticky and it's an error if:
When the YZ plane is active, the X number is sticky and it's an error if:
High Speed Peck Drill (G73)
The G73 cycle is intended for deep drilling with chip breaking. The retracts in this cycle break the chip but do not totally retract the drill from the hole. It's suitable for tools with long flutes which clear the broken chips from the hole.
Program: G73 X~ Z~ R~ L~ Q~
Q~ is the delta increment along the Z-axis
The G73 cycle is as follows:
  1. Preliminary canned cycle motion
  2. Move the Z-axis only at the current feed rate downward by delta or to the Z position (whichever is less deep).
  3. Rapid back incrementally in Z 0.010 in.
  4. Repeat Step 1 through 3 until the Z position is reached at Step 1.
  5. Rapid back down to the current hole bottom, backed off a bit.
  6. Retract the Z-axis at traverse rate to clear Z.
It's an error if:
Cancel Canned Cycles (G80)
To cancels all canned cycles, program: G80
It's okay to program G80 if no canned cycles are in effect. After a G80, the motion mode must be set with G00 (or any other motion mode G word). If motion mode is not set after G80, this error message appears: "Cannot use axis values without a g code that uses them."
Drilling Cycle (G81)
The G81 Cycle is as follows:
  1. Preliminary canned cycle motion.
  2. Move the Z-axis only at the current feed rate to the Z position.
  3. Retract the Z-axis at traverse rate to clear Z.
Examples
Example
This means that it's in absolute distance mode (G90), old Z retract mode (G98) and the G81 drilling cycle is performed once. The X number and X position are 4. The Y number and Y position are 5. The Z number and Z position are 1.5. The R number and clear Z are 2.8. The following moves take place:
Example
This means that it's in incremental distance mode (G91), old Z retract mode, and the G81 drilling cycle is repeated three times. The X number is 4, the Y number is 5, the Z number is -0.6 and the R number is 1.8. The initial X position is 5 (=1+4), the initial Y position is 7 (=2+5), the clear Z position is 4.8 (=1.8+3) and the Z position is 4.2 (=4.8-0.6). Old Z is 3.0.
The first move is a traverse along the Z-axis to (1,2,4.8), since old Z < clear Z.
The first repeat consists of three moves:
Example code using G81 cycle:
(Sample Program G81EX18:)
N5 G90 G80 G20
N10 M06 T6 G43 H6
N15 M03 S1300
N20 G00 X1 Y1
N25 Z0.5
N35 X2
N40 X3
N45 Y2
N50 X2
N55 X1
N65 X0 Y0
N70 M05
N75 M30
Simple Drilling Cycle (G82)
The G82 cycle is as follows:
  3. Dwell for the P number of seconds.
  4. Dwell for the P number of seconds.
Peck Drilling Cycle (G83)
Q~ is a delta increment along the Z-axis
The G83 cycle is as follows:
  2. Move the Z-axis only at the current feed rate downward by delta or to the Z position, whichever is less deep.
  3. Rapid back out to the clear Z.
  4. Repeat Steps 1 through 3 until the Z position is reached at Step 1.
It's an error if:
Tapping Cycle (G84)
The G84 cycle is intended for tapping. This cycle rotates the spindle clockwise to tap a pre-drilled hole; when the bottom of the hole is reached, the spindle rotates in the reverse direction and exits the hole.
Program: G84 X~ Y~ Z~ R~ P~ F~
  • X~ is the position of the hole on the X-axis
  • Y~ is the position of the hole on the Y-axis
  • Z~ is the depth, tapping from the R-plane to the Z-depth
  • R~ is the position of the retract plane (R-plane)
  • P~ is the number of seconds to dwell
The G84 cycle is as follows:
  2. Start the spindle forward.
  3. Move the Z-axis at the programmed feed rate (F~) to the Z-depth.
  4. Reverse the spindle.
  5. Dwell for the P number of seconds.
  6. Retract the Z-axis at the programmed feed rate (F~) to the R-plane.
This cycle uses a P word, where P specifies the number of seconds to dwell. The P word is optional – if it is not included, PathPilot calculates a dwell for you (half of a second per 1000 RPM).
Spindle speed must be commanded before calling a G84 cycle. Feed rate override is ignored during a tapping cycle. Feedhold is ignored until the return operation is executed. After the tapping operation is completed, either a G98 or G99 command controls the return height — G99 returns the tool to the R-plane; G98 returns the tool to the initial height.
Example
N40 T51 G43 H51 M6
N45 S400 M3
N50 G54
N55 M8
N65 G0 X0.5 Y-0.75
N70 G43 Z0.6 H51
N80 G0 Z0.2
N85 S400
N90 G98 G84 X0.5 Y-0.75 Z-0.605 R0.2 F20.
N95 X1.0 Y -1.25
N100 G80
N105 G0 Z0.6
Boring Cycle (G85)
The G85 cycle is as follows:
  3. Retract the Z-axis at the current feed rate to clear Z.
Boring Cycle (G86)
The G86 cycle is intended for boring. This cycle uses a P number for the number of seconds to dwell.
Program: G86 X~ Y~ Z~ A~ R~ L~ P~
The G86 cycle is as follows:
  4. Stop the spindle turning.
  5. Retract the Z-axis at traverse rate to clear Z.
  6. Restart the spindle in the direction it was going.
  7. Move the Z-axis only at the current feed rate to the Z position.
It's an error if:
  • The spindle is not turning before this cycle is executed
Boring Cycle (G88)
The G88 cycle is as follows:
  5. Stop the program so the operator can retract the spindle manually.
  6. }Restart the spindle in the direction it was going.
Boring Cycle (G89)
The G89 cycle is as follows:
  4. Retract the Z-axis at the current feed rate to clear Z.
Programming M-Code
Supported M-Codes Reference
M-Code
M00
Program stop
M01
Optional program stop
M02
Program end
M03, M04
Rotate spindle clockwise/counterclockwise
M05
Stop spindle rotation
M07, M08
Coolant on
M09
All coolant off
M30
Program end and rewind
M48
M49
M64
Activate output relays
M65
Deactivate output relays
M66
Wait on an input
M98
Call subroutine
M99
Return from subroutine/repeat
M231, M233
Chip Conveyor Control
M301, M302, M303
USB camera control
  • In the same folder as the G-code program
  • In an images folder within the G-code program's folder
  • In an images folder within the home directory
  1. Program an M00 or M01 break, and, using parentheses, type the full file name of the image (including its extension).
Example
Display Information with Text
Example
To use M01 to take pictures:
  2. Run the G-code program.
Spindle Control (M03, M04, and M05)
To start the spindle turning counterclockwise at the currently programmed speed, program: M04
It's okay to use M03 or M04 if the spindle speed is set to 0; if this is done, the spindle won’t start turning. If later the spindle speed is set above 0, the spindle starts turning. It is permitted to use M03 or M04 when the spindle is already turning, or to use M05 when the spindle is already stopped.
Tool Change (M06)
  • If you have an ATC:
  • If you don't have an ATC:
Example
N191 M06 T3 G43 H3
Feed Override Control (M50)
The P1 is optional.
The P1 is optional.
Set Current Tool Number (M61)
  • Q~ is the tool number
It's an error if:
  • Q~ is not 0 or greater
Example
Example
The following is legal:
M64 P0
M64 P2
M64 P3
The following is not legal:
M64 P023
M64 P0 P2 P3
Wait on Input (M66)
M66 P- | E- <L->
  • L- is the wait mode type:
Chip Conveyor Control (M231 and M233)
To turn the chip conveyor on, program: M231 P~ Q~
  • P~ is the number of seconds to run.
  • Q~ is the number of seconds to idle.
  • If P~ and Q~ are omitted, the chip conveyor runs continuously.
To turn the chip conveyor off, program: M233
To begin a video recording by an attached camera, program: M301
To take a picture with an attached camera, program: M303
Programming Input Codes
Feed Rate (F)
Spindle Speed (S)
It's an error if:
  • The S number is negative
Change Tool Number (T)
It's an error if:
  • A negative T number is used
Advanced Programming
There are significant differences between controls in the way parameters work. Do not assume that code from another control works in the same way with the operating system. We don't recommend writing parametric G-code — it’s difficult to debug, and difficult for another operator to understand. Modern CAM virtually eliminates the need for it.
Parameters
Parameters Reference
Parameter Syntax
  • Numbered - #4711
  • Named local - #<localvalue>
Parameter Scope
Parameter Mode
Persistence and Volatility
Intended Use
Numbered Parameters Reference
Read-Only Parameters
  • 5400: Current tool number
  • 5410: Current tool diameter
Named Parameters Reference
Examples
Expressions
Binary Operators Reference
  1. **
  2. * / MOD
  3. + -
  4. EQ NE GT GE LT LE
  5. AND OR XOR
Example
which is
0.5
Functions Reference
The available functions are:
  • ABS[arg]: Absolute value
  • ACOS[arg]: Inverse cosine
  • ASIN[arg]: Inverse sine
  • COS[arg]: Cosine
  • LN[arg]: Base-e logarithm
  • SIN[arg]: Sine
  • SQRT[arg]: Square root
  • TAN[arg]: Tangent
Subroutines
Subroutines Reference
  • o123
  • o99999
  • o<my test code>
  • Call: Call the subroutine
  • Return: Return a value
Example of sub, endsub, call:
o100 sub
o100 endsub
M02
For example, this is valid:
o100 sub
o100 endsub
M02
But this is not:
M02
o100 sub
o100 endsub
if/endif
If/endif example:
o100 sub
o110 if [#2 GT 5]
(some code here)
o110 endif
(some more code here)
o100 endsub
if/elseif/else/endif
If/elseif/endif example:
F100
F200
F150
o102 endif
Repeat example:
(Mill 5 diagonal shapes)
G91 (Incremental mode)
o103 repeat [5]
o103 endrepeat
G90 (Absolute mode)
Looping Subroutines Reference
do/while
Do/while loop example:
o100 do
(debug, parameter 1 = #1)
o110 if [#1 EQ 2]
o110 endif
(some code here)
o100 while [#1 LT 3]
M02
while/endwhile
While/endwhile example:
(draw a sawtooth shape)
F25 (set a feed rate)
o101 while [#1 LT 10]
G01 X0
G01 Y[#1/10] X1
o101 endwhile
M02 (end program)
