770M Knowledge Base
  • Digital multimeter
  • Metric hex wench set
  • Phillips screwdriver
Touch Screen isn't Responding
Reseat the USB Cable (Touch screen only)
  1. Unplug and re-plug the USB cable from both the controller and the monitor. Then restart the controller to test. If the monitor still doesn’t work, go to Step 2.
  2. Replace the USB cable with a known good USB cable from another computer. Then restart the controller to test.
  1. From the PathPilot interface, in the MDI Line DRO field, type ADMIN TOUCHSCREEN and press the Enter key on the keyboard. Then follow the onscreen prompts to calibrate the touch screen.
  1. Go to the File tab in PathPilot. Press the Home button.
  2. Locate the pointercal.xinput file and highlight it.
  3. Press the Delete button.
  4. Exit out of PathPilot and re-boot controller.
  5. Upon restarting the controller, Path Pilot should prompt you to go through the touch screen calibration, make sure to touch all 4 touch points with finger or stylus (not mouse).
Console isn’t Receiving Power
M/MX Electrical Cabinet
    4. Panel Color Depth: 24 Bit
RPM, Feed Override, or Max Velocity Knobs Don’t Work
  1. Computer
  3. DB25 Connector for Pendant
Daughter Board
  3. E-Stop circuit connection
  5. Key switch input
  7. Front panel LED connector
Potentiometer Board (39376)
Examine Wiring to Buttons
