770M Knowledge Base
Early 1100m and 770m mills utilized 10x38 mm ceramic fuses for the XMF1 transformer. While more then capable to perform the job, it is harder for customers to find replacements and they are typically more expensive.
Machine
Serial Number
1100M
MA10141 and lower
770M
MB10089 and lower
Part Numbers
1100M - PN 39135 XFM1 fuse holder replacement kit
770M - PN 39136 XFM1 fuse holder replacement kit
a. Flat Head Screwdriver – 1/8” (6mm) wide blade
b. Wire Cutter
c. Wire Stripper or Utility Knife
d. Wire Connection Crimper, or a pair of Pliers
  1. Remove power to the machine
  2. Locate the Original Fuse Blocks and remove them by pulling up and out on the bottom of the fuse block.
Note: 770m only has a single fuse block holder
  1. Remove the wires using a flat head screwdriver
  2. Use the wire cutters to remove the spade connectors from the end of the wires
    a. 1100M: for all 4 wires; 770M: for both wires
    NOTE: Cut as close to the spade connector as possible Make sure the wire label does not fall off
  1. Pull back the wire label and use the wire stripper/utility knife to remove a 1/4" (6mm) section of the wire casing
  1. Slide on the included Pin terminal connectors onto the bare wire and use the crimper/pliers to clamp the terminal to the wire as shown below
  1. Add the side plate to the new grey fuse block(s) and install the fuse(s)
  1. Snap the new grey fuse block(s) onto the DIN rail by hooking the top of the rail with the block and swinging the bottom in until it clicks.
  1. Wire the block(s) as shown in the picture below.
