AF50+ Knowledge Base
Programmable Automatic Workpiece Positioning
Cut Lengths
0.157 in. to 50 in. (4 mm to 1270 mm)
Maximum Length Per Stroke
Up to 10 in. (254 mm)
Maximum Strokes per Part
Maximum Parts per Program
999
Maximum Capacity
Rectangular Stock
6 in. tall × 8 in. wide (152 mm tall × 203 mm wide)
Round Stock
7 in. (178 mm) diameter
Material Weight
250 lbs (113 kg), subject to air supply pressure
Blade
Motor Power
1 hp (0.75 kW)
Blade Speeds
60 Hz: 90, 134, 195, 255 ft/min (27, 41, 59, 78 m/min)
50 Hz: 70, 110, 160, 210 ft/min (22, 34, 49, 64 m/min)
Blade Length
93 in. (2362 mm)
Blade Width
0.75 in. (19 mm)
Blade Thickness
0.035 in. (0.9 mm)
Coolant
Capacity
2.65 gal (10 L)
Dimensions
Floor-To-Table Height
22 in. (559 mm)
Typical System Weight
450 lb (205 kg)
Power and Air Requirements
Primary Power
Single-Phase 115 Vac, 50/60 Hz
Required Circuit Amperage
Dedicated 15 A breaker
Compressed Air Source
90 psi to 120 psi (620 kPa to 827 kPa)
Space Requirements
Minimum Depth
36 in. (0.91 m) plus the length of stock
Minimum Height
67 in. (1.71 m)
Minimum Width
60 in. (1.53 m)
This is a section of the AF50+ Autofeed Bandsaw operator's manual. To view the whole manual, go to Tormach document UM10825.
