24R Knowledge Base
Base- 24R
Alternative Part Number
Base Casting*
Linear Guideway Assembly, Y-Axis (PN 39049)
Linear Rail, Y-Axis, 15 mm × 1650 mm*
Y-Axis Linear Guide Block (PN 39048)
Linear Rail Bolt Cap*
Y-Axis Ball Screw Assembly (PN 38323)
Ball Screw, Rolled, 16 mm × 5 mm - 1650 mm*
Y-Axis Ball Nut (Nut Only)*
Ball Screw Support Bearing, Fixed (PN 38328)
Motor, Stepper, NEMA 34, 1.2 deg, 450 Ncm, 3-phase, 400 mm Cable (PN 50374)
Motor Mount, NEMA 34*
Y-Axis Linear Rail Cover, Left (PN 39050)
Y Limit Switch Flag*
Cover, XY Axis Motor Mount*
Y-Axis Linear Rail Cover, Right (PN 39566)
Screw, Socket Head Cap, M4 × 0.7 - 16
McMaster-Carr: 91290A154
58
12
McMaster-Carr: 91290A242
Washer, Split Lock, M5
McMaster-Carr: 91111A124
Screw, Socket Head Cap, M6 × 1 - 60
McMaster-Carr: 91290A344
Screw, Button Head Cap, Flanged M4 × 0.7 - 8
McMaster-Carr: 92137A303
Screw, Socket Head Cap, M6 × 1 - 45
McMaster-Carr: 91290A338
Shaft Coupling, Jaw, One Piece Split, 10 mm × 0.5 in. - 35 mm
McMaster-Carr: 97654A376
12
