24R Knowledge Base
X-Axis Carriage - 24R
Alternative Part Number
X Carriage Casting*
Z-Axis Linear Rail Plate*
Linear Guideway Assembly, Z-Axis (PN 39067)
Linear Rail, Z-Axis, 15 mm × 370 mm*
X/Z-Axis Linear Guide Block (PN 39301)
Linear Rail Bolt Cap*
Limit Switch, Rectangular Proximity Sensor (PN 39074)
X Limit Switch Flag*
Z-Axis Ball Screw Assembly (PN 38372)
Ball Screw, Rolled, 16 mm × 5 mm - 321 mm*
X-Axis Ball Nut (Nut Only)*
Ball Screw Support Bearing, Floating*
Ball Screw Support Bearing, Fixed (PN 38328)
Motor, Stepper with Brake, Nema 34, 1.2 deg, 450 Ncm, 3 phase, 6.8 A, 400 mm Shrink Tube Cable, Includes Motor and Brake Connectors (PN 51133)
X-Axis Ball Nut Carrier*
Cover, Z-Axis Rear*
Access Panel, Z-Axis Rear*
Z-Axis Motor Mounting Plate*
DIN5 Connector Assembly (PN 38212)
Retaining Ring, External, 10 mm*
Screw, Socket Head Cap, M4 × 0.7 - 18
McMaster-Carr: 91290A164
14
17
Screw, Socket Head Cap, M6 × 1 - 45
McMaster-Carr: 91290A338
Washer, Split Lock, M5
McMaster-Carr: 91111A124
McMaster-Carr: 91290A242
14
20
Screw, Pan Head Machine, M4 × 0.7 - 25, Stainless Steel
McMaster-Carr: 90116A221
McMaster-Carr: 97654A376
15
22
Screw, Socket Head Cap, M4 × 0.7 - 16
McMaster-Carr: 91290A154
McMaster-Carr: 91290A330
Screw, Socket Head Cap, M8 × 1.25 - 25
McMaster-Carr: 91290A432
Shaft Coupling, Jaw, One Piece Split, 10 mm × 0.5 in. - 35 mm (PN 39318)
Screw, Socket Head Cap, M4 × 0.7 - 25
McMaster-Carr: 91290A176
16
27
Screw, Button Head Cap, M5 × 0.8 - 10
McMaster-Carr: 91239A224
Remote Oil Line Fitting*
Screw, Socket Head Cap, M5 × 0.8 - 8
McMaster-Carr: 91290A222
