AF50+ Knowledge Base
Material Slips in Vise Clamps - AF50+
Problem
The material slips in the vise clamps during operations.
Cause
The air pressure to the vise jaws may be too low.
You May Need To…
Probability
How-To Steps
Need More?
Clean the bandsaw.
High
Examine the bandsaw for chip build-up. If necessary, clean it of chips.
Adjust the air pressure to the vise jaws.
High
Verify that the air pressure is set to at least 90 psi. If it’s not, adjust your regulator. Otherwise, examine your air supply.
For information, see “Air Requirements”.
Tighten the handwheel.
High
During manual operation, verify that the handwheel is completely tightened. If it's not, tighten it.
For information, see “Manual Operation”.
