PCNC 1100 Knowledge Base
Tool Breakage Detection
Utilizing an ETS with the G37 H~ P~ command allows you to check for broken tools mid program with Tormach’s PathPilot!
Move and Measure Tool Length
To move and measure the tool length, program: G37 H~ P~
NOTE: MX BT30 tool holders are designed to seat in the spindle taper, and should never touch the nose of the spindle.
NOTE: On MX mills, use the tip of the BT30 drive dog, not the spindle nose, to reference .
