1100M Knowledge Base
Read the packing list to see if there are any items that have not yet been delivered. We recommend waiting until you've received all shipments to begin installing the machine. Depending on the product and options ordered, the system may arrive in one or more shipments of:
  • Accessories (if applicable)
  • Machine
NOTE: The machine system and large accessories are sent by freight carrier. Smaller accessories may be sent by parcel service.
Inspect the item(s):
  • Note any damage on the delivery receipt before signing for the shipment.
Installation Tools and Items
Before uncrating and installing your machine, collect the following tools and items.
  • 4 mm hex wrench (included in tool bag)
  • 1500-lb capacity engine hoist
  • Assistant to help you
  • Combination wrench set
  • Consumables, like:
    • Anti-seize
    • Air tool oil
    • Machine way oil
  • Digital multimeter
  • Hammer
  • Level (2 ft)
  • Lifting Bar Kit (PN 31446)
  • Pallet jack
  • Phillips screwdriver (included in tool bag)
  • Pry bar
  • Reciprocating saw (or similar) to break down the pallet
  • Shears or knife
  • Socket set
  • Step ladder
  • Snips
  • Work gloves
Move the Pallet
Tools and Items Required
Pallet jack
Shipments arrive in crates loaded on pallets, which the freight carrier unloads onto the curb or loading dock.
Verify that the ground surface is smooth and clean of debris, and then use a pallet jack to move the pallet(s) to the desired installation location.
If a pallet is too wide to fit through a doorway, see Moving Dimensions (D40147).
