8L Knowledge Base
Electrical Cabinet - 8L
Electrical Cabinet Back Plate, 8L*
Spindle Brake Resistor (PN 37906)
Contactor Relay, 3-Position, 220 V, 12 A, 24 Vdc Coil, Screw Terminal (PN 37343)
Circuit Breaker (15A, 1 Pole) (PN 37521)
Relay, DPDT, 24VDC Coil, 400VAC @ 8A (PN 50830)
Filter (110 Vac/250 Vac, 20 A) (PN 37914)
Electrical Noise Suppressor (DIN Mount) (PN 37358)
Stepper Driver (PN 53488)
ECM1 Board Shield (PN 37518)
Thermal Switch, Manual Reset, Ceramic, 220 V, 10 A, 85C (PN 37420)
Terminal Block, Discrete*
44
12
ECM 1.7, Machine Control Board (PN 37509)
Power Supply (24 Vdc, 60 W) (PN 50461)
DIN Rail (35 × 7.5), 250 mm Long (PN 37910)
DIN Rail (35 × 7.5), 210 mm Long (PN 37910)
DIN Rail (35 × 7.5), 200 mm Long (PN 37910)
VFD (1.5 hp, 120 Vac Input) (PN 51123)
Power Supply, 90-132 Vac / 180-264 Vac, 75 Vdc, 600 W, 8 A (PN 39101)
Terminal Block, Discrete, Ground*
