The electrical schematic varies by serial number. Identify your machine's serial number (on the right-hand side of the machine, near the Main Disconnect switch). If the serial number is 10506 or higher, refer to the electrical schematics in this manual. If the serial number is 10505 or lower, refer to Tormach document TD10829.
Sub Systems
115 Vac Power - 8L (LA10506+) -
24 Vdc Controls - 8L (LA10506+) -
Axis Drive Bus - 8L (LA10506+) -
Spindle Drive - 8L (LA10506+) -
Machine Control Board - 8L (LA10506+) -
Limit/Door Switches - 8L (LA10506+) -
Accessory Power - 8L (LA10506+) -
Grounds - 8L (LA10506+) -
Grounds Terminal trip - 8L (LA10506+) -
AC Terminal Strip (Before EMI1) - 8L (LA10506+) -
AC Terminal Strip (After EMI1) - 8L (LA10506+) -
Control Terminal Strip - 8L (LA10506+) -
Limit Switches Terminal Strip - 8L (LA10506+) -
Operator Console Schematic - 8L (LA10506+)
