AF50 Knowledge Base
  1. Inspect the item(s):
  • Note any damage on the delivery receipt before signing for the shipment. If there is extensive visible damage to the machine, refuse to accept the shipment.
  1. Before uncrating your machine, collect the following tools and items:
  • Metric hex wrench set
  • Pallet jack
  • Pry bar
  • Snips
  • Work gloves
Move the Pallet
  • Verify that the ground surface is smooth and clean of debris, and then use a pallet jack to move the pallet(s) to the desired installation location.
This is a section of the AF50 Autofeed Bandsaw operator's manual. To view the whole manual, go to Tormach document UM10538.
