AF50 Knowledge Base
Coolant Pump Doesn't Work - AF50
Problem
The coolant pump doesn’t work.
Cause
The coolant pump may not be receiving power, or there may be faulty components.
You May Need To…
Probability
How-To Steps
Need?
Turn on the coolant pump.
High
Examine the coolant pump’s switch. If necessary, turn it to the ON position.
For information, see “Controls Overview”.
Fill the coolant tank.
High
Examine the coolant level in the coolant tank. If necessary, fill it to an appropriate level.
Examine the coolant pump.
Medium
Examine the coolant pump for blockages or mechanical damage. If necessary, remove blockages or replace the coolant pump.
Create a support ticket with Tormach Technical Support at http://tormach.com/how-to-submit-a-support-ticket for guidance on how to proceed.
Examine the main motor.
Low
Verify that the motor that drives the blade (main motor) is powered on and operating. If it’s not on, turn it on.
Replace the main fuse.
Low
Examine the main fuse. If necessary, replace it.
For information, see “Electrical Schematics”
