AF50 Knowledge Base
Noise or Machine Vibration - AF50
Problem
The machine vibrates or operates loudly.
Cause
There may be damaged components, or you may need to use a different blade or cutting speed.
You May Need To…
Probability
How-To Steps
Need More?
Change the blade or the cutting speed.
High
  • Verify that the blade’s TPI isn’t too high: you must use the correct blade for the material.
  • Verify that the cutting speed isn’t too high: lower the cutting speed, and then do a test cut. Examine the behavior of the machine as it cuts.
For information, see “Choose a Blade” or “Change the Speed”.
Examine the workpiece setup.
High
  • Manual Operation Verify that the workpiece isn’t too loose: use the handwheel to tighten the clamp on the front vise. If necessary, use a jig to hold the workpiece.
    • Automatic Operation Examine the vise clamps: verify that there is 1/8 in. or less of a gap between the clamps and the material. Then, verify that the vise jaw clamping pressure isn’t set too low for the material.
For information, see “Use Automatic Mode” or “Use Manual Mode”.
Replace or sharpen the blade.
Medium
Examine the blade for dullness. If it’s too dull, sharpen or replace it.
For information, see “Change a Blade”.
Fill the oil in the gearbox.
Medium
Examine the oil level in the gearbox. If necessary, fill it to an appropriate level.
For information, see “Replace the Gearbox Oil”.
