AF50 Knowledge Base
Machine Doesn't Start or a Panel Breaker Trips - AF50
Problem
The machine doesn’t start or a panel breaker trips.
Cause
There may be incorrect wiring or faulty components.
You May Need To…
Probability
How-To Steps
Need More?
Power on the main power supply, or examine the main power supply voltage.
High
  • Test all hot lines to confirm that they have the correct voltage on all legs.
  • Verify that the main power supply is switched to the ON position.
For information, see “Electrical Schematics”.
Replace the main fuse.
High
Examine the main fuse. If necessary, replace it.
Examine the pulley cover safety switch.
Medium
Examine the pulley cover safety switch wiring. If necessary, make the correct connections.
Rewire the plug/receptacle.
Low
Test the contacts. If necessary, make the correct connections.
Rewire the motor.
Low
Inspect the motor wiring. If necessary, make the correct connections.
Replace the start capacitor.
Low
Test the start capacitor. If necessary, make the correct connections.
Replace the panel breaker.
Low
Verify that the panel breaker is the correct size for the machine load. If it’s not, replace it.
Create a support ticket with Tormach Technical Support at http://tormach.com/how-to-submit-a-support-ticket for guidance on how to proceed.
Examine all wiring.
Low
Examine all wiring for breaks, disconnections, or corrosion. If necessary, repair or replace the wires.
Replace the motor.
Low
Test the motor. If necessary, repair or replace it.
