PCNC 1100 Knowledge Base
The DB25 is the serial communication line that connects the controller to mill. Once connected to the electrical cabinet the signal travels down a ribbon cable to an IDC26 connector. This connects to the machine control board or MX3660.
The images below are general pin alignment and the following charts show detail the DB25 pin responsibilities.
PCNC1100 and PCNC770 Mill:
Pin #
Speed/Enable - Measure 2.5Vdc (0-10kHz)
X-Axis Direction - Measure 0 Vdc (Normal) and X+, 5 Vdc X-
X+/- - Measure 5 Vdc (Normal), 4.75 Vdc (Pressed)
Y-Axis Direction - Measure 0 Vdc (Normal) and Y+, 5 Vdc X-
Y+/- - Measure 5 Vdc (Normal), 4.75 Vdc (Pressed)
Z-Axis Direction - Measure 0 Vdc (Normal) and Z+, 5 Vdc X-
Z+/- - Measure 5 Vdc (Normal), 4.75 Vdc (Pressed)
A-Axis Direction - Measure 0 Vdc (Normal) and A+, 5 Vdc X-
A+/- - Measure 5 Vdc (Normal), 4.75 Vdc (Pressed)
X Limit 5 Vdc
Y Limit 5 Vdc
12
Z Limit 5 Vdc
13
Accessory Input
14
Coolant - Measure 5 Vdc
15
Machine OK
16
FWD 5 Vdc / REV 0 Vdc
PCNC 440 Mill
Pin #
Spindle Enable
X Step
X Direction
Y Step
Y Direction
Z Step
Z Direction
A Step
A Direction
X Limit (Used for enclosure door switch)
Y Limit
12
Z Limit
13
Probe In
14
Spindle Speed
15
Estop Reset
16
Charge Pump
17
Coolant
15L Slant Pro
Pin #
Spindle Dir
ATC turret switch input
ATC forward
Collet closer
Z Encoder
A Encoder
12
B Encoder
13
Accessory Input
14
Coolant - Measure 5 Vdc?
15
Machine OK
16
Frequency encoded data input (??FWD 5 Vdc / REV 0 Vdc?)
