PCNC 1100 Knowledge Base
Upper Mill Assembly - PCNC 1100
Alternative Part Number
Lower Spindle Bearing*
ABEC identification: 7008C/DT (double tandem pair- ORDERED AS A PAIR)
Screw M8 x 30
McMaster-Carr: 91290A434
Spindle Cartridge
3A - Spindle Cartridge Assembly (PN 30306)
Spindle Cartridge Assembly for R8 includes callout numbers 1,3, 12,13,14,73, 87, 88, and 90.
Screw, M5 x 12 mm
McMaster-Carr: 91290A228
Screw, M3 x 12 mm
McMaster-Carr: 91290A117
Latch
Latch Kit (PN 31217)
Latch Kit Assembly includes callout numbers 5,6,7
Nut, M3
McMaster-Carr: 90591A250
Nut, M5
McMaster-Carr: 90591A260
Screw, M5 x 16
McMaster-Carr: 91290A232
Screw, M6 x 16
McMaster-Carr: 91290A321
Spindle Motor Cover (PN 30315)
12
Upper Spindle Bearing
ABEC identification: 7007C/DT (double tandem pair –ORDERED AS A PAIR)
13
Nut, M33 x 1.5 (PN 30317)
14
Screw, M5 x 8
McMaster-Carr: 91290A222
15
Screw, M12 x 50
McMaster-Carr: 91290A626
16
Pin, 8 x 35 (PN 30320)
17
Washer, 12 mm
McMaster-Carr: 91202A246
18
Washer, 12 mm
McMaster-Carr: 91166A290
19
Head Casting*
20
Spindle Motor Mount (PN 30324)
21
Washer, 10 mm
22
Washer, 10 mm
McMaster-Carr: 93475A280
23
Screw, M10 x 30
McMaster-Carr: 91290A522
24
Nut, M6
McMaster-Carr: 90591A151
25
Pin, 5 x 35*
26
Spindle Lock (PN 30330)
27
Spindle Lock Pivot (PN 30331)
28
Spindle Pulley (PN 30332)
29
Nut, M27 x 1.5 (PN 30333)
30
Screw, M4 x 8
McMaster-Carr: 92010A218
31
Spindle Motor Pulley (PN 30335)
32
Handle Pin (PN 30336)
33
Set Screw, M5 x 8
McMaster-Carr: 92605A231
34
Spring, 1 x 4.8 x 20 (PN 30338)
35
Spindle Motor Handle*
36
Pivot Plate Pin, 6 x 45 (PN 30340)
37
Spindle Motor Pivot Plate (PN 30341)
38
Pivot Plate Clamp Bolt*
39
Pin (PN 30343)
40
Spring, 1 x 4.8 x 20 (PN 30344)
41
Pivot Plate Clamp Handle*
42
Spindle Motor (PN 30346)
42A - Spindle Motor Fan (PN 32872)
43
Spindle Motor Pulley Spacer (PN 30347)
44
Key, 8 x 40 (PN 30348)
45
Screw, M12 x 45
McMaster-Carr: 91290A624
46
Sleeve (PN 30350)
47
Pulley Washer*
48
Screw, M8 x 20
McMaster-Carr: 91290A426
49
Screw, M6 x 30
McMaster-Carr: 91290A332
50
Spring (PN 30354)
51
Screw, M6 x 40
McMaster-Carr: 91290A203
52
Screw, M6 x 30
McMaster-Carr: 91290A344
53
Screw, M5 x 20
McMaster-Carr: 91290A242
54
Z-axis Motor w/Brake (PN 32002)
55
Screw, M5 x 26
McMaster-Carr: 91290A252
56
M5 Lock Washer
McMaster-Carr: 92148A170
57
M5 Washer
McMaster-Carr: 93475A240
58
Z-axis Motor Coupler (PN 30362)
59
Nut, M14 x 1.5 (PN 30363)
60
Lock Washer, 14 mm (PN 30364)
61
Z-axis Motor Mount Cover Plate*
62
Screw, M10 x 40
McMaster-Carr: 91290A528
63
Z-axis Motor Mount*
64
Pin, 6 x 30*
65
Screw, M16 x 12
McMaster-Carr: 91390A183
66
Screw, M16
McMaster-Carr: 3107T45
67
Spacer*
68
Z-axis Ball Screw Cover Plate (PN 30372)
69
Z-axis Ball Screw Bearing (PN 30373)
ABEC identification: ABEC7202B/Angular Contact 7201B (qty 2 needed per axis)
70
Spacer (PN 30374)
71
Z-axis Ball Screw Upper Bumper (PN 30375)
72
Column Cover Plate*
73
Spacer (PN 30377)
74
Z-axis Way Cover (PN 30378)
75
Machine Column*
76
Screw, M12 x 60
McMaster-Carr: 91290A234
77
Pin, 10 x 55 (PN 30381)
78
Z-axis Ball Screw and Nut (PN 30382)
79
Washer*
80
Z-axis Gib (PN 30384)
81
Screw (PN 30385)
82
Z-axis Saddle*
83
Z Ball Screw Nut Housing (PN 30387)
84
Z-axis Ball Screw Lower Bumper (PN 30388)
85
Spindle Belt (PN 30389)
3V280 Gates
86
Z-axis Lower Bumper Washer*
87
Spindle*
88
Pin*
89
Key, 8x26*
90
Lower Spindle Spacer (PN 30394)
91
Cylindrical Pin, 4x16*
92
Washer
93
Z-axis Lower Way Cover*
94
Pin, M6 x 35*
95
Screw, M5 x 12
McMaster-Carr: 92095A210
