xsTECH Knowledge Base
xsTECH Machine Specifications
Below you will find the technical specifications for your xsTech Router.
Table Size (X x Y)
12.6 in x 5.9 in
Max. Table Load
6.6 lbs.
Working Area (X x Y)
8.6 in x 6.3 in x 2.4 in
Spindle Motor
Direct Drive 80 W Brushless DC
Repositioning Accuracy
0.004 in
Spindle Speed Range
3000 - 15000 RPM
Noise Level (No Load Operation)
<66 dB(A)
Size
15.4 in x 15.7 in x 16.7 in
Weight
33 lbs.
Voltage Input
100 - 120 vac 50/60 Hz
Spindle Taper
ER11
