15L Knowledge Base
Lathe Headstock - 15L
Alternative Part Number
5C Collet
5C Insert (PN 33325)
5C Insert Pin*
Spindle, Lathe (PN 34252)
Screw, M8 x 20
McMaster-Carr: 96144A211
Spring, Cam Lock*
Cam Lock Pin*
Cam Lock*
D1 Rebuild Kit1 (PN 34250)
Key, M8 x 25 (PN 34257)
O-ring Seal, Spindle Nose (PN 34258)
Bearing, Spindle Nose (PN 34259)
ABEC Identification: 7013AC/DB (1 unit includes a bearing pair)
12
Spacer Sleeve, Spindle Bearing (PN 34260)
13
Spacer Ring, Spindle (PN 34261)
14
Bearing, Spindle Tail (PN 34262)
ABEC Identification: 7012AC/DB (1 unit includes a bearing pair)
15
Seal Sleeve (PN 34263)
16
Screw, M8 x 35
McMaster-Carr: 91290A438
17
Nose Cap, Headstock (PN 34265)
18
Logo Casting*
19
Screw, M5 x 20
McMaster-Carr: 91290A370
20
Screw, M12 x 40
McMaster-Carr: 96144A297
21
Washer, Lock M12
McMaster-Carr: 92148A214
22
Washer, Flat M12
McMaster-Carr: 93475A290
23
Pin, M10 x 30*
24
Head Stock Casting*
25
Not Used
26
Tail Cap, Head Stock*
27
Screw, M5 x 8
McMaster-Carr: 91290A222
28
Belt Cover Panel (PN 34276)
29
Cover Bracket*
30
Closer Mount Bracket*
31
Screw, M6 x 40
McMaster-Carr: 91290A203
32
Spanner Nut*
Spanner Nut Kit2 *
33
Set Screw, M8 x 12
McMaster-Carr: 91390A142
34
Brass Pad*
35
Set Screw, M5 x 8 Cone Tip
McMaster-Carr: 91210A808
36
Spindle Pulley (PN 34284)
37
Spindle Lock Nut (PN 34285)
38
Screw, M6 x 12
McMaster-Carr: 96144A111
39
Retaining Clip (PN 34287)
40
Encoder Pulley (PN 34288)
41
Encoder Ring Pulley (PN 34289)
42
Belt, Encoder (PN 33227)
43
Spacer, Encoder Bearing (PN 34291)
44
Key, M5 x 10 (PN 34292)
45
Encoder Shaft (PN 34293)
46
Retaining Ring (PN 34294)
47
Bearing, Encoder (PN 34295)
48
Mount Spacer, Encoder*
49
Mount, Encoder (PN 34297)
50
Washer, Flat M6
McMaster-Carr: 93475A250
51
Washer, Lock M6
McMaster-Carr: 92148A180
52
Screw, M6 x 65
McMaster-Carr: 91290A346
53
Screw, M4 x 20
McMaster-Carr: 91290A168
54
Encoder (PN 32560)
55
Belt Guard Cover (PN 34303)
56
Guard Hole Cover (PN 34304)
57
Guard Hole Cover (PN 34305)
1D1 Cam Lock Rebuild Kit (includes items #5, 6, 7, 8 = qty 3 each)
2Spanner Nut Kit (includes items #32, 33, 34)
To order part numbers not listed on http://Tormach.com , email orders@tormach.com!
