Tool Ejection Before Tray Pickup
On both the 770MX (MF/MH serials) and 1100MX, the Power Drawbar applies a small amount of force to act as a brake after a spindle orient move during tool changes. If the spindle orients into place but then drops the tool before the tray picked up the tool, a brake needle valve adjustment is likely needed. Before making any adjustments, make sure that 90-120 PSI is present at the FRL on the rear of your machine.
Adjusting the Needle Valve
The brake assembly is located on the back of the ATC.
  1. Place a cardboard box with some padding under the spindle during the adjustment period, to avoid damage to the mill table or tool holder.
  2. Load an empty tool holder into the spindle.
  3. Start by turning the brass needle valve clockwise 1/4 turn.
  1. Execute a tool change, and check for improvement. If none is seen, continue the process from step 3, until the early drop stops.
