1100MX Knowledge Base
1100MX Maintenance
Machine Maintenance
Maintenance Safety
All Maintenance Procedures
  • Power off the machine and disconnect the pneumatic supply before doing any maintenance procedures.
  • When appropriate, lockout/tagout the Main Disconnect switch and the pneumatic supply line before doing any maintenance procedures.
Swarf Maintenance Procedures
  • Wear work gloves.
Coolant Maintenance Procedures
  • Wear rubber gloves.
Maintenance Schedules
If you disassemble any components, refer to the machine's reference drawings when you've completed the maintenance procedure. For information, see Diagrams and Parts Lists. For any additional support, we can help. Create a support ticket with Tormach Technical Support at tormach.com/how-to-submit-a-support-ticket for guidance on how to proceed.
NOTE: For information on completing the following maintenance procedures, see the operator's manual for your machine.
Daily
  • Clean the way covers of chips.
  • Clean the chip baskets on the coolant tank.
  • Examine the coolant level and condition.
  • Examine the way oil level and refill as necessary.
  • Retract the plunger on the manual oiler, hold it in the retracted position for two seconds, and then release it.
NOTE: The plunger should move slowly from the retracted position. If it doesn't, it could indicate a malfunctioning oiler.
  • Verify that the regulator has at least 90 psi compressed air (for pneumatic accessories installed, like the Power Drawbar.
  • Verify that the door switches are properly functioning.
Weekly
  • Verify that the machine's lubrication points (sliding surfaces and ball screw nuts) are receiving way oil.
  • Examine the enclosure and other guards for damage.
  • Examine the drawbar for wear.
  • Remove vises, fixture plates, rotary tables, and other accessories, and then examine them for rust.
    If needed, reapply rust inhibitor before reinstalling workholding and accessories.
  • Check coolant concentration.
Monthly
  • Clean the electrical cabinet vents of dust with a clean cloth or compressed air.
  • Clean fine swarf from the coolant tank.
  • Examine all axes' slideway surfaces and ball screws to determine if an oil film is present.
  • Examine the air tool oil level in the FRL Filter-Regulator-Lubricator and refill as necessary.
Semi-Annually
NOTE: After the first 90 days of operation, complete the items on this list. After that, complete the items every six months.
  • Examine the spindle belt for wear.
  • Examine the way covers for wear.
  • Examine the X-axis flex conduit for wear.
Annually
  • Remove the way covers and examine them for wear. Clean any chips or oil underneath the way covers.
  • Examine the windows and replace them if necessary.
  • Check the machine's backlash.
Regular Maintenance
Clean the Way Covers
To extend the service life of the machine, you must make sure that the way covers are protecting the machine's slideways. Regularly do the following:
Clean the Coolant System
To extend the service life of the coolant and the coolant pump, you must make sure that both are free of contaminants.
  • Use a chip brush to clean the machine, chip trays, and enclosure of chips and other swarf.
  • Empty the chip strainer on the coolant tank.
  • Measure the coolant concentration, pH, and volume, and then compare your findings to the material's safety data sheet (SDS).
    • Coolant Level Too Low Fill the coolant tank with fresh coolant, making sure that it is the appropriate concentration.
    • Coolant pH Outside of Manufacturer's Recommended Coolant Limits Adjust the pH according to the manufacturer's recommendation.
NOTE: You must only use coolant that is recommended for machining. See "Cutting Fluid Reference".
Periodically do the following:
  • Remove the coolant tank covers and the chip strainer, and then clean the fine swarf from the coolant tank.
  • If you're using a filter to prevent small particles from entering the coolant tank, replace it when it's saturated with chips, swarf, or tramp oil.
  • Examine the coolant for contamination, and determine if the coolant's oil-water emulsion has broken.
  • Drain and thoroughly clean the coolant tank, and then replace with fresh coolant.
NOTICE! Hazardous Waste: Only dispose of coolant as advised by local environmental protection authorities. You must not dispose of coolant in a septic system or a sewer.
About Cutting Fluid
Clean and well maintained coolant has increased performance, prevents rust, and smells better than contaminated coolant.
Coolant becomes contaminated when:
  • Swarf accumulates in the chip pans, the chip strainer, or the coolant tank.
  • Tramp oil isn't regularly removed from the coolant tank.
  • The concentration or pH aren't maintained to the manufacture’s specifications.
Using flood coolant provides the following benefits:
  • Cools the cutting zone
  • Flushes away swarf
  • Lubricates the cutting tool
  • Provides some degree of rust inhibition
You must only use flood coolant that is recommended for CNC machining applications, like:
  • Soluble oils
  • Semi-synthetic coolants
  • Synthetic coolants
You must never use:
  • Coolant without rust inhibitors
  • Flammable coolants such as alcohols, diesel fuel, or kerosene
WARNING! Fire Hazard: The machine and its enclosure are not designed to contain fire or explosions. Only use materials and coolants that are intended for the specific machining operation. Never use flammable or explosive items.
  • Straight cutting oil
  • Water
If you use a coolant concentrate, you must mix it with water to the dilution ratio recommended by the coolant manufacturer. Use an optical refractometer to measure coolant concentration.
Examine the Drawbar
To extend the service life of the drawbar, you must make sure that the drawbar isn't damaged, and that it's properly lubricated.
  • Examine the drawbar for signs of wear or damage.
For the Power Drawbar, regularly do the following:
  • Use Anti-Seize to lubricate the Power Drawbar disc springs (the Belleville washers) and clamping mechanism.
  • Examine the BT30 drawbar stroke and adjust if necessary.
Examine the Enclosure Windows
Regularly examine the enclosure windows, and all other guarding, for signs of wear or damage.
When required, replace the windows with the following parts:
  • Window, 1100, Side (PN 37648)
  • Window, 1100, Left Door (PN 37649)
  • Window, 1100, Right Door (PN 37650)
Lubricate the Machine
To keep the machine operating properly, and to extend the service life of the machine, you must verify that the slideway surfaces and ball screws are receiving lubrication.
Clean the oil reservoir's cover and all exposed surfaces surrounding the oil reservoir. Swarf or debris that enters the oil reservoir can plug the small, internal passages of the lubrication system.
NOTE: The strainer at the top of the oil reservoir isn't a filter, and can't remove all types of debris that may cause blockages.
  • If there's not an oil film, examine the lubrication system for blockages, broken fittings, or pinched oil lines.
  • Examine the amount of available oil and, if necessary, refill with new, high-quality ISO VG 68 grade Machine Oil (PN 31386).
About the Manual Oiler
The manual oiler operates with a plunger:
  • On the Pull Stroke The oiler pulls machine oil from the oil reservoir.
  • On the Retract Stroke The oiler pushes machine oil through the lubrication system.
The plunger is spring-loaded, and creates a light hydraulic pressure sufficient to distribute the oil through the machine. Do not push the plunger after you retract it.
When the machine is first powered on (and then after every four hours of operation), retract the oiler's plunger and hold it in the retracted position for two seconds. Then, release the oiler's plunger.
About the Automatic Oiler
The automatic oiler is powered whenever the machine is powered on, and has the following default settings:
  • Lubrication interval: 480 minutes (8 hours)
  • Actuation time: 12 seconds
Lubrication System Reference
The machine's lubrication system distributes oil to the following 15 points:
  • 12 slideways bearing surfaces
    • Four on the X-axis
    • Four on the Y-axis
    • Four on the Z-axis
  • Three ball screw nuts
Examine the Spindle Belt
To extend the service life of the spindle belt, you must regularly examine it for signs of damage or wear.
If the spindle belt is damaged, you must replace it with 1100MX Spindle Belt (PN 50402).
Examine the Pull Stud Clamp
To extend the service life of your spindle, you must regularly do the following:
  • Examine the pull stud clamp for signs of wear or damage.
  • Make sure the inside of the spindle taper is clean and dry.
  • Use Anti-Seize (PN 31273) to lubricate the working surfaces of the pull stud clamp.
  • Use a mild degreaser to clean the shank of all tool holders.
Prevent Rust
Take proper care to protect all exposed iron and steel surfaces on your machine. To reduce the possibility of rust, you must regularly do the following:
  • Clean the machine, chip pans, and enclosure of chips and other swarf with a chip brush.
  • Clean all exterior surfaces with a mild cleaner.
  • Only use flood coolant that is recommended for machining (see "Cutting Fluid Reference" (page 5)).
  • Periodically test the coolant concentration, and adjust (if necessary) to meet coolant manufacturer's recommended concentration.
  • Put LPS 3® (or similar rust inhibitor) on the machine before installing any workholding or accessories.
  • Only operate the machine in a temperature- and humidity-controlled environment. Extreme changes in temperature or humidity can create condensation on the machine.
  • Put LPS 3® (or similar rust inhibitor) on all exposed, non-painted metal surfaces before leaving the machine unused.
  • Remove all workholding and accessories, and then check for rust.
  • If needed, reapply rust inhibitor before reinstalling workholding or accessories.
If you find rust on the machine table, continue to “Remove Rust”, below.
Remove Rust
Use a fine machinist's stone to remove light surface rust on the machine table: use light, even pressure, and move the stone in a random motion to avoid changing the flatness of the machine table.
If you find a lot of rust, or if there is rust on the machine's slideways or ball screws, take photos of all rust-covered areas. Create a support ticket with Tormach Technical Support at tormach.com/how-to-submit-a-support-ticket for guidance on how to proceed.
