24R Knowledge Base
  1. Inspect the item(s):
  • Note any damage on the delivery receipt before signing for the shipment. If there is extensive visible damage to the machine, refuse to accept the shipment.
  1. If there are any items that have not yet been delivered, we recommend waiting until you've received all shipments to begin installing the machine. Depending on the product and options ordered, the system may arrive in one or more shipments of:
  • Accessories (if applicable)
  • Machine
NOTE: The machine system and large accessories are sent by freight carrier. Smaller accessories may be sent by parcel service.
Packing List
The following items are included with your 24R (PN 39532):
  • 24R Machine Owner's Kit (PN 39534)
  • CW3000 Chiller (PN 35161)
  • Chiller Alarm Cable (PN 50381)
  • Tormach Tool Bag
The Tormach tool bag contains the following tools and items:
  • 6 mm Vacuum Gasket (PN 50362), 6 m
  • 18 mm - 21 mm Wrench (PN 50358)
  • 30 mm - 27 mm Wrench (PN 50357)
  • Adjustable Wrench (PN 50359)
  • Dust Shoe Assembly (PN 50625)
  • ER20 Collet: 1/4 in. (PN 30120)
  • ER20 Collet Nut
  • Grease Gun (PN 50360)
  • Metric Hex Wrench Set (PN 50361)
  • Operator box
The machine owner's kit contains the following items:
  • Black nylon cable tie, 4
  • Controller/Monitor Cable (PN 39042), 3
  • Ethernet Cable (PN 50383), 2000 mm
  • Grease Nozzle Kit (PN 50389)
  • M5 × 25 mm screw, 4
  • M5 nut, 4
  • Operator Box Drill Template (TD10713)
  • Operator's Manual (PN 39535)
Installation Tools and Items
Before uncrating and installing your machine, collect the following tools and items.
  • 2 in. × 6 in. × 8 in. board, 40
  • 4 in. × 4 in. × 6 ft visual grade #2 (or higher) board, 2
  • #5 drill bit
  • Combination wrenches:
    • 18 mm - 21 mm combination wrench (provided in the tool bag)
    • 30 mm - 27 mm combination wrench (provided in the tool bag)
  • Carpenter's level
  • Distilled water
  • Drill
  • Ladder (optional)
  • Metric hex wrench set (provided in the tool bag)
  • Pallet jack
  • Phillips screwdriver
  • Pry bar
  • Snips
  • Socket wrench and an 8 mm (5/16 in.) socket
  • Tape
  • Work gloves
  • Wrenches:
    • 8 mm wrench
    • 16 mm wrench
    • 21 mm wrench
    • 22 mm wrench
    • 24 mm wrench
    • Adjustable wrench (provided in the tool bag)
Move the Pallet
Tools and Items Required
  • Pallet jack
Shipments arrive in crates loaded on pallets, which the freight carrier unloads onto the curb or loading dock.
Verify that the ground surface is smooth and clean of debris, and then use a pallet jack to move the pallet(s) to the desired installation location.
