In the event your power drawbar starts making a noticeable popping sound, followed by a the tool hanging up on a tool release command, the remedy covered below should get you back to a smooth tool change situation.
Grease the Gripper
Start by covering the mill table with cardboard or towels.
Begin with an empty spindle, and spray compressed air and WD40 up the spindle at the gripper to clean out any lingering chips or debris.
Apply a liberal amount of general purpose grease to a tool holders pull stud. (Any reasonable quality grease or better will do)
Insert and release the greased holder/stud combo a number of times to make sure the grease is being deposited on the gripped and the cavity of the spindle.
Apply a little more WD40 spray onto the freshly greased gripper, but just a handful of quick shots, just enough to break down the grease a little bit, but not enough to wash it out.
Wipe any excess oil or grease off of the spindle taper itself.
Test out the drawbar for popping.
If the popping continues, you can attempt the same process with anti-seize.
