1300PL Knowledge Base
  1. Inspect the item(s):
  • Note any damage on the delivery receipt before signing for the shipment. If there is extensive visible damage to the machine, refuse to accept the shipment.
  1. If there are any items that have not yet been delivered, we recommend waiting until you've received all shipments to begin installing the machine. Depending on the product and options ordered, the system may arrive in one or more shipments of:
  • Accessories (if applicable)
  • Machine
NOTE: The machine system and large accessories are sent by freight carrier. Smaller accessories may be sent by parcel service.
Installation Tools and Items
Before uncrating and installing your machine, collect the following tools and items.
  • Tin snips
  • Flat-blade screwdriver
  • Pliers
  • 3mm, 4mm, 5mm, 6mm Allen key
  • Dead-blow hammer
  • Utility knife
  • Adjustable crescent wrench
  • Pallet jack
  • Engine hoist, forklift, or gantry crane
  • Lifting sling (2200lb / 1000kg minimum rating)
Move the Pallet
Tools and Items Required
  • Pallet jack
Shipments arrive in crates loaded on pallets, which the freight carrier unloads onto the curb or loading dock.
  • Verify that the ground surface is smooth and clean of debris, and then use a pallet jack to move the pallet(s) to the desired installation location.
  • One side of the crate is labeled Lift from this side only. Verify that there's at least 8 ft (2.5 m) of free space behind this side of the crate so that you can lay the machine down flat on the ground.
This is a section of the 1300PL operator's manual. To view the whole manual, go to Tormach document UM10720.
