1300PL Knowledge Base
Torch Pierces Too High
Pierce height is set via the AUTO F/S settings, or manually with M207. Follow the steps below for troubleshooting regarding the torch piercing too high.
Reset Trigger Depth
Reason: Torch touch trigger depth set incorrectly.
Torch touch trigger depth is the difference between the Z location where the torch touches the material and the Z location where the touch switch in the floating Z head registers a touch-off.
View the torch touch trigger depth setup process, here.
Check Programming
Reason: Wrong material picked in Auto F/S or M207 not set.
If using M200 Auto F/S, ensure that you have selected the correct material on the Main tab of PathPilot.
Using the M200 Auto F/S system chooses a pierce height appropriate for the selected material.
If not using M200 Auto F/S to set pierce height automatically, make sure that you have a call to M207 in your program to explicitly set a pierce height.
For more information on 1300PL specific G and M codes, please reference Programming - 1300PL.
