Spindle Cartridge - 770MX
Alternative Part Numbers
Magnetic Encoder, Spindle Ring (PN 38298)
Spindle Pulley, 770MX (PN 39586)
Flange, 770MX BT30 Power Drawbar*
Key, Straight, 6 mm × 6 mm - 64 mm*
Disc Spring Guide, MX BT30 Spindle (PN 39597)
Disc Spring Compression Nut, MX BT30 Spindle (PN 39598)
Disc Spring, 40 mm × 20.4 mm × 2.0 mm × 3.10 mm (PN 39689)
16
Nut, Jam, M12 × 1.75 (PN 39602)
Drawbar, BT30 Spindle (PN 39574)
Clamping Unit, BT30 (PN 39690)
Key, Straight, 4 mm × 4 mm - 12 mm*
O-Ring, 9 mm × 12 mm × 1.5 mm, Buna-N (PN 39584)
Screw, Flat Point Set, M4 × 0.7 - 5
McMaster-Carr: 92605A111
Nut, Bearing, M25 × 1.5*
Screw, Flat Point Set, M10 × 1.5 - 8
McMaster-Carr: 93245A658
McMaster-Carr: 91290A242
BT30 Clamping Unit Installation Tool (PN 50385)
18
Drawbar Core Assembly, MX BT30 Spindle (PN 39599)
