X-Axis Assembly - 770MX
Alternative Part Number
770 Machine Table*
770 X-Axis Motor Mount*
X-/Y-Axis Ball Screw Angular Contact Bearing (PN 31432)
770 X-Y Ball Screw Bearing Spacer*
Bearing Cap (PN 31530)
Sleeve*
770 X and Y Ball Screw Preload Nut (PN 31616)
770 Tab Washer for Preload Nut (PN 31542)
X-Axis Ball Screw Assembly, 770 (PN 31423)
Ball Screw Coupler (PN 31421)
X/Y-Axis Ball Screw End Bumper, 770 (PN 31613)
770 Ball Screw End Stop Clamp*
Washer, Flat, 5 × 25, 3 mm Thick*
770 X-Y Motor Mount Cover Plate*
X-Axis Limit Switch Flag (PN 31208)
Screw, Socket Head Cap, M5 × 0.8 - 8
McMaster-Carr: 91290A224
28
17
Washer, Split Lock, M8
McMaster-Carr: 91202A238
Washer, Flat, M8
McMaster-Carr: 91166A270
Pin, Taper, 8 × 30, M5 Thread*
Screw, Pan Head Machine, M5 × 0.8 - 10
McMaster-Carr: 92000A320
Front Drip Guard, 660 mm (PN 50401)
X-Axis Servo Motor, 770 (PN 38406)
X-Axis Motor Cover, 770MX (PN 39277)
Flex Conduit Bracket, X-Axis (PN 39712)
Flex Conduit Fitting, 13 mm ID × 16 mm OD (PN 30628)
McMaster-Carr: 97654A376
