AF50 Knowledge Base
Noise or Problems Moving Through the Cut - AF50
Problem
The machine is loud while cutting, or it doesn’t move freely while cutting.
Cause
The feed rate may be too high, or you may be using the wrong blade.
You May Need To…
Probability
How-To Steps
Need More?
Clean the bandsaw.
High
Examine the bandsaw for chip build-up between the blade and it’s wheels. If necessary, clean it of chips.
Adjust the feed rate.
High
Examine the blade of the material.
High
Verify that the blade’s TPI isn’t too high, or that the material isn’t too course: you must use the correct blade for the material. If you’re not, you may need to choose a new blade.
Adjust the clamping pressure.
Medium
During automatic operation, verify that the clamp pressure regulator isn’t set too low: increase the pressure, and then do a test cut. Examine the behavior of the machine as it cuts.
For information, see “Change the Clamping Pressure”.
Tighten the handwheel.
Medium
During manual operation, verify that the handwheel is completely tightened. If it’s not, tighten it.
For information, see “Manual Operation”.
Adjust the cutting speed.
Medium
Verify that the cutting speed isn’t too high: lower the cutting speed, and then do a test cut. Examine the behavior of the machine as it cuts.
For information, see “Change the Speed”.
