AF50 Knowledge Base
Cuts Are Crooked - AF50
Problem
The machine makes crooked cuts through material.
Cause
The feed rate or cutting speed may be incorrect, you may be using the wrong blade, or you may need to make adjustments to the blade.
You May Need To…
Probability
How-To Steps
Need More?
Clean the bandsaw.
High
Examine the bandsaw for chip build-up between the blade and it’s wheels. If necessary, clean it of chips.
Adjust the feed rate.
High
Replace the blade.
High
Examine the blade for dullness. If it’s too dull, replace it.
For information, see “Change a blade”.
Replace or adjust the guide bearings.
Medium
Examine the guide bearings: they may be out of adjustment, or too far away from the workpiece. If they are, adjust them.
For information, see ”Use Automatic Mode”, “Use Manual Mode”, or “Mechanical Adjustments”.
Adjust the blade’s tension.
Medium
Verify that the blade isn’t too tight or too loose between the wheels. If necessary, use the tensioner on the top of the saw head to adjust the blade’s tension.
