AF50 Knowledge Base
Material Doesn't Advance - AF50
Problem
The material isn’t moving forward during operations to continue the cut.
Cause
You may need to make adjustments to the machine, or adjust the clamping pressure.
You May Need To…
Probability
How-To Steps
Need More?
Clean the bandsaw.
High
Examine the bandsaw for chip build-up. If necessary, clean it of chips.
Remove any obstructions from the air line.
High
Verify the air line isn’t pinched. If it is, remove the obstruction.
For information, see “Air Requirements”.
Adjust the clamping pressure.
High
During automatic operation, verify that the clamp pressure regulator isn’t set too low: increase the pressure, and then test.
For information, see “Change the Clamping Pressure”.
Align the jaws.
Medium
Examine the vise clamps for correct alignment. If they’re not correctly aligned, adjust them.
For information, see “Mechanical Adjustments”.
Adjust the air pressure.
Low
Verify that the air pressure is set to at least 90 psi. If it's not adjust your regulator. Otherwise, examine your air supply.
Adjust the infeed table.
Low
Examine the infeed table for correct alignment. If it’s not correctly aligned, adjust it.
