AF50 Knowledge Base
Blades Dull Too Quickly - AF50
Problem
Blades dull earlier than expected when cutting materials.
Cause
The cutting speed or feed rathe may be incorrect, you may be using the wrong blade, or you may need to make adjustments to the blade.
You May Need To…
Probability
How-To Steps
Need More?
Clean the bandsaw.
High
Examine the bandsaw for chip build-up between the blade and it's wheels. If necessary, clean it of chips.
Adjust the feed rate.
High
Adjust the cutting speed.
High
Verify that the cutting speed isn’t too high: lower the cutting speed, and then do a test cut. Examine the behavior of the machine as it cuts.
For information, see “Change the Speed”.
Examine the blade, material, and size of cut.
High
Verify that the blade’s TPI isn’t too fine or too course for the size and type of material being cut. If not, you may need to choose a new blade. Verify that the blade isn’t breaking too frequently.
For information, see “Choose a Blade” and “Blades Break Too Frequently”.
Follow the blade break-in procedure.
High
To maximize blade life, you must follow the procedure to break in the blade.
For information, see “Break in the Blade”.
Replace the blade.
Low
Examine the blade for twists or kinks. If there are any, replace the blade.
For information, see “Change a Blade”.
Adjust the position of the blade on the wheels.
Low
Verify that the blade is correctly positioned on the wheels: open the blade cover and examine the blade. If necessary, adjust the tracking.
For information, see “Mechanical Adjustments”.
