1300PL Knowledge Base
Purpose
This document gives instructions on installing and calibrating the Touch Screen Kit.
Product Information
Product: Touch Screen Kit (PN 35575)
Monitor (PN 37761)
USB Extension Cable, 10 ft (PN 30279)
SVGA Video Extension Cable, 15 ft (PN 35705)
HDMI Cable
Screw, Pan Head, M4 × 10 mm (PN 30537)
M4 x 10 mm Thread-Forming Screw (PN 34249)
Cable Tie Holder (PN 33193)
Install the Monitor
  1. Align the monitor with the VESA mount plate.
  2. Attach the top of the monitor to the VESA mount plate with a Phillips screwdriver and two M4 × 10 mm machine screws.
  3. Attach the bottom of the monitor to the VESA mount plate with a Phillips screwdriver and two M4 × 10 mm thread-forming screws.
Figure 1: Monitor installed on the VESA mount plate.
Make Monitor Connections
  1. Connect the following cables to the touch screen monitor:
    1. Power cables
    2. HDMI
    3. USB
      IMPORTANT! If your Touch Screen Kit includes a VGA cable, discard it. If connected, the VGA cable could cause PathPilot to freeze. You'll use an HDMI cable for the touch screen installation.
  2. Connect the monitor's cables.
  3. Route all of the cables' loose ends down the Controller Arm.
  4. Secure the cables to the wire tie mounts that you installed on the round monitor post with four 4 in. cable ties.
  5. Connect the power cable to the monitor’s power transformer.
  6. Secure the power transformer to the square tube arm with two cable tie holders and two 4 in. cable ties, as shown in the following image.
Figure 2: Power transformer secured to the square tube arm.
  1. Route the loose ends of all the cables through the slots in the square tube arm.
  2. Connect the USB cable to the USB extension cable. Then, route the loose end of the cable to the PathPilot controller, and connect it to the USB 2.0 port on the controller.
  3. Route the loose end of the HDMI cable to the PathPilot controller and connect it.
  4. Route the loose end of the power cable to the back of the electrical cabinet, and connect it to any of the Accessory power outlets on the side of the electrical cabinet.
Calibrate the Touch Screen
Problem
Cause
Solutions
You Might Need To...
Probability
How-To Steps
Need More?
High
Verify that you have PathPilot v2.4.4 or higher installed on your controller.
From the PathPilot interface, in the MDI Line DRO field, type ADMIN TOUCHSCREEN SENSITIVITY 1000 and press Enter. You can use a value between 1 and 2047, but 1000 is generally sufficient for most shop spaces.
Verify that the touch screen responds to touch inputs. If it doesn't, go to the next step.
From the PathPilot interface, on the File tab, find the pointercal.xinput file and delete it.
Restart the PathPilot controller.
The calibration utility displays. For now, skip this procedure.
From the PathPilot interface, in the MDI Line DRO field, type ADMIN TOUCHSCREEN and press Enter.
The calibration utility displays. Use your finger (not a mouse) to touch all four points that display on the screen.
To view a PDF version of your manual, go to Tormach document TD10383.
