8L Knowledge Base
Setting Up Work and Tool Offsets on a Tormach Lathe
Setting up tools on a Tormach 15L and 8L, are very similar processes. The only difference is the 8L will use positive X axis values, compared the 15L using negative X axis values.
warning DISCLAIMER - PathPilot has changed over time. There may be some small changes, between the versions seen in these videos, and the most up to date versions.
