8L Knowledge Base
PathPilot Interface Overview - 8L
About PathPilot
Figure 1: Sections in the PathPilot interface.
Notebook Section
Figure 2: Notebook section.
Main Tab
Figure 3: Main tab.
  • Access G-code files that are already loaded into PathPilot, and open or close them.
    For information, see Load G-Code.
  • Send G-code commands directly to the machine using the Manual Data Input (MDI) Line DRO field.
    For information, see Manually Enter Commands.
  • In a G-code program, do tasks like finding specific terms in the code, reading the code, or viewing the generated tool path.
    For information, see Read G-Code.
File Tab
Figure 4: File tab.
  • Transfer G-code files into the PathPilot controller.
  • Edit G-code files.
    For information, see Edit G-Code.
  • Load .nc files into PathPilot to run a program.
  • Move files within the system.
    For information, see Manage System Files.
Settings Tab
Figure 5: Settings tab.
Offsets Tab
Figure 6: Offsets tab.
Conversational Tab
Figure 7: Conversational tab.
Status Tab
Figure 8: Status tab.
Persistent Controls
Figure 9: Persistent Controls section.
Program Control Area
Figure 10: Program Control area.
Position Status Area
Figure 11: Position Status area.
Manual Control Area
Figure 12: Manual Control area.
Keyboard Shortcuts
Keyboard Shortcut
Use to...
Alt+E
Edit the currently loaded G-code program (from any tab in the PathPilot interface)
Alt+Enter
Use the Manual Data Input (MDI) Line DRO field
Alt+R
Start a program
Esc
Stop a program
Shift+Alt+E
From the Main tab, quickly edit a G-code program with conversational programming
Space Bar
Feed hold the machine
Manage PathPilot Versions
Figure 13: Update button on the Status tab.
Figure 14: Software Update dialog box.
  1. Select Install.
Figure 15: Install button on the Software Update dialog box.
  1. From the PathPilot support center, download the most recent PathPilot update file.
Figure 16: Update button on the Status tab.
Figure 17: Software Update dialog box.
Figure 18: Browse dialog box.
  2. From the Status tab, select Update.
Figure 19: Update button on the Status tab.
Figure 20: Software Update dialog box.
  1. From the Browse dialog box, select Previous Versions.
Figure 21: Browse dialog box.
This is a section of the 8L operator's manual. To view the whole manual, go to Tormach document UM10753.
