1100MX Knowledge Base
If you have just installed your BT30 Power Drawbar, or the tooling is giving you issues when you try an remove it from the spindle, then you may need to make some adjustments. These adjustments are very easy to accomplish and this quick video walks you through them. In addition, 2 piston drawbars are being shipped installed in Tormach MX mills. Their adjustment is slightly different and covered in this video.
