1100MX Knowledge Base
Chip Pans
Install the Chip Pans
It is recommended to install the ATC, if applicable, before finishing the enclosure installation.
  4. Clean the surfaces of the chip pans and the Machine Stand with a mild degreaser (like Simple Green®) to make sure that the butyl tape bonds to the chip pans.
  5. Find the roll of butyl tape that you set aside while assembling the Machine Stand.
  6. Remove the cover paper, and then put one strip of butyl tape along each edge on the top of the Machine Stand. Make sure that the butyl tape completely covers the space in the corners or between joints — the butyl tape should make a seal between the Machine Stand and the chip pans to help prevent leaks.
Figure 1: Example of the locations to put butyl tape.
  1. Break the butyl tape on each screw hole on the top edge of the Machine Stand with a small hex wrench (or similar).
  2. Remove the remaining cover paper from the butyl tape strips.
  3. Align the right-hand chip pan with the Machine Stand.
  4. Loosely attach the right-hand chip pan to the Machine Stand with a 4 mm hex wrench and seven M6 × 1.0 - 12 button head flange screws.
Figure 2: Right-hand chip pan aligned with the Machine Stand.
  1. Put a strip of butyl tape along the center seam on the front of the right-hand chip pan to make a seal between the two chip pans.
  2. Remove the remaining cover paper from the butyl tape strip.
  3. Align the left-hand chip pan with the Machine Stand.
  4. Loosely attach the left-hand chip pan to the Machine Stand with a 4 mm hex wrench and 11 M6 × 1.0 - 12 button head flange screws.
Figure 3: Left-hand chip pan aligned with the Machine Stand.
  1. Securely tighten all screws on the chip pans until they're snug.
  2. Install the Emergency Stop box to the front of the chip pan with four M5 screws.
  3. Depending on your machine setup, do one of the following:
  • Machine with Enclosure You've completed the installation of the chip pans.
  • Machine Without Enclosure Find the stainless steel wear guard that you set aside earlier, and attach it across the front of the chip pans with two M5 × 0.8 - 10 button head flange screws.
Figure 4: Stainless steel wear guard aligned with the front of the chip pans.
